03-10-2010, 14:14 | #1 (permalink) |
Freak Poster Join Date: Mar 2007 Location: ARGENTINA
Member: 472354 Status: Offline Sonork: 1580747 Thanks Meter: 67 | Warning: Crypto block not found m2510 I try to read codes with sim inside and i have this problem: 10:11:03 - SET TESTMODE DONE 10:11:03 - IMEI: 35302503****** 10:11:04 - FIRMWARE: M2510URIE (September R) 10:11:06 - MSL ADDRESS: RPISB59722 10:11:07 - ADVANCED MSL DETECTED BYPASSING... 10:11:47 - WARNING: CRYPTO BLOCK NOT FOUND 10:11:47 - MSL BYPASS: FAILED The some problem with direct unlock. Can you solve this? B.R. SEBAELPOTRO! sorry for my bad english I speek only spanish |
03-10-2010, 15:20 | #2 (permalink) | |
No Life Poster Join Date: Feb 2003 Location: Inside CPU Age: 43
Member: 23420 Status: Offline Thanks Meter: 3,080 | Quote:
then we can analyse it btw try also by selecting m2520 as model | |
The Following User Says Thank You to ssa For This Useful Post: |
03-10-2010, 15:39 | #3 (permalink) |
Member: 472354 Status: Offline Sonork: 1580747 Thanks Meter: 67 | Whit m2520 model the some error crypto block not found This is the dump folder http://www.megaupload.com/?d=J4JJIA7I And the imei is: 35401303314071/1 Last edited by sebaelpotro; 03-10-2010 at 15:44. |
03-10-2010, 15:53 | #4 (permalink) |
Member: 472354 Status: Offline Sonork: 1580747 Thanks Meter: 67 | This is the original LOG Booting Trident Phone... 11:53:09 - SET TESTMODE DONE 11:53:10 - IMEI: 35401303314071 11:53:11 - FIRMWARE: M2510VCIE (May 2009) 11:53:13 - MSL ADDRESS: RS5SB33001 11:53:14 - ADVANCED MSL DETECTED BYPASSING... 11:53:54 - WARNING: CRYPTO BLOCK NOT FOUND 11:53:54 - MSL BYPASS: FAILED |
03-10-2010, 16:23 | #5 (permalink) |
Member: 23420 Status: Offline Thanks Meter: 3,080 | I checked it, and found a strange issue, will make an update for this so you can re-test Last edited by ssa; 03-10-2010 at 16:39. |
03-10-2010, 16:45 | #6 (permalink) |
Member: 23420 Status: Offline Thanks Meter: 3,080 | Press in the client ALT+R to relead phone data then shutdown client, and restart, now try again there was some security change in your firmware but hope it will be fine now |
The Following 2 Users Say Thank You to ssa For This Useful Post: |
Alcatel S120 Flash File not found in support [SOLVED] | surin | PolarBox 3 | 16 | 03-30-2010 10:57 |
WARNING: Apple blocks downgrade to OS 3.0 or 3.0.1 | TheTelecomShop | iPhone 2 / iPhone 3G / iPhone 3GS | 3 | 09-13-2009 13:36 |
i still not use it apple not found and license not found | ABDULLAHI MUHD | FuriousGold | 2 | 06-16-2009 12:57 |
CRYPTO-BOX not found or contains not valid data | Dayratel | NSPRO | 2 | 05-11-2006 13:09 |
