11-05-2008, 11:06 | #1 (permalink) |
Insane Poster Join Date: Oct 2005 Location: Lelystad, Netherlands
Member: 192880 Status: Offline Thanks Meter: 35 | UFS upgrade 2.8 (208) solution. Solve Problem with BB5king soft shutdown. To upgrade your ufs to firmware 2.8 do the following: 1. Download this soft: http://id.mxkey.biz/downloads.php?ca...download_id=29 2. Install it. 3. After install plug your ufs device. 4. Start program 5. At the left top select your ufs device and click connect 6. An automatic prompt ask you if you want to upgrade your firmware 7. Confirm it. After this you can use your box with BB5King soft. |
The Following 17 Users Say Thank You to serjer For This Useful Post: |
11-05-2008, 12:04 | #2 (permalink) |
No Life Poster Join Date: Dec 2003 Location: Wien,Austria
Member: 45985 Status: Offline Thanks Meter: 96 | Done it and ufs fw is 2.8 but i still canīt use it with bb5king If i use ufs as interface i get Code: 05.11.2008 11:55:26 0x11010201 05.11.2008 11:55:26 0x13010200 05.11.2008 11:55:26 Operation time: 00:00. 05.11.2008 11:55:26 Done with error(s). Code: 05.11.2008 11:56:04 JAF box ATmega firmware version: 1B0 05.11.2008 11:56:08 Searching for phone ... 05.11.2008 11:56:08 Phone found on FBUS interface 05.11.2008 11:56:08 Reading phone info ... 05.11.2008 11:56:08 Type: RM-217 05.11.2008 11:56:08 Version: V_06.60_21-05-08_RM-217_(c)_Nokia. 05.11.2008 11:56:08 IMEI: 359811013730400 05.11.2008 11:56:09 SP LOCK status: 05.11.2008 11:56:09 Config Key: 2320300000000000 05.11.2008 11:56:09 Block 1: CLOSED Type 5 Data: 23203F 05.11.2008 11:56:09 Key counter: 0/3 05.11.2008 11:56:09 Cable counter: 0/10 05.11.2008 11:56:09 Read Phone Info OK 05.11.2008 11:56:09 Operation time: 00:06. 05.11.2008 11:56:09 Successfully done. 05.11.2008 11:56:23 JAF box ATmega firmware version: 1B0 05.11.2008 11:56:27 Searching for phone ... 05.11.2008 11:56:27 Phone found on FBUS interface 05.11.2008 11:56:27 Reading phone info ... 05.11.2008 11:56:27 Type: RM-217 05.11.2008 11:56:27 Version: V_06.60_21-05-08_RM-217_(c)_Nokia. 05.11.2008 11:56:27 IMEI: 359811013730400 05.11.2008 11:56:28 SP LOCK status: 05.11.2008 11:56:28 Config Key: 2320300000000000 05.11.2008 11:56:28 Block 1: CLOSED Type 5 Data: 23203F 05.11.2008 11:56:28 Key counter: 0/3 05.11.2008 11:56:28 Cable counter: 0/10 05.11.2008 11:56:28 Read Phone Info OK 05.11.2008 11:56:29 JAF box ATmega firmware version: 1B0 05.11.2008 11:56:31 Searching for phone ... 05.11.2008 11:56:31 Phone found on FBUS interface 05.11.2008 11:56:31 Reading phone info ... 05.11.2008 11:56:32 Reading PM Field 308 Subfield 1 with length 8192 bytes 05.11.2008 11:56:35 Saving to file: RM-217_359811013730400_Locked_Keycnt_0_Fbuscnt_0__V_06.60_21-05-08_RM-217_(c)_Nokia.__05_11_2008__11_56_35.bin 05.11.2008 11:56:35 PM308 backup OK 05.11.2008 11:56:35 Searching for JAF box ... 05.11.2008 11:56:35 JAF box detected 05.11.2008 11:56:36 JAF box ATmega firmware version: 1B0 05.11.2008 11:56:36 Initialize JAF box ... 05.11.2008 11:56:36 Sending loader... 05.11.2008 11:56:36 Rap3Gv2 selected. 05.11.2008 11:56:36 JAF box JAFBOX_BB5_FLASH_bb5challenge ... 