Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > BB5BOX Products > BB5KING for (BB5BOX)
Old 11-18-2008, 19:09   #1 (permalink)
.:bono:.'s Avatar
Member: 96141
Thanks Meter: 184
6300 can't repair FFFFFFFFFFFFFFF
Hi all
here is log, i tryed with ufs and jaf, also with all bbking versions
18/11/2008 18:58:13 UFS box version: 208
18/11/2008 18:58:13 UFS box SN: xxxx
18/11/2008 18:58:25 Searching for phone ...
18/11/2008 18:58:28 Phone found on FBUS interface
18/11/2008 18:58:28 Reading phone info ...
18/11/2008 18:58:28 Type: RM-217
18/11/2008 18:58:28 Version: V_06.60_21-05-08_RM-217_(c)_Nokia.
18/11/2008 18:58:28 IMEI: 352042027070933
18/11/2008 18:58:29 SP LOCK status:
18/11/2008 18:58:29 Config Key: FFFFFFFFFFFFFFFF
18/11/2008 18:58:29 Block 1: CLOSED Type 5 Data: 00101F
18/11/2008 18:58:29 Key counter: 0/3
18/11/2008 18:58:29 Cable counter: 0/10
18/11/2008 18:58:29 Read Phone Info OK
18/11/2008 18:58:29 Operation time: 00:20.
18/11/2008 18:58:29 Successfully done.
18/11/2008 18:58:44 UFS box version: 208
18/11/2008 18:58:44 UFS box SN: 5515
18/11/2008 18:58:56 Searching for phone ...
18/11/2008 18:58:58 Phone found on FBUS interface
18/11/2008 18:58:58 Reading phone info ...
18/11/2008 18:58:58 Type: RM-217
18/11/2008 18:58:59 Version: V_06.60_21-05-08_RM-217_(c)_Nokia.
18/11/2008 18:58:59 IMEI: 352042027070933
18/11/2008 18:58:59 SP LOCK status:
18/11/2008 18:58:59 Config Key: FFFFFFFFFFFFFFFF
18/11/2008 18:58:59 Block 1: CLOSED Type 5 Data: 00101F
18/11/2008 18:58:59 Key counter: 0/3
18/11/2008 18:58:59 Cable counter: 0/10
18/11/2008 18:58:59 Read Phone Info OK
18/11/2008 18:58:59 Searching for phone ...
18/11/2008 18:59:02 Phone found on FBUS interface
18/11/2008 18:59:02 Reading phone info ...
18/11/2008 18:59:03 Reading PM Field 308 Subfield 1 with length 8192 bytes
18/11/2008 18:59:18 Saving to file: RM-217_352042027070933_Locked_Keycnt_0_Fbuscnt_0__V_0 6.60_21-05-08_RM-217_(c)_Nokia.__18_11_2008__18_59_18.bin
18/11/2008 18:59:18 PM308 backup OK
18/11/2008 18:59:18 Searching for UFS box ...
18/11/2008 18:59:18 UFS box detected
18/11/2008 18:59:22 UFS box version: 208
18/11/2008 18:59:22 UFS box SN: xxxx
18/11/2008 18:59:22 UFS box UFSBOX_BB5_FLASH_bb5challenge ...
18/11/2008 18:59:36 0x11130153
18/11/2008 18:59:36 ERROR!
18/11/2008 18:59:36 Operation time: 00:56.
18/11/2008 18:59:36 Done with error(s).
Old 11-18-2008, 19:25   #2 (permalink)
Member: 26041
Thanks Meter: 160
hi friend
Use Jaf Flasher as interface and try to repaire SL again.
Jaf more stable.
Best Regards.
Old 11-18-2008, 19:34   #3 (permalink)
.:bono:.'s Avatar
Member: 96141
Thanks Meter: 184
Originally Posted by .:RoMeO:. View Post
hi friend
Jaf more stable.
Best Regards.
i told u that i used ufs and jaf too
any other solution?
br
Old 11-18-2008, 23:02   #4 (permalink)
sharmin's Avatar
Member: 222009
Sonork: 100.1576751
Thanks Meter: 435
can u pls tell which version r u using of bb5 king to repair sl zone
have u tried with the last version ??? Nokia_BB5KING_v105.zip
Old 11-19-2008, 00:26   #5 (permalink)
gecata's Avatar
Member: 16994
Thanks Meter: 157
Originally Posted by .:bono:. View Post
Hi all
Try with v. 1.03. It should work, but You will have another problem - phone will auto power down. I also have one 6300 with this problem and not found solution till now. May be in another version this will be fixed!
Good luck!
Old 11-19-2008, 08:13   #6 (permalink)
Member: 26041
Thanks Meter: 160
any other solution?
br
hi friend
please try to make check,backup crt via jaf program if u can make these features then your cable 100 % else problem from cable .
use another cable and try to unlock it again.
Best Regards.
