10-07-2010, 15:36 | #1 (permalink) |
Freak Poster Join Date: May 2000 Location: crete,greece
Member: 1400 Status: Offline Thanks Meter: 77 | Samsung B7330 unlocked succesfully!!! [Solved] Setting testmode... 4:33:27 - OMAP TESTMODE: DONE 4:33:27 - Reading Phonedata 4:33:30 - Firmware: JC1B7330XXJC1 4:33:30 - Imei: 3539xxxxxxxxx 4:33:31 - Chipset: 7225A-SNCAOWZM-1235 4:33:31 - MSL Addr: R4XSC07327 4:33:32 - Unlocking... 4:33:33 - Leaving Testmode 4:33:33 - Unlock Done... If phone asks for a code enter 00000000 -- Operation done in 14 seconds -- Many thanks to SRS team and especially to ssa for providing best support!!! |
The Following 4 Users Say Thank You to spawoolm For This Useful Post: |
10-13-2010, 11:15 | #3 (permalink) |
No Life Poster Join Date: Feb 2003 Location: Inside CPU Age: 43
Member: 23420 Status: Offline Thanks Meter: 3,080 | easy... get an SRS account - Unlock Samsung Online - Remote Unlock Server EN - Samsung Simlock Removal - www.UnlockSamsungOnline.com download latest clients from the website install software follow instruction in the client unlocking this phone only takes a few seconds |
The Following User Says Thank You to ssa For This Useful Post: |
10-14-2010, 10:33 | #6 (permalink) |
Junior Member Join Date: Oct 2010
Member: 1416558 Status: Offline Thanks Meter: 3 | How to set USB Debugging?? In my firmware there is not option Application settings... someone can help me??? I can't connect to srs server........:confu sed: |
The Following User Says Thank You to baccomatto For This Useful Post: |
10-14-2010, 15:40 | #8 (permalink) |
Member: 1400 Status: Offline Thanks Meter: 77 | Assuming that you are connected to the server,you need the drivers installed for the phone.Then press *#9090# and choose option 2.Then *#7284# and choose modem.Phone will restart.Choose auto from com port.Then you are ready to press direct unlock. |
The Following User Says Thank You to spawoolm For This Useful Post: |
10-14-2010, 23:05 | #9 (permalink) | |
Member: 1416558 Status: Offline Thanks Meter: 3 | Quote:
suggestions?? | |
10-14-2010, 23:48 | #10 (permalink) | |
10-15-2010, 17:56 | #13 (permalink) | |
-------- New Session 14/10/2010 19:50:43 Version: 10.0.26 Phone: B7330 Ports: C:6 M:5 User:SRS016779 -------- Rescanning ports... Detected COM1 - STATUS: READY (COM) Detected COM5 - STATUS: READY (MODEM) Detected COM6 - STATUS: READY (COM) -- Operation done in 2 seconds -- -------- New Session 14/10/2010 19:51:12 Version: 10.0.26 Phone: B7330 Ports: C:6 M:5 User:SRS016779 -------- Communication Error: PCOM001 Possible Causes: - Wrong port selected. (press RESCAN) - Samsung Drivers not installed - Phone not in PC-Studio mode Also check when your using a serial cable, if there is an connector for a 9 volt battery on the cable, in that case you MUST connect the battery to the cable (red/black wire with clip) -- Operation done in 17 seconds -- -------- New Session 14/10/2010 22:18:27 Version: 10.0.26 Phone: B7330 Ports: C:6 M:5 User:SRS016779 -------- Rescanning ports... Detected COM1 - STATUS: READY (COM) Detected COM5 - STATUS: READY (MODEM) Detected COM6 - STATUS: READY (COM) -- Operation done in 2 seconds -- -------- New Session 14/10/2010 22:18:50 Version: 10.0.26 Phone: B7330 Ports: C:6 M:5 User:SRS016779 -------- Communication Error: PCOM001 Possible Causes: - Wrong port selected. (press RESCAN) - Samsung Drivers not installed - Phone not in PC-Studio mode Also check when your using a serial cable, if there is an connector for a 9 volt battery on the cable, in that case you MUST connect the battery to the cable (red/black wire with clip) -- Operation done in 17 seconds -- -------- New Session 14/10/2010 22:19:18 Version: 10.0.26 Phone: B7330 Ports: C:5 M:5 User:SRS016779 -------- Communication Error: PCOM001 Possible Causes: - Wrong port selected. (press RESCAN) - Samsung Drivers not installed - Phone not in PC-Studio mode Also check when your using a serial cable, if there is an connector for a 9 volt battery on the cable, in that case you MUST connect the battery to