************* How to enter unlock codes -=- How to Master Reset & More************ Question: How to enter codes in htc based fones. Answer : put a cross sim card in , other than the fone is locked , it ask u to input unlock code , the code u recieved from us 8 digits one , enter it , if asked twice do the same .show u network means ur fone is unlocked :) ================================================== ======= Question: How to enter codes in G1 - GOOGLE (HTC fone) IMP: U MUST HAVE ONE SIM CARD WHICH HAS DATA SERVICES ENABLED ON IT. Step 1 Insert any other sim card in phone other than Tmobile simcard, this simcard which you insert should have 3G activated on it, the phone will ask you to enter unlock code, Here you must enter unlock code given by us to you . Step 2 Press MENU Button on the phone you will see small button on the lower part of screen pop up APN settings Now click : APN settings You will see a list of Tmobile service click again Menu button A new button will pop up click New Apn Now enter your network settings here and then sign in to gmail Question: How to enter codes in Motorolla fones . Answer: put a cross sim card in , other than ur fone is locked on , it ask u for subsidy code , enter the code 8 digits u have recieved from us , once show u network , is unlocked permanantly . in some cases if it dont ask any subsidy code , plz leave the cross sim inside the fone for around one hr , and than u see the screen again to enter subsidy code . Motorola 3G If your phone is on a 3G network enter **057* Then enter the unlock code into the window ================================================== ======= Question : How to enter codes in Nokia based fones . Answer: just power on the fone with no sim card inside the fone in offline mode, once fone fully powerd on type this code with ur fone keypad. #PW+ CODE +1 # fone will reboot automatically , means is unlocked . ================================================== ======== Question: How to enter codes in blackberry fones . Answer: u have to follow this path from your fone menu. options/advance options/simcard now using ur fone keypad dial MEPD , now it show u network lock status . after dat plz dial from fone key pad , MEP2 , it ask u for the code , enter it wat u have recieved from us , says code accepted . PHONE UNLOCKED:) IMP NOTE: while typing MEP2 , make sure after DIGIT P , u use alt /num button on ur fone keypad than u press number 2 , if not it wont ask u the code. ================================================== ======== How to enter Unlock Code on BENQ 1 - Switch ON your phone with a not allowed SIM Card, 2 - Enter the Unlock Code we send to you. ================================================== ======== How to enter Unlock Code on LG Electronics Model : LG KF750 1. insert original sim card and turn phone on. 2. Enter 2945#*750# 3. A menu will pop up, select sim unlock 4. Enter your unlock code and press ok 5. The phone will then reboot and the unlock is complete. Model : LG KU990 Viewty 1. insert original sim card and turn phone on. 2. Press telephone icon at bottom of screen to bring up the phone keypad 3. Enter 2945#*990# 4. A menu will pop up, select sim unlock 5. Enter your unlock code and press ok 6. The phone will then reboot and the unlock is complete. Model : LG VU CU915 & CU920 1. Put a AT&T or Cingular SIM in the phone; it does not have to be an active SIM 2. Enter *#865625# then the 16 digit unlock code 3. Device should say: Network Lock Deactivated 4. Phone may automatically reboot and is now unlocked ! Model : LG U310 1. Turn ON the phone without SIM Card : 2. Enter 815118#*# 3. Sim unlock mode pop up . 4. Enter your unlock code and press ok 5. The phone will then reboot and the unlock is complete. Model : LG KC550 & KS360 1. Insert original sim card and turn phone on. 2. Enter 2945#*71001# 3. Sim unlock mode pop up . 4. Enter your unlock code and press ok 5. The phone will then reboot and the unlock is complete. Model : LG KF700 (aka LG Virgo) 1. insert original sim card and turn phone on. 2. Enter 2945#*700# 3. A menu will pop up, select sim unlock 4. Enter your unlock code and press ok 5. The phone will then reboot and the unlock is complete. Model : LG KF600 1. Insert original sim card and turn phone on. 2. Enter 2945#*71001# 3. Sim unlock mode pop up . 