Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | -= Z3X JTAG PLUS =- | Search | Today's Posts | Mark Forums Read |
![]() | #1 (permalink) |
Insane Poster ![]() ![]() ![]() Join Date: Jul 2005 Age: 52
Member: 166086 Status: Offline Thanks Meter: 9 | Nooox Box Instructions Please!!!! - >> problem solved << CU SW version: V 05.51 05-09-07 RM-146 (c) Nokia IMEI: ************** Provider: 7040101086424810 Profilbit: 1000000000000000 - locked Profilbit PSW counter: 0/3 - 0/10 Simlock status: >> OPEN << Server version: SIMLOCK SERVER VERSION 63 Productcode: 0543661 Model: 5300 RM-146 ************************************************** ***** Unlock supported - use AD0 Keycounter bypass supported Find UnlockTrigger supported - AD0 Find Profilbitpatch (TelCel) supported - AD0 Find Keycounter bypass supported - AD0 ************************************************** ***** Donīt waste your time! Your phone is OPEN!!!! AND WHAT IS THIS ABOUT SETTINGS/SUPPORT TO UPDATE TRIGGER I DON'T UNDERSTAND WHAT TO DO HERE AND I HAVE USED ADVANCED BB5 WITH GREAT SUCCESS PLEASE HELP ME USE THIS BOX. ![]() ![]() ![]() email: [email protected] Last edited by koksi; 08-16-2008 at 11:20. |
![]() | #3 (permalink) |
Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2003
Member: 19575 Status: Offline Thanks Meter: 134 | Pls post here all logs what you have tried. Btw be sure that is no security code on it. And olso press update trigger and connect gnd near RAP. Update trigger you should press once a day or more that you have allways the newest triggers |
![]() | #4 (permalink) |
Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Aug 2008 Location: inside ProASIC3
Member: 833635 Status: Offline Sonork: 100.1578967 Thanks Meter: 604 | @jjrock Please tell us which lock is closed. Block 1,2,..? Perhaps you can post JAF or MT log from your phone. If there is a failure inside SW we change it as soon as possible!!! Thank you NoooX-Team |
![]() | #5 (permalink) |
Member: 166086 Status: Offline Thanks Meter: 9 | JAF log I have tried too unlock about 10 different phones so far...8 showed that the phones where unlocked and the other 2 unlock failed. ..please never had this problem with advanced bb5 box. Here is the JAF log for one of the phones. LOCK STATUS: CONFIG KEY: 3102000000000000 Provider: T-Mobile;U.S.A. Key Code count: 3, FBUS Code count: 10 Block 1: Lock 1: CLOSED -> Lock Data: 310160 Block 2: Lock 1: CLOSED -> Lock Data: 310200 Block 3: Lock 1: CLOSED -> Lock Data: 310210 Block 4: Lock 1: CLOSED -> Lock Data: 310220 Block 5: Lock 1: CLOSED -> Lock Data: 310230 Block 6: Lock 1: CLOSED -> Lock Data: 310240 Block 7: Lock 1: CLOSED -> Lock Data: 310250 Block 8: Lock 1: CLOSED -> Lock Data: 310260 Block 9: Lock 1: CLOSED -> Lock Data: 310270 Block 10: Lock 1: CLOSED -> Lock Data: 310310 Block 11: Lock 1: CLOSED -> Lock Data: 310580 Block 12: Lock 1: CLOSED -> Lock Data: 310660 Block 13: Lock 1: CLOSED -> Lock Data: 310800 Loading INI list... Detected P-KEY: 9001****** P-key nokia module version 01.02 Init usb communication... Reading product code... Product Code: 0531219 |
![]() | #6 (permalink) |
