Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > NoooX Box
Old 02-13-2010, 02:15   #1 (permalink)
Member: 312779
Thanks Meter: 12
X3 FULL FLASHING Using Fbus 29secs
The same type of box, not the same service, AdvanceBox not give up updates to the user in charge, NOOOX BOX gave up on the user does not have responsibility, I think I bought the wrong box!
AdvanceBox Turbo Flasher Found
Initialize Device....
Init TRY : 1
Changing Clock to 15mhz..
Box Name : AdvanceBox Turbo
Box Firmware : LogiCore 1.16.10
Software Version : v2010.0.1.21
AdvanceBox SN : B57E17A0C7A4ED6DC97700D0
CHECK ACTIVATION : 00
BOX ACTIVATED
DDR DELAY : 01
INIT : OK
CMT Type : BB5
CMT Algorithm : XSR 1.6
CMT Supported Hardwares :
> 020C192102034000
> 0203192102034000
> 020C192102034100
> 0203192102034100
> 0203192102054100
> 020C192102054100
Secondary Sending Speed : 3250000Hz
Algorithm Sending Speed : 6500000Hz
Program Sending Speed : 19500000Hz
Message Reading Speed : 98000Hz
Number of Blocks : 136
Entry Point: 0x0259
Page Format : -1
MAX PAGE : 0x00040000
AdvanceFBox SendBootCodeEx
InitialiseBootstrap_DCT5 DIR
BootFlashMode_DCT5
BootFlashModeDCT5Ex Succeeded First Time
SYSTEM_ID_RESPONSE_BB5 (0xC0) - 2010417160 (0x08) bytes returned
Number of Sub Blocks 7 (0x07)
1 SYSTEM_ASIC_ID 01
Block Length : 21 (15)
BB ASIC Index : 0 (00) CMT
ID DWORD 0 : 00000001
ID DWORD 1 : 00000226
ID DWORD 2 : 00000001
ID DWORD 3 : 020C1921
ID DWORD 4 : 02034100
2 ROM_ID 15
Block Length : 5 (05)
ID DWORD 0 : 00001040
3 ROM_ID 15
ID DWORD 0 : 00001030
4 PUBLIC_ID 12
ID DWORD 0 : 28A00117
ID DWORD 1 : AA400E49
ID DWORD 2 : 71E5DB08
ID DWORD 3 : B7C7DD92
ID DWORD 4 : 3EBCDADF
5 ASIC_MODE_ID 13
Block Length : 2 (02)
Mode Id : 00
6 ROOT_KEY_HASH 14
Block Length : 17 (11)
Hash : 7B 04 54 00 E1 75 20 22 F9 EB 80 B0 DE A9 C6 5D
7 ROM_ID 15
Block Length : 9 (09)
CRC 0 : 67E82268
CRC 1 : F29CEA60
Checksum 39
SearchForBootstrap_DCT5..
Boot File MATCH : RAP3Gv40_2nd.fg
Boot File - Version : 009.048.000
Boot File - Revision : 0x0201
BB5ProtocolType == : New
PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0"
PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0"
TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5
TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0
TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX
TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C
ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000)
MCU_CONFIGURATION_RESPONSE_BB5:
MessageID : C1
SubBlocks : 05
1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
BB ASIC Index : CMT 00
Device Type : RAM 05
Device Index : 00
Manufacturer Code : 0000 -> Flash
Device ID : 0000 -> Not detected
Extended/Fixed ID : 0000
Revision ID : 0000
2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Type : MMC 04
Device Index : 00
Manufacturer Code : FFFF -> Flash
Device ID : 0000 -> BAD FLASH TYPE
Revision ID : 0000
3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Type : NOR 00
Device Index : 00
Revision ID : 0000
4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Index : 01
Manufacturer Code : 0000 -> SPANSION
Device ID : 0001 -> Not used
Revision ID : 0000
5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Type : MuxOneNAND 03
Device Index : 00
Manufacturer Code : 00EC ->
Device ID : 0030 -> K5W1G13ACB
Revision ID : 0321
Checksum : 27
SearchForBootstrap_DCT5 : No Error - 0 (0x00)
FLS1SendAlgoCodeEx..
SendAlgoCode_DCT5..
SearchForAlgorithm_DCT5..
Looking for ALL Devices...
Algo File MATCH : RAP3Gv40_XSR17_alg.fg
Algo Loader Sent...
SendCodeStart_NewProtocol :
SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00)
SendAlgoCodeFile_DCT5 : No Error - 0 (0x00)
FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready)
VPP Enabled by Software
Using Internal VPP
VPPSwitchInfo : VPP1 VPP_GENERATED_IN_PROMMER - VPP2 VPP_GENERATED_IN_PROMMER
CMT Does Not Support 12V VPP
CMT Does Not Support Group Erase
00 unsupported VPP Voltage setting
Using Internal VPP
SendFlashVoltageInit_DCT5
VPP1 0000
VPP2 0000
FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4
Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01)
Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only)
Certificate 1
ASIC Index : CMT 0
Certificate 2
ASIC Index : CMT 0
Certificate 3
ASIC Index : CMT 0
Certificate 4
ASIC Index : CMT 0
STORE_CERTIFICATE_REQUEST_BB5 : 61 04 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 D7
STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00)
ProcessPartitionInfo_DCT5...