the cable (red/black wire with clip) -- Operation done in 17 seconds -- -------- New Session 14/10/2010 22:19:46 Version: 10.0.26 Phone: B7330 Ports: C:6 M:5 User:SRS016779 -------- Communication Error: PCOM001 Possible Causes: - Wrong port selected. (press RESCAN) - Samsung Drivers not installed - Phone not in PC-Studio mode Also check when your using a serial cable, if there is an connector for a 9 volt battery on the cable, in that case you MUST connect the battery to the cable (red/black wire with clip) -- Operation done in 17 seconds -- -------- New Session 14/10/2010 22:26:13 Version: 10.0.26 Phone: B7330 Ports: C:6 M:AUTO User:SRS016779 -------- Rescanning ports... Detected COM1 - STATUS: READY (COM) Detected COM5 - STATUS: READY (COM) Detected COM6 - STATUS: READY (COM) -- Operation done in 1 seconds -- -------- New Session 14/10/2010 22:26:33 Version: 10.0.26 Phone: B7330 Ports: C:6 M:AUTO User:SRS016779 -------- Communication Error: PCOM001 Possible Causes: - Wrong port selected. (press RESCAN) - Samsung Drivers not installed - Phone not in PC-Studio mode Also check when your using a serial cable, if there is an connector for a 9 volt battery on the cable, in that case you MUST connect the battery to the cable (red/black wire with clip) -- Operation done in 17 seconds -- -------- New Session 14/10/2010 22:35:27 Version: 10.0.26 Phone: B7330 Ports: C:6 M:AUTO User:SRS016779 -------- Communication Error: PCOM001 Possible Causes: - Wrong port selected. (press RESCAN) - Samsung Drivers not installed - Phone not in PC-Studio mode Also check when your using a serial cable, if there is an connector for a 9 volt battery on the cable, in that case you MUST connect the battery to the cable (red/black wire with clip) -- Operation done in 16 seconds -- -------- New Session 14/10/2010 22:39:33 Version: 10.0.26 Phone: B7330 Ports: C:6 M:AUTO User:SRS016779 -------- Locating Remote server... Getting data from server. -- Operation done in 10 seconds -- -------- New Session 14/10/2010 22:43:16 Version: 10.0.26 Phone: B7330 Ports: C:6 M:AUTO User:SRS016779 -------- Communication Error: PCOM001 Possible Causes: - Wrong port selected. (press RESCAN) - Samsung Drivers not installed - Phone not in PC-Studio mode Also check when your using a serial cable, if there is an connector for a 9 volt battery on the cable, in that case you MUST connect the battery to the cable (red/black wire with clip) -- Operation done in 16 seconds -- -------- New Session 14/10/2010 22:45:15 Version: 10.0.26 Phone: B7330 Ports: C:6 M:AUTO User:SRS016779 -------- Communication Error: PCOM001 Possible Causes: - Wrong port selected. (press RESCAN) - Samsung Drivers not installed - Phone not in PC-Studio mode Also check when your using a serial cable, if there is an connector for a 9 volt battery on the cable, in that case you MUST connect the battery to the cable (red/black wire with clip) -- Operation done in 17 seconds -- -------- New Session 14/10/2010 22:55:01 Version: 10.0.26 Phone: B7330 Ports: C:1 M:AUTO User:SRS016779 -------- Rescanning ports... Detected COM1 - STATUS: READY (COM) -- Operation done in 1 seconds -- -------- New Session 14/10/2010 22:55:28 Version: 10.0.26 Phone: B7330 Ports: C:6 M:AUTO User:SRS016779 -------- Rescanning ports... Detected COM1 - STATUS: READY (COM) Detected COM5 - STATUS: READY (COM) Detected COM6 - STATUS: READY (COM) -- Operation done in 1 seconds -- -------- New Session 14/10/2010 22:55:49 Version: 10.0.26 Phone: B7330 Ports: C:6 M:AUTO User:SRS016779 -------- Communication Error: PCOM001 Possible Causes: - Wrong port selected. (press RESCAN) - Samsung Drivers not installed - Phone not in PC-Studio mode Also check when your using a serial cable, if there is an connector for a 9 volt battery on the cable, in that case you MUST connect the battery to the cable (red/black wire with clip) -- Operation done in 17 seconds -- -------- New Session 14/10/2010 22:56:08 Version: 10.0.26 Phone: B7330 Ports: C:6 M:AUTO User:SRS016779 -------- Communication Error: PCOM001 Possible