Member: 833635 Status: Offline Sonork: 100.1578967 Thanks Meter: 604 | @jjrock You got a new testversion via PM now. Please PM me return from FBus_Test.exe. Please post version from this phone and the log from the other 2 phones! Thank you NoooX-Team Last edited by NoooX-Box; 08-17-2008 at 00:02. |
![]() | #7 (permalink) | |
Member: 166086 Status: Offline Thanks Meter: 9 | This Phone Is Locked Here Is Fbus Read Out Quote:
Provider: 3102000000000000 PSW counter: 0/3 - 1/10 Simlock status: >> OPEN << ![]() ![]() ![]() IT SAYS OPEN EVEN THOUGH IT IS LOCKED. MCU SW version: V 05.02 05-06-07 RM-147 (c) Nokia IMEI: 356433012176346 Provider: 3102000000000000 Profilbit: 8000000000000000 PSW counter: 0/3 - 1/10 Simlock status: >> OPEN << Server version: SIMLOCK SERVER VERSION 63 Model: 5300b RM-147 ************************************************** ***** Unlock supported - AD0 Profilbitpatch (TelCel) supported - AD0 Find UnlockTrigger supported - AD0 Find Profilbitpatch (TelCel) supported - AD0 Find Keycounter bypass supported - AD0 Find UnlockTrigger supported - AD8 Find Profilbitpatch (TelCel) supported - AD8 Find Keycounter bypass supported - AD8 ************************************************** ***** Donīt waste your time! Your phone is OPEN!!!! ![]() ![]() | |
![]() | #9 (permalink) |
Member: 833635 Status: Offline Sonork: 100.1578967 Thanks Meter: 604 | Please download new NoooX_Box.exe and try it again. http://forum.gsmhosting.com/vbb/showthread.php?t=577385 Thanks NoooX-Box |
![]() | #10 (permalink) | |
Member: 166086 Status: Offline Thanks Meter: 9 | Great!!!!!!!!!!!! Quote:
Txs a lot guys!!!!!!! Very nice product unlocked my first 5300b minutes ago!!!!! Great product keep it up!!!! | |
![]() | #11 (permalink) |
Member: 166086 Status: Offline Thanks Meter: 9 | I have another 5300b that has the counters used up by advanced bb5 box. I have been trying to unlock it using Nooox but no luck any suggestions guys? Here is the read out. MCU SW version: V 05.51 05-09-07 RM-146 (c) Nokia IMEI: 356433013425726 Provider: 3102000000000000 Profilbit: 8000000000000000 PSW counter: 3/3 - 10/10 Simlock status: >> CLOSED << Server version: SIMLOCK SERVER VERSION 63 Model: 5300 RM-146 ************************************************** ***** Unlock supported - AD0 Keycounter bypass supported - AD0 Find UnlockTrigger supported - AD0 Find Profilbitpatch (TelCel) supported - AD0 Find Keycounter bypass supported - AD0 Find UnlockTrigger supported - AD8 Find Profilbitpatch (TelCel) supported - AD8 Find Keycounter bypass supported - AD8 ALSO FROM FBUS TEST YOU SENT ME 43021.55: 1E10007F000253074D6A1E100053005E014000131255FFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFF004480000000000000003102 00000000000000180DA3000000000080000001FFFFFF009400 0001FFFFFF00A8000001FFFFFF00BC000001FFFFFF00D00000 01FFFFFF00E4000001464E94 Provider: 3102000000000000 PSW counter: 3/3 - 10/10 Simlock status: >> OPEN << IT SAYS OPEN HERE?? TXS IN ADVANCED |
erro nooox box - >> problem solved << | arybraga | NoooX Box | 11 | 03-22-2010 14:59 |
Nokia 6280 Unlock with Nooox-Box , Test Mode - >> problem solved << | powerplay83 | NoooX Box | 4 | 10-12-2008 10:58 |
And Another Telcel !!!!please Solve This!!! - >> problem solved << | jjrock | NoooX Box | 20 | 09-23-2008 20:14 |
5200 not unlock, help nooox box team - >> problem solved << | landk | NoooX Box | 6 | 09-18-2008 01:31 |