Partition Info
Partition Blocks : 1
1 PARTITION_INFO_BB5
BB ASIC Index : 0x00 CMT
Device Type : 0x03 MuxOneNAND
Device Index : 0x00
Partition Version : 00010000
Spare : FFFFFFFF
Num Partitions : 00000004
Partition 1
Attribute : 00000002 RO
Start Address : 000A0000
Partition 2
ID : 00000008 FILESYSTEM
Attribute : 00000001 RW
Start Address : 02CC0000
Partition 3
Start Address : 077C0000
Partition 4
Start Address : 07B40000
PARTITION_INFO_REQUEST_BB5
PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00)
ProcessPartitionInfo_DCT5 : No Error - 0 (0x00)
StartErase_DCT5...
BlockLength : 0x00E1 (225)
ERASE Blocks : 0x0004 (4)
0 ERASE_AREA_BB5 0x12
Block Length : 0x4B (75)
Device Index : 0x00
0 : 00020000-000203FF
1 : 00060000-0009FFFF
2 : 000A0000-0025FFFF
3 : 003E0000-005DFFFF
4 : 005E0000-010DFFFF
5 : 01EC0000-01EDFFFF
6 : 027C0000-02CBFFFF
7 : 077C0000-07B3FFFF
8 : 010E0000-01EBFFFF
1 FORMAT_PARTITION_BB5 0x19
Block Length : 0x2F (47)
Device Index : 0x00
Format Info ID :0x02000000
Format Info :0000000000000008000000000000000200000064000000020 000000200000001000000000000
2 FORMAT_PARTITION_BB5 0x19
Device Index : 0x00
Format Info :000000000000000A000000010000000200000064000000020 000000200000001000000000000
3 FORMAT_PARTITION_BB5 0x19
Device Index : 0x00
Format Info :000000000000000B000000000000000200000064000000020 000000200000001000000000000
ERASE_REQUEST_BB5 : 5009120B00030000020000000203FF120B0003000006000000 09FFFF120B000300000A00000025FFFF120B000300003E0000 005DFFFF120B000300005E0000010DFFFF120B00030001EC00 0001EDFFFF120B000300027C000002CBFFFF120B000300077C 000007B3FFFF120B000300010E000001EBFFFF3D
Status_BB5 STATUS_REQUEST_BB5..
1 Sub Block ID : 15 STATUS_NAND_OK_BB5
Block Length : 0F
BB ASIC Index : 00
Device Type : 03
Device Type : 00
Num Bad Blocks : 00000001
Additional Bad : 00000001
Correctable ECC : 00000000
ERASE_REQUEST_BB5 : 5001192F000300000000020000000000000008000000000000 0002000000640000000200000002000000010000000000003E
Block Length : 0F
BB ASIC Index : 00
Device Type : 03
Device Type : 00
ERASE_REQUEST_BB5 : 5001192F00030000000002000000000000000A000000010000 0002000000640000000200000002000000010000000000003B
Block Length : 0F
BB ASIC Index : 00
Device Type : 03
Device Type : 00
ERASE_REQUEST_BB5 : 5001192F00030000000002000000000000000B000000000000 0002000000640000000200000002000000010000000000003B
Block Length : 0F
BB ASIC Index : 00
Device Type : 03
Device Type : 00
Successfully erased..
Processing : rm540__04.11.mcusw
Total blocks to write : 136
>> CMT Rootkey Hash CERT : ADA
>> CMT Rootkey Hash CERT : KEYS
>> CMT Rootkey Hash CERT : PRIMAPP
>> CMT Rootkey Hash CERT : PASUBTOC
>> CMT Rootkey Hash CERT : PAPUBKEYS
>> CMT Rootkey Hash CERT : RAP3NAND
>> CMT Rootkey Hash CERT : UPDAPP
>> CMT Rootkey Hash CERT : DSP0
>> CMT Rootkey Hash CERT : MCUSW
>> CMT Rootkey Hash CERT : MCUSW1
>> CMT Rootkey Hash CERT : GENIO_INIT
>> CMT Rootkey Hash CERT : ISA+DYNSW
ContinueFlash_DCT5 Complete
Block Length : 0F
BB ASIC Index : 00
Device Type : 03
Device Type : 00
FlashInfo.RestartMode : 1
Continue Flash Complete : : No Error - 0 (0x00)
Time Taken to Flash : 00:00:17
Making delay between files for 7000ms
CMT Type : BB5
> 020C192102034000
> 0203192102034000
> 020C192102034100
> 0203192102034100
> 0203192102054100
> 020C192102054100
Number of Blocks : 27
Entry Point: 0x011D
Page Format : -1
Init TRY : 1
BOX ACTIVATED
DDR DELAY : 01
INIT : OK
VBATT OFF ...
VBATT ON
Setting VBATT Done!...
