question about TMA with my Cyclone box [ANSWERED] hello all, I use all the time the TMA with my cyclone box, and use the RJ45 cable and put it in the yellow adapter of cyclone (adapter v1), but from some time this don't work and I use now RJ48 (10 pin) adapter in my yellow adapter, and have Problem of peak power (USB), this is TMA probleme, anny one have idea for repair this or need change one all the 3 month ? Best Regards, JAVA Good. |
Can you Describe more Please TMA is working with Cycolone 100% |
TMA don't work now with RJ45, only with RJ48 with peak power (USB) on my computer anny solution or TMA died ? Best Regards, JAVA Good. |
anny help pls, or crap product, or bad publicity ? Best Regards, JAVA Good. |
1 Attachment(s) anny one have solution or can help me pls ? I have the ligth power on if I use RJ45 cable or RJ48 cable, and only RJ48 cable work with my box ? Attachment 222738 anny help pls, Best Regards, JAVA Good. |
1 Attachment(s) hello all, my TMA don't work and after search on the forum I'am not sure about value of the fuse of my TMA, any one can confirme or correct me pls ? Attachment 224091 Best Regards, JAVA Good. |
1 Attachment(s) big tks for the team for all your invisible reply and help, and an other big tks for some unlocker like Alex for reply and help, I desolder all cable and resolder again and change the fuse with an other one, Attachment 224611 and my TMA now work, not perfectly but work fine because it's a GPG Money cable, Best Regards, JAVA Good. |
Dear Sir, sorry for the delay reponse. pls noted that TMA and cyclone can be connected with the RJ45 and RJ48. br winnie |
tks for your reply, so can you tell me why if I use the RJ45 or RJ48 cable I have the same led on PCB power on ? in the first time, it's not like now, maybe need change some think, if you can help me pls, maybe next time I buy other one, but I need understand, I don't use it many time, Best Regards, JAVA Good. |
pls noted that RJ45 can be used with usb and Jaf cable, but RJ48 can be used the Jaf cable without usb. regarding to the same led powered on, pls let me know which led powered on, 8pin or 10pin? br winnie |
@ verry nice information and tks for the reply : Quote:
and have a question pls, maybe it's not the section, but the team I think can understand, can use the TMA with MTbox with out anny probleme pls ? Best Regards, JAVA Good. |
You can but you must not connect the usb cable when working with the MT-Box BR Alex |
tks for all, and I forget Alex, tks for your help on TMA, my probleme is solved with desolder and solder again the cable, Best Regards, JAVA Good. |
You are always welcome my friend :) BR Alex |