05.11.2008 11:56:37 05.11.2008 11:56:38 ASIC ID: 000000010000022600010006010C192101001101 05.11.2008 11:56:38 HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 05.11.2008 11:56:38 ROM ID: 191EC665DFAAF68F 05.11.2008 11:56:38 JAF CMT Boot Ready 05.11.2008 11:56:38 05.11.2008 11:56:39 Hello ok 05.11.2008 11:56:39 ok 05.11.2008 11:56:53 Hello ok 05.11.2008 11:56:53 Hello ok 05.11.2008 11:56:53 PM send. 05.11.2008 11:56:54 Test call... 05.11.2008 11:56:54 cpsr - 0x0000001F 05.11.2008 11:56:54 p15_1 - 0x0005307F 05.11.2008 11:56:54 p15_2 - 0x0005117F 05.11.2008 11:56:54 p15_3 - 0x0005317F 05.11.2008 11:56:54 esn_init ret - 0x00000001, <tmp_buff2> - 0x00000001 05.11.2008 11:56:54 esn_read ret - 0x00000001, <tmp_buff2> - 0x00000001 05.11.2008 11:56:54 Normal BB5 found - 0x0002B400 05.11.2008 11:56:55 LR - FFFF3688, param - 0x03, size - 0x00 05.11.2008 11:56:55 UpdSLock - 0x00000001 05.11.2008 11:56:55 ret - 0x01, <tmp_buff2> - 0x23 05.11.2008 11:56:55 PM_308 CRC - 0x0018EF1A 05.11.2008 11:56:55 Reciving PM 05.11.2008 11:56:57 Hello ok 05.11.2008 11:56:57 PM buff recived 05.11.2008 11:56:57 After unlock. 05.11.2008 11:56:58 JAF box ATmega firmware version: 1B0 05.11.2008 11:57:00 Searching for phone ... 05.11.2008 11:57:00 Phone found on FBUS interface 05.11.2008 11:57:01 Writting PM Field 308 Subfield 1 with length 8192 bytes 05.11.2008 11:57:04 Reset phone ... 05.11.2008 11:57:07 PM Field 308 Subfield 1 written OK 05.11.2008 11:57:07 Operation time: 00:45. 05.11.2008 11:57:07 Successfully done. 05.11.2008 11:57:13 JAF box ATmega firmware version: 1B0 05.11.2008 11:57:17 Searching for phone ... 05.11.2008 11:57:17 Phone found on FBUS interface 05.11.2008 11:57:17 Reading phone info ... 05.11.2008 11:57:17 Type: RM-217 05.11.2008 11:57:17 Version: V_06.60_21-05-08_RM-217_(c)_Nokia. 05.11.2008 11:57:17 IMEI: 359811013730400 05.11.2008 11:57:19 SP LOCK status: 05.11.2008 11:57:19 Config Key: 2342000000000000 05.11.2008 11:57:19 Block 1: OPEN Type 5 Data: 23420F 05.11.2008 11:57:19 Block 2: OPEN Type 5 Data: 23594F 05.11.2008 11:57:19 Block 3: OPEN Type 5 Data: 23420F 05.11.2008 11:57:19 Block 4: OPEN Type 5 Data: 23594F 05.11.2008 11:57:19 Key counter: 0/3 05.11.2008 11:57:19 Cable counter: 0/10 05.11.2008 11:57:19 Read Phone Info OK 05.11.2008 11:57:19 Operation time: 00:07. 05.11.2008 11:57:19 Successfully done. br |
11-05-2008, 13:05 | #3 (permalink) |
No Life Poster Join Date: May 2007 Location: Algerie,Batna
Member: 508860 Status: Offline Sonork: 1613186 Thanks Meter: 224 | me to ufs 05.11.2008 11:55:26 0x11010201 05.11.2008 11:55:26 0x13010200 05.11.2008 11:55:26 Operation time: 00:00. 05.11.2008 11:55:26 Done with error(s). |
11-05-2008, 13:44 | #5 (permalink) |