Old 11-19-2008, 19:10   #7 (permalink)
.:bono:.'s Avatar
Member: 96141
Thanks Meter: 184
JAF box ATmega firmware version: 1B0
SP LOCK status:
Read Phone Info OK
Saving to file: RM-217_352042027070933_Locked_Keycnt_0_Fbuscnt_0__V_0 6.60_21-05-08_RM-217_(c)_Nokia.__19_11_2008__19_04_33.bin
PM308 backup OK
Searching for JAF box ...
JAF box detected
Initialize JAF box ...
JAF box JAFBOX_BB5_FLASH_bb5challenge ...
Error. 0x10130103
ERROR!
Operation time: 00:29.
Done with error(s).
Thread phone exit.
Old 11-19-2008, 19:15   #8 (permalink)
Kashif Khan's Avatar
Member: 88016
Thanks Meter: 314
Its looks your cable is faulty.
i know you will write here that my cable is working well, open your cable and put right resistor
and post the result.
kashif Khan
Old 11-25-2008, 19:22   #9 (permalink)
.:bono:.'s Avatar
Member: 96141
Thanks Meter: 184
kashif Khan
yes, yes and yes
it was a cable problem, i phone sucsesfully repaired with universal fbus cable
SP LOCK status:
Read Phone Info OK
Saving to file: RM-217_352042027070933_Locked_Keycnt_0_Fbuscnt_0__V_0 6.60_21-05-08_RM-217_(c)_Nokia.__25_11_2008__19_06_30.bin
PM308 backup OK
JAF box detected
ASIC ID: 000000010000022600010006010C192101001101
HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
ROM ID: 191EC665DFAAF68F
bb5king SW v1.07
Sending loader...
Rap3Gv3 selected.
BB5_FLASH_CMTbootload
JAF CMT Boot Ready
Hello ok
ok
Get card info ...
Verify card OK
Get card info ...
Verify card OK
Hello ok
Hello ok
PM send.
Test call...
cpsr - 0x0000001F
p15_1 - 0x0005307F
p15_2 - 0x0005117F
p15_3 - 0x0005317F
esn_init ret - 0x00000001, <tmp_buff2> - 0x00000001
esn_read ret - 0x00000001, <tmp_buff2> - 0x00000001
Normal BB5 found - 0x0002B400
LR - FFFF3688, param - 0x03, size - 0x00
UpdSLock - 0x00000001
ret - 0x01, <tmp_buff2> - 0x23
PM_308 CRC - 0x00090131
Reciving PM
Hello ok
PM buff recived
After unlock.
Writting PM Field 308 Subfield 1 with length 8192 bytes
Reset phone ...
PM Field 308 Subfield 1 written OK
Operation time: 01:08.
Successfully done.
Thread phone exit.
25/11/2008 19:07:43 JAF box ATmega firmware version: 1B0
25/11/2008 19:07:57 Searching for phone ...
25/11/2008 19:07:57 Phone found on FBUS interface
25/11/2008 19:07:57 Reading phone info ...
25/11/2008 19:07:57 Type: RM-217
25/11/2008 19:07:57 Version: V_06.60_21-05-08_RM-217_(c)_Nokia.
25/11/2008 19:07:57 IMEI: 352042027070933
25/11/2008 19:07:58 SP LOCK status:
25/11/2008 19:07:58 Config Key: 2440700000000000
25/11/2008 19:07:58 Block 1: OPEN Type 5 Data: FFFFFF
25/11/2008 19:07:58 Block 2: OPEN Type 5 Data: FFFFFF
25/11/2008 19:07:58 Block 3: OPEN Type 5 Data: FFFFFF
25/11/2008 19:07:58 Block 4: OPEN Type 5 Data: FFFFFF
25/11/2008 19:07:58 Block 5: OPEN Type 5 Data: FFFFFF
25/11/2008 19:07:58 Block 6: OPEN Type 5 Data: FFFFFF
25/11/2008 19:07:58 Block 7: OPEN Type 5 Data: FFFFFF
25/11/2008 19:07:58 Key counter: 0/3
25/11/2008 19:07:58 Cable counter: 0/10
25/11/2008 19:07:58 Read Phone Info OK
25/11/2008 19:07:58 Operation time: 00:16.
25/11/2008 19:07:58 Successfully done.
thank u
br
Old 11-27-2008, 13:35   #10 (permalink)
Member: 88016
Thanks Meter: 314
Just press the thanx button
why smartclip can't repair pds, unlock, repair imei to 0A.52 Boot V3R !!!??? richiricherd Smart-Clip 6 03-11-2010 07:39
Can't Repair SP Data BB5 King useless for using SL Repairing. mujahid_ali BB5KING for (BB5BOX) 6 11-27-2008 20:29
nokia 6300 can't repair FFFFFFFFFFFFFFF msantar BB5KING 1 11-26-2008 16:59
v3 r374 repair ok can't repair v3r r4515 xiaoyuz Motorola P2K (USB-Smart) 0 06-20-2006 08:48
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.24268 seconds with 8 queries
