And Another Telcel !!!!please Solve This!!! - >> problem solved << Code: MCU SW version: V 05.00 27-04-07 RM-174 (c) Nokia |
pls try again (we bought a 5200 telcel phone and tested them ourself with every firmware and worked very well :) ) |
Tried 10 Times And Even Downgrade And Upgrade But I Will Try Again!! AND I AM NOT SURE IF I AM DOING THE UPDATE TRIGGER WELL PLEASE INSTRUCT ME IF I HAVE TO SELECT THE MODEL I AM DOING AND PRESS UPDATE TRIGGER OR JUST PRESS UPDATE TRIGGER OR WHAT?? |
perhaps new flashship and need to find trigger first in settings/support press update triger and then switch back to main not need to select any modell this update the coplete triggerlist |
hi, i uploaded new unlock- and profilbittrigger for 5200 Telcel 5200 RM-174 V 05.00 27-04-07 RM-174 (c) Nokia 5200b RM-181 V 05.00 27-04-07 RM-181 (c) Nokia (Flashchip : K5G5629ATD) Please click "update Trigger". I make new fixed PC SW version on Saturday or Sunday. NoooX-Team |
I need help Unlock 5200 telcel chip "K5G5629ATB" Code: MCU SW version: V 05.00 27-04-07 RM-174 (c) Nokia |
Hi, untick "Test Profilbit" and "Enable Profilbit K searching" on "Settings/Support" tab and try it again! NoooX-Team |
I NEED UNLOCK N75 TELCEL IS POSIBOL??? MCU SW version: V 06wk15v37 08-03-07 RM-128 (c) Nokia IMEI: 354815015265005 Provider: 3340201549764300 Providername: Telcel - Mexico Profilbit: 1000000000000000 - locked Profilbit PSW counter: 0/3 - 0/10 Simlock status: >> CLOSED << (02 locks) Server version: SIMLOCK SERVER VERSION 63 Model: N75 RM-128 ************************************************** ***** TP-Unlock supported via learning mode Find UnlockTrigger supported - AD0 Find Profilbitpatch (TelCel) supported - AD0 Find Keycounter bypass supported - AD0 Find UnlockTrigger supported - AD8 Find Profilbitpatch (TelCel) supported - AD8 Find Keycounter bypass supported - AD8 ************************************************** *** |
I need unlock n75 telcel is posibo?? MCU SW version: V 06wk15v37 08-03-07 RM-128 (c) Nokia IMEI: 354815015265005 Provider: 3340201549764300 Providername: Telcel - Mexico Profilbit: 1000000000000000 - locked Profilbit PSW counter: 0/3 - 0/10 Simlock status: >> CLOSED << (02 locks) Server version: SIMLOCK SERVER VERSION 63 Model: N75 RM-128 ************************************************** ***** TP-Unlock supported via learning mode Find UnlockTrigger supported - AD0 Find Profilbitpatch (TelCel) supported - AD0 Find Keycounter bypass supported - AD0 Find UnlockTrigger supported - AD8 Find Profilbitpatch (TelCel) supported - AD8 Find Keycounter bypass supported - AD8 ************************************************ |
yes klick unlock button :) |
Download newest version 2.23, tick "Test Profilbit" (support/Settings Tab) for your N75 and post your log please. NoooX-Team |
N75 telcel Code: MCU SW version: V 06wk15v37 08-03-07 RM-128 (c) Nokia |
dont cancel hold TP so long as software say phone unlocked |
You use bad TP! Check TP picture once again and you can unlock your phone ;) NoooX-Team |
N73 no unloker Code: MCU SW version: V 05wk47v48 26-06-07 RM-132 (c) Nokia |