Causes: - Wrong port selected. (press RESCAN) - Samsung Drivers not installed - Phone not in PC-Studio mode Also check when your using a serial cable, if there is an connector for a 9 volt battery on the cable, in that case you MUST connect the battery to the cable (red/black wire with clip) -- Operation done in 17 seconds -- -------- New Session 14/10/2010 22:56:35 Version: 10.0.26 Phone: B7330 Ports: C:6 M:AUTO User:SRS016779 -------- Communication Error: PCOM001 Possible Causes: - Wrong port selected. (press RESCAN) - Samsung Drivers not installed - Phone not in PC-Studio mode Also check when your using a serial cable, if there is an connector for a 9 volt battery on the cable, in that case you MUST connect the battery to the cable (red/black wire with clip) -- Operation done in 17 seconds -- -------- New Session 14/10/2010 23:21:08 Version: 10.0.26 Phone: B7330 Ports: C:6 M:AUTO User:SRS016779 -------- Communication Error: PCOM001 Possible Causes: - Wrong port selected. (press RESCAN) - Samsung Drivers not installed - Phone not in PC-Studio mode Also check when your using a serial cable, if there is an connector for a 9 volt battery on the cable, in that case you MUST connect the battery to the cable (red/black wire with clip) -- Operation done in 16 seconds -- -------- New Session 14/10/2010 23:22:04 Version: 10.0.26 Phone: B7330 Ports: C:6 M:AUTO User:SRS016779 -------- Communication Error: PCOM001 Possible Causes: - Wrong port selected. (press RESCAN) - Samsung Drivers not installed - Phone not in PC-Studio mode Also check when your using a serial cable, if there is an connector for a 9 volt battery on the cable, in that case you MUST connect the battery to the cable (red/black wire with clip) -- Operation done in 16 seconds -- -------- New Session 14/10/2010 23:48:21 Version: 10.0.26 Phone: B7330 Ports: C:6 M:AUTO User:SRS016779 -------- Rescanning ports... Detected COM1 - STATUS: READY (COM) Detected COM5 - STATUS: READY (COM) Detected COM6 - STATUS: READY (COM) -- Operation done in 1 seconds -- -------- New Session 14/10/2010 23:48:45 Version: 10.0.26 Phone: B7330 Ports: C:6 M:AUTO User:SRS016779 -------- Communication Error: PCOM001 Possible Causes: - Wrong port selected. (press RESCAN) - Samsung Drivers not installed - Phone not in PC-Studio mode Also check when your using a serial cable, if there is an connector for a 9 volt battery on the cable, in that case you MUST connect the battery to the cable (red/black wire with clip) -- Operation done in 18 seconds -- -------- New Session 14/10/2010 23:49:14 Version: 10.0.26 Phone: B7330 Ports: C:6 M:AUTO User:SRS016779 -------- Communication Error: PCOM001 Possible Causes: - Wrong port selected. (press RESCAN) - Samsung Drivers not installed - Phone not in PC-Studio mode Also check when your using a serial cable, if there is an connector for a 9 volt battery on the cable, in that case you MUST connect the battery to the cable (red/black wire with clip) -- Operation done in 17 seconds -- -------- New Session 14/10/2010 23:49:40 Version: 10.0.26 Phone: B7330 Ports: C:6 M:AUTO User:SRS016779 -------- Communication Error: PCOM001 Possible Causes: - Wrong port selected. (press RESCAN) - Samsung Drivers not installed - Phone not in PC-Studio mode Also check when your using a serial cable, if there is an connector for a 9 volt battery on the cable, in that case you MUST connect the battery to the cable (red/black wire with clip) -- Operation done in 19 seconds -- | |
10-15-2010, 19:14 | #14 (permalink) |
No Life Poster Join Date: Apr 2001
Member: 3941 Status: Offline Thanks Meter: 636 | Hi, Try setting your port number manually without using the 'rescan' button: Samsung Remote unlock Server >> Manuals >> general >> set-omap2-modem Best regards, |
10-15-2010, 19:38 | #15 (permalink) | |
someone of srs can help me again? i have done nothing with 3 credits.... | |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
FAQ about unlock n0kia | man0n | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 11-29-2010 19:06 |