BootFlashMode_DCT5
1 SYSTEM_ASIC_ID 01
2 ROM_ID 15
3 ROM_ID 15
4 PUBLIC_ID 12
5 ASIC_MODE_ID 13
Mode Id : 00
6 ROOT_KEY_HASH 14
7 ROM_ID 15
CRC 0 : 67E82268
CRC 1 : F29CEA60
Checksum 39
MessageID : C1
SubBlocks : 05
Block Length : 0B
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Index : 01
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0321
Checksum : 27
SendAlgoCode_DCT5..
Algo Loader Sent...
Using Internal VPP
Using Internal VPP
VPP1 0000
VPP2 0000
No RESTORE CERTIFICATE FOUND IN IMAGE FILE
Partition Info
Device Index : 0x00
Spare : FFFFFFFF
Partition 1
Partition 2
Partition 3
Partition 4
StartErase_DCT5...
BlockLength : 0x000E (14)
ERASE Blocks : 0x0001 (1)
Block Length : 0x0B (11)
Device Index : 0x00
0 : 01EE0000-027BFFFF
ERASE_REQUEST_BB5 : 5001120B00030001EE0000027BFFFF74
Block Length : 0F
BB ASIC Index : 00
Device Type : 03
Device Type : 00
Processing : rm540__04.11.ppm_a
Total blocks to write : 27
Block Length : 0F
BB ASIC Index : 00
Device Type : 03
Device Type : 00
FlashInfo.RestartMode : 2
Time Taken to Flash : 00:00:04
CMT Type : BB5
> 020C192102034000
> 0203192102034000
> 020C192102034100
> 0203192102034100
> 0203192102054100
> 020C192102054100
Number of Blocks : 54
Entry Point: 0x0154
Page Format : -1
Init TRY : 1
BOX ACTIVATED
DDR DELAY : 01
INIT : OK
VBATT OFF ...
VBATT ON
BootFlashMode_DCT5
1 SYSTEM_ASIC_ID 01
2 ROM_ID 15
3 ROM_ID 15
4 PUBLIC_ID 12
5 ASIC_MODE_ID 13
Mode Id : 00
6 ROOT_KEY_HASH 14
7 ROM_ID 15
CRC 0 : 67E82268
CRC 1 : F29CEA60
Checksum 39
MessageID : C1
SubBlocks : 05
Block Length : 0B
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Index : 01
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0321
Checksum : 27
SendAlgoCode_DCT5..
Algo Loader Sent...
Using Internal VPP
Using Internal VPP
VPP1 0000
VPP2 0000
Partition Info
Device Index : 0x00
Spare : FFFFFFFF
Partition 1
Partition 2
Partition 3
Partition 4
StartErase_DCT5...
BlockLength : 0x003F (63)
ERASE Blocks : 0x0002 (2)
Device Index : 0x00
0 : 02CC0000-077BFFFF
Device Index : 0x00
ERASE_REQUEST_BB5 : 5001120B00030002CC0000077BFFFF90
Block Length : 0F
BB ASIC Index : 00
Device Type : 03
Device Type : 00
Block Length : 0F
BB ASIC Index : 00
Device Type : 03
Device Type : 00
Processing : rm540__04.11.image_a_0580697_001
Total blocks to write : 54
Block Length : 0F
BB ASIC Index : 00
Device Type : 03
Device Type : 00
Time Taken to Flash : 00:00:08
Rebooting Box ...
Init TRY : 1
BOX ACTIVATED
DDR DELAY : 01
INIT : OK
VBATT OFF ...
VBATT ON
Waiting for phone to Power On, 8000 ms delay
Reading Phone Information...
MCU: V 04.11 09-12-09 RM-540 (c) Nokia
IMEI: lemor X3
Simlock Version : SIMLOCK SERVER
CONFIG KEY: 0000000000000000
PROVIDER KEY: 2440700000000000
Provider : AT&T;U.S.A. (3650)
Counters : 0/3 , 0/10
Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open
SP Lock Status : Not Locked
Old 02-13-2010, 03:22   #2 (permalink)
WeBoXGT's Avatar
Member: 628110
Thanks Meter: 87
wtf!!!!!
this box already dead, long time.....
Old 02-13-2010, 03:29   #3 (permalink)
rico_deep's Avatar
Member: 159757
Thanks Meter: 461
You need another BOX to DO that, advance BOX is DEAD.
That's the new ADVANCE TURBO FLASHER BOX..
vovo.
Old 08-21-2010, 04:50   #4 (permalink)
Member: 733840
Thanks Meter: 11
forget it a cheaper,use mxkey
N97 FULL FLASH VIA FBUS 1min and 34secs lemor Advance-Box 5 04-12-2010 12:24
E52 FULL Flash via FBUS = 49 Seconds Advance-Box Advance-Box 24 04-07-2010 11:26
E63 FULL FLASH VIA FBUS = 1min 31SECS lemor Advance-Box 6 02-19-2010 11:17
N75 Successfully Flash Using Fbus Cable lemor MT-BOX 8 01-15-2009 06:40
Page generated in 0.23093 seconds with 9 queries
