iPhone 4/ 4S ios5.01 and 5.1 Permanent Unlock and Activation Solution by Rebel X-SIM Rebel X-SIM iPhone 4/ 4S ios 5.01 and 5.1 Permanent Unlock Solution is Launched, This is a Permanent Unlock Solution for iPhone 4/ 4S all Versions all firmwares.. With this Solution you will only Need Rebel X-SIM one time for initializing then take it OUT and your iPhone 4S /4 is permanently Unlocked and Activated.. You will be using your iPhone 4/ 4S ios 5.01 and 5.1 WITHOUT Rebel X-SIM inserted all the time as if your iPhone 4/ 4s was NEVER Locked. No SAM required. No Jailbreak required. No Codes required. No Cables required. No Logs required. No Software or Apps required. No Need to Cut your SIM. No Need Technical Knowledge required. No 112 or any special number dialing required. Use any SIM card, without voiding your warranty, on any provider!. Supports 3G, EDGE, MMS, Facetime Supports All Network SIM Cards 2G, 3G, WCDMA. How on Earth does this Work ? 1- Insert your iPhone 4/ 4s with Rebel X-SIM. 2- Follow these steps to add your Country Provider IMSI for Unlocking and Activation. 3- Enter your IMSI and your iPhone 4/ 4s is Unlocked and Activated.. 4- Take OUT the Rebel X-SIM with from your iPhone 4/ 4S without Powering Off 5 - Insert your Network Provider WITHOUT Rebel X-SIM then Power OFF your iPhone 4s. 6- Power back ON your iPhone 4S WITHOUT Rebel X-SIM inside and iPhone 4/ 4S will ask for Activation then do nothing wait.. 7- Then You will get Network Just Click Next on the Activation Required Window and it will disappear. 8- Enjoy your iPhone 4/ 4s Fully UNLOCKED and ACTIVATED This is the last episode.. Nothing More to add.. Looking forward to ios 5.2 hehe! http://xsimcard.com/blog/wp-content/...ebel-x-sim.jpg Please remember to keep your Rebel X-SIM in a safe place because you will need it when you change your SIM card or Reset Your Network or Update Your iPhone. Best Regards. Rebel X-SIM SHOP X-SIM Forum Rebel X-SIM Blog Apple have Closed the SAM bug used for this solution.. Please refer to the link below for an update.. on this issue http://forum.gsmhosting.com/vbb/f510...-dead-1466813/ |
Its the revolution bravo bravoooooo, i am the first poster yes |
Just to verify so iPhone 4 can be unlock now? with version 5.0, 5.0.1 and 5.1 that using baseband 04.11 and 04.12? Please kindly verify because I never seen like this before using X-SIM only :D |
Though You will Need to Keep The Rebel X-SIM very safe in your home because when ever you Change your SIM card or update your iPhone you will need X-SIM again to Unlock and Take OUT.. Meaning YOU DO NOT NEED X-SIM inside your iPhone all the TIME.. UNLOCK and Take OUT.. Enjoy |
THX.... No SAM required. No Jailbreak required. No Codes required. No Cables required. No Logs required. No Software or Apps required. No Need to Cut your SIM. No Need Technical Knowledge required. No 112 or any special number dialing requir |
Yes i would like to know as it mention iphone 4/4s permanent unlock ???????????????? |
HI FRIENDS I WANT TO KNOW and we can use it in different phones one and the same x sim for the Sim unlock???? |
How can it be a Permanent unlock if after you update or reset the phone we have to reuse the card? |
But if you change that particular SIM card for example you buy a NEW SIM card then you will Need Rebel X-SIM to initialize then TAKE OUT and that SIM card is permanently Unlocked to that iPhone.. |
miliky, please do not say your X-SIM can permanently unlock iPhone 4 and iPhone 4S because your xsim only can do is temporarily unlock meaning once you reset and change the simcard the iPhone will ask for the original simcard again :D and person need the xsim again to activate! ONLY apple company can permanently unlocked all iphones in the world and no need any extra chip ( xsim, gevey sim, gpp sim ) to able to use any simcard! and will stay unlocked once you turn off, reset, update, change another simcard at all! |
Also if you RESET your iPhone Network Settings or Update later in the Future you will need X-SIM once again to Unlock iPhone 4 or 4S permanently to that SIM |
some one have already tested it??????? |
