06-27-2009, 20:40 | #31 (permalink) |
No Life Poster Join Date: Feb 2003 Location: Inside CPU Age: 43
Member: 23420 Status: Offline Thanks Meter: 3,080 | - Samsung S5230 StaR PhoneCode Reset to 00000000 over original usb cable. - Fixed bug in AKSEED bypass. - Improved communication with phone. - Included Samsung S5230 Drivers in installer package Soon more new features.... Download Latest Client from http://www.UnlockSamsungOnline.com REMARK: all old client are stop working from now.. Update is REQUIRED to 0.9.44 |
07-04-2009, 16:55 | #32 (permalink) |
Member: 23420 Status: Offline Thanks Meter: 3,080 | Samsung Remote Server is updated to version 0.9.45 In this new version: - New Samsung S3110 and S5200 E2P Unlock - Updated Server Images - Fixed bug on auto close you can download the latest version from http://www.UnlockSamsungOnline.com Remember all old versions will stop working now, SRSPRO users need to update to latest installer Soon more hot news in this HOT summer... |
07-09-2009, 19:15 | #33 (permalink) |
No Life Poster Join Date: Jul 2002
Member: 13737 Status: Offline Sonork: 100.100725 Thanks Meter: 194 | on mines direct unlock not active and also user code reset does,t seem to work on S5320 after reset code its still the same phone lock code any special trick or may be client is not advanced? |
07-09-2009, 21:20 | #34 (permalink) |
Member: 23420 Status: Offline Thanks Meter: 3,080 | make sure port is correct and drivers are installed ok, we tested on more than 20 phones, and on all phones the usercode will reset to 00000000 |
08-16-2009, 15:58 | #40 (permalink) |
Member: 23420 Status: Offline Thanks Meter: 3,080 | New Update for SRS Server to version 0.9.46 Direct Unlock, Imei Repair, Usercode Reset: - Samsung GT M2510 - Samsung GT M2513 - Samsung GT S5230 (star) - Samsung GT S5233 (star) For unlocking samsung star you need an E210 Dual Cable (USB+RJ45) Unlock Process takes about 2 minutes Instructions for S5230/S5233 unlock - power on phone - connect both USB and RJ45 cable - Select modemport, and Comport in client - Press Direct unlock - Wait till phone restart - Press Direct unlock again Now your phone is unlocked / unfreezed Now SRS Server supports 945 Models ! Make sure to download latest installer from www.UnlockSamsungOnline.com you can discuss this update here: http://forum.gsmhosting.com/vbb/showthread.php?t=807683 This is a free update for all SRSPRO users, Enjoy btw did you know you can also use other boxes as interface to SRS Server so use your old box, and cables to unlock latest models online. |
08-16-2009, 21:06 | #41 (permalink) |
Member: 23420 Status: Offline Thanks Meter: 3,080 | Please update to 0.9.47 (download from www.UnlockSamsungOnline.com) this new version contains bugfix for server communication. |
08-26-2009, 20:32 | #43 (permalink) |
Member: 23420 Status: Offline Thanks Meter: 3,080 | SRS Server Updated to version 0.9.48 - Improved S5230/S5233 Unlock. - Added port selector Normal/Fast speed (for fast e2p reading) - Added Samsung I637 BlackJack Unlock/Code Read. - Added samsung C3610 / C3610C E2P Reading. - Implemented new Process log. - Fixed bug in E2P reading. - Fixed several small bugs in functionality. - Updated server, system is much faster now. Make sure you download the latest version from http://www.UnlockSamsungOnline.com/files/samsung.zip Now when you use an other FTDI box as interface to the server you can also work at High Speed E2P mode. Best Regards... Team UnlockSamsungOnline |
08-27-2009, 10:01 | #44 (permalink) |
Member: 23420 Status: Offline Thanks Meter: 3,080 | we discovered a bug in the latest version, the port speed selector was not working correct, we fixed this issue in version 0.9.49 in case you get an error in NAND reading on S5230/S5233 then select mode Normal instead of the preselected mode Fast latest update you can get from http://www.UnlockSamsungOnline.com/files/samsung.zip |
08-27-2009, 13:47 | #45 (permalink) |
Freak Poster Join Date: Apr 2003 Age: 44
Member: 26577 Status: Offline Thanks Meter: 29 | Please correct the link mr ssa! I have downloaded the new installer from the link in your previous post, but it is still the older version 0.9.48 not the 49. And the older version is not working. |
FULL = installation and latest update for UNIVERSAL BOX _ NO NEED INTERNET TO UPDATE | HZZORY4GSM | Universalbox | 0 | 10-04-2008 06:07 |
Chill out this summer with cool Infinity Updates .... See this latest update !! | Infinity-Box | Main Sales Section | 0 | 05-12-2007 13:40 |
Siemens Clip...Latest Update | Networkunlock | Griffin | 15 | 09-19-2003 13:02 |
send me latest update by WRAY 5.3 urgently PLSS | --==Dixon==-- | BF, BG, TH, BHx Series | 10 | 10-04-2002 22:32 |