Member: 45985 Status: Offline Thanks Meter: 96 | After updatig drivers,all is ok! Code: 05.11.2008 13:36:38 UFS box version: 206 05.11.2008 13:36:38 UFS box SN: 08 05.11.2008 13:36:42 Searching for phone ... 05.11.2008 13:36:44 Phone found on FBUS interface 05.11.2008 13:36:44 Reading phone info ... 05.11.2008 13:36:45 Type: RM-146 05.11.2008 13:36:45 Version: V_04.70_24-01-07_RM-146_(c)_Nokia. 05.11.2008 13:36:45 IMEI: 356959014093808 05.11.2008 13:36:46 SP LOCK status: 05.11.2008 13:36:46 Config Key: 2320300000000000 05.11.2008 13:36:46 Block 1: CLOSED Type 5 Data: 23203F 05.11.2008 13:36:46 Key counter: 0/3 05.11.2008 13:36:46 Cable counter: 0/10 05.11.2008 13:36:46 Read Phone Info OK 05.11.2008 13:36:46 Operation time: 00:12. 05.11.2008 13:36:46 Successfully done. 05.11.2008 13:36:56 UFS box version: 206 05.11.2008 13:36:56 UFS box SN: 08 05.11.2008 13:37:00 Searching for phone ... 05.11.2008 13:37:03 Phone found on FBUS interface 05.11.2008 13:37:03 Reading phone info ... 05.11.2008 13:37:03 Type: RM-146 05.11.2008 13:37:03 Version: V_04.70_24-01-07_RM-146_(c)_Nokia. 05.11.2008 13:37:04 IMEI: 356959014093808 05.11.2008 13:37:04 SP LOCK status: 05.11.2008 13:37:04 Config Key: 2320300000000000 05.11.2008 13:37:04 Block 1: CLOSED Type 5 Data: 23203F 05.11.2008 13:37:04 Key counter: 0/3 05.11.2008 13:37:04 Cable counter: 0/10 05.11.2008 13:37:04 Read Phone Info OK 05.11.2008 13:37:09 UFS box version: 206 05.11.2008 13:37:09 UFS box SN: 08 05.11.2008 13:37:11 Searching for phone ... 05.11.2008 13:37:13 Phone found on FBUS interface 05.11.2008 13:37:13 Reading phone info ... 05.11.2008 13:37:15 Reading PM Field 308 Subfield 1 with length 8192 bytes 05.11.2008 13:37:29 Saving to file: RM-146_356959014093808_Locked_Keycnt_0_Fbuscnt_0__V_04.70_24-01-07_RM-146_(c)_Nokia.__05_11_2008__13_37_29.bin 05.11.2008 13:37:29 PM308 backup OK 05.11.2008 13:37:29 Searching for UFS box ... 05.11.2008 13:37:29 UFS box detected 05.11.2008 13:37:33 UFS box version: 206 05.11.2008 13:37:33 UFS box SN: 08 05.11.2008 13:37:33 Sending loader... 05.11.2008 13:37:33 Rap3Gv2 selected. 05.11.2008 13:37:33 UFS box UFSBOX_BB5_FLASH_bb5challenge ... 05.11.2008 13:37:37 05.11.2008 13:37:37 ASIC ID: 000000010000022600010006010C192101001101 05.11.2008 13:37:37 HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 05.11.2008 13:37:37 ROM ID: 191EC665DFAAF68F 05.11.2008 13:37:37 UFS box UFSBOX_BB5_FLASH_CMTbootload ... 05.11.2008 13:37:37 UFSx CMT Boot Ready 05.11.2008 13:37:37 05.11.2008 13:37:41 Hello ok 05.11.2008 13:37:42 ok 05.11.2008 13:37:55 Hello ok 05.11.2008 13:37:58 Hello ok 05.11.2008 13:37:58 PM send. 05.11.2008 13:37:58 Test call... 05.11.2008 13:37:59 cpsr - 0x0000001F 05.11.2008 13:37:59 p15_1 - 0x0005307F 05.11.2008 13:37:59 p15_2 - 0x0005117F 05.11.2008 13:37:59 p15_3 - 0x0005317F 05.11.2008 13:37:59 esn_init ret - 0x00000001, <tmp_buff2> - 0x00000001 05.11.2008 13:37:59 esn_read ret - 0x00000001, <tmp_buff2> - 0x00000001 05.11.2008 13:38:00 Normal BB5 found - 0x0002B400 05.11.2008 13:38:00 LR - FFFF3688, param - 0x03, size - 0x00 05.11.2008 13:38:00 UpdSLock - 0x00000001 05.11.2008 13:38:00 ret - 0x01, <tmp_buff2> - 0x23 05.11.2008 13:38:00 PM_308 CRC - 0x00190309 05.11.2008 13:38:01 Reciving PM 05.11.2008 13:38:14 Hello ok 05.11.2008 13:38:14 PM buff recived 05.11.2008 13:38:14 After unlock. 05.11.2008 13:38:18 UFS box version: 206 05.11.2008 13:38:18 UFS box SN: 08 05.11.2008 13:38:20 Searching for phone ... 05.11.2008 13:38:22 Phone found on FBUS interface 05.11.2008 13:38:23 Writting PM Field 308 Subfield 1 with length 8192 bytes 05.11.2008 13:38:27 Reset phone ... 05.11.2008 13:38:32 PM Field 308 Subfield 1 written OK 05.11.2008 13:38:32 Operation time: 01:40. 05.11.2008 13:38:32 Successfully done. 05.11.2008 13:38:41 UFS box version: 206 05.11.2008 13:38:41 UFS box SN: 08 05.11.2008 13:38:45 Searching for phone ... 05.11.2008 13:38:48 Phone found on FBUS interface 05.11.2008 13:38:48 Reading phone info ... 05.11.2008 13:38:48 Type: RM-146 05.11.2008 13:38:48 Version: V_04.70_24-01-07_RM-146_(c)_Nokia. 05.11.2008 13:38:49 IMEI: 356959014093808 05.11.2008 13:38:51 SP LOCK status: 05.11.2008 13:38:51 Config Key: 2342000000000000 05.11.2008 13:38:51 Block 1: OPEN Type 5 Data: 23420F 05.11.2008 13:38:51 Block 2: OPEN Type 5 Data: 23594F 05.11.2008 13:38:51 Block 3: OPEN Type 5 Data: 23420F 05.11.2008 13:38:51 Block 4: OPEN Type 5 Data: 23594F 05.11.2008 13:38:51 Key counter: 0/3 05.11.2008 13:38:51 Cable counter: 0/10 05.11.2008 13:38:51 Read Phone Info OK 05.11.2008 13:38:51 Operation time: 00:13. 05.11.2008 13:38:51 Successfully done. |
11-05-2008, 13:56 | #6 (permalink) |
Member: 508860 Status: Offline Sonork: 1613186 Thanks Meter: 224 | the same problem 05.11.2008 11:55:26 0x11010201 05.11.2008 11:55:26 0x13010200 05.11.2008 11:55:26 Operation time: 00:00. 05.11.2008 11:55:26 Done with error(s). |
11-05-2008, 16:10 | #9 (permalink) |
No Life Poster Join Date: Aug 2004 Location: ISLAND Age: 54
Member: 80036 Status: Offline Thanks Meter: 25 | ASIC ID: 000000010000022600010006010C192101003000 HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 273F6D55DFAAF68F UFS box UFSBOX_BB5_FLASH_CMTbootload ... Error. 0x11130205 ERROR! Error. Cannot send boot. Operation time: 00:37. Done with error(s). Thread phone exit. SAME ERROR, NOTHING CHANGED |
11-05-2008, 16:22 | #10 (permalink) | |
Member: 80036 Status: Offline Thanks Meter: 25 | This is not a rm-78, the problem is for the 6280-6288 Quote:
WHY DID U WRITE HERE THIS? the problem is for the 6280 rm-78 - untill now- | |
11-05-2008, 18:52 | #12 (permalink) | |
No Life Poster Join Date: Feb 2004 Location: egypt Age: 51
Member: 52847 Status: Offline Thanks Meter: 73 | Quote:
try to change ver sw for ur fone upgtrde or dwngade ur fone sw ver it will be ok | |
11-05-2008, 18:59 | #13 (permalink) |
Freak Poster Join Date: Jul 2004 Location: Chile
Member: 71290 Status: Offline Sonork: 100.1645657 Thanks Meter: 105 | solution ufs3 friends and problem solved BB5KING UFS s is always taken out of the box-card BB5 and Put on a p-key, this happens because the two boxes (BB5 BOX AND UFS3) work with the same driver Greetings |
11-05-2008, 19:21 | #14 (permalink) |
Insane Poster Join Date: Dec 2003 Location: SLOVENIJA Age: 57
Member: 45771 Status: Offline Sonork: 1580823 Thanks Meter: 15 | i hawe to problem ,buth i hawe 3 twister and bb5 box not work with old one when i change new twister box with updated software work ....... after 5 hours ........................ problem ist just old software twister ...must be updated and new driver 2.0.8.... and go... now i am very hapy thenx boys for hepl me |
~~ UFS Upgrade 2.8 (208) Solution 100% Work ~~ | Paki Mobile | BB5KING for (BB5BOX) | 25 | 12-02-2010 10:47 |