4. Enter your unlock code and press ok 5. The phone will then reboot and the unlock is complete. Model : LG U970 1. Insert original sim card and turn phone on. 2. Enter 2945#*970# 3. A menu will pop up, select Unlock Usim. 4. Select Network Lock. 5. Enter the unlock code and ok. Model : LG U300 1 - Switch ON the phone with Accepted SIM Card (from Original Network Provider) 2 - Enter Code : 815118#*# 3 - then phone will ask to enter NCK Model : LG C2000: Insert non-Cingular SIM card Power on the handset - phone will display "phone restricted" Select "Cancel" - phone will display "phone restriction code" Enter the SIM Unlock code. Select "OK" - the handset is now successfully unlocked Model : LG TU720 - LG CU720 and all LG Shine SERIES 1) Power ON your phone with an accepted SIM card 2) Type *#865625#UNLOCK CODE 3) Press OK 4) Device is now unlocked Model : LG CE110 1) Put a non AT&T or Cingular SIM in the phone; 2) The phone display: Invalid Smart Chip 3) Power on handset 4) Select "Cancel" - phone displays "phone restriction code" 5) Enter the unlock code (8 digit code*) 6) Select "OK’" - the handset is successfully unlocked Model : LG CU400 & CU500v 1 - Insert SIM Card from a unsupported network provider, 2 - Power on the handset, 3 - Phone will display "Invalid SmartChip" 4 - In Idle screen, enter : 159753#*# 5 - Phone will display "Enter NCK, Remaining 5" 6 - Enter the 8 digit SIM Unlock code 7 - Select "OK" 8 - The handset is now successfully unlocked Model : LG U8150 1 - Switch ON your phone with a NOT Allowed SIM Card, 2 - Compose : 2, 7, 7, 6, 3, 4, #, *, #, 3 - Go to menu "SIM Lock", 4 - Enter the Unlock Code we send to you. Model : LG U400 1. Insert the network SIM in the handset which has given u the LG U400. 2. Enter 2945#*88110#. 3. The phone will then prompt 'Unlock sim'. Press OK. 4. The phone will then prompt 'Network Unlock'. Press OK. 5. The phone will then prompt- 'Input Network Control Key'. Enter the 8 digit unlocking code. Press OK. If the unlocking code comes with only 7 digits, add a 0 in front of the 7 digit code. If the unlocking code comes with only 6 digits, add 00 in front of the 6 digit code. 6. It should give you the message Success. 7. Come back to the main screen and Enter 2945#*88110#. 8. The phone will then prompt unlock sim. Press OK. 9. The phone will then prompt Network Unlock/ Lock but if you scroll down you will see a message Enter SP Lock. Enter SP Code. 10. Then press OK Model : All other model 1 - Switch ON your phone with an Allowed SIM Card, 2 - Then compose : 2945#*5101# - (if you have a LG 510w) 1945#*5101# - (if you have a LG 1200 & B1200) 2945#*5221# - (if you have a LG 5200 & 52200) 2945#*5301# - (if you have a LG 5300) 2945#*5401# - (if you have a LG 5400) 2945#*70001# - (if you have a LG 7020) 2945#*7101# - (if you have a LG 7100) 2945#*1201# or 2945#*70001# - (if you have a LG 1100) 2945#*70001# - (if you have a LG7250T) 2945#*2201# - (if you have a LG C2200) 2945#*5301# - (if you have a LG T5100) 2945#*3311# - (if you have a LG C3310) 3 - Go to "Menu" and then to "Settings", 4 - Then select "Security", 5 - To finish select "Network Provider" and select "Desactivate" 6 - Enter the Unlock Code we send to you. Model : To Classify For the next models u must to insert the original SIM: LG C3100 press 2945#*3101# LG C3380 press 2945#*7101# LG F2300 press 2945#*7101# LG KE260 press 2945#*2601# LG KE970 press 2945#*9701# LG KG120 press 2945#*1201# LG KG220 press 2945#*1201# LG KG240 press 2945#*3311# LG KG280 press 2945#*7101# LG KG290 press 2945#*7101# LG KG800 press 2945#*7101# LG KU250 press 2945#*250# LG KU380 press 2945#*380# After that will appear an secret menu,go to settings-security- sim lock ,enter NCK and press OK. For next models insert one SIM ,not the original SIM: LG KU311 press 815118#*# LG KU800 press 82652#*# LG L600v press 815118#*# LG U8150 press 277634#*# LG U8210 press 277634#*# LG U8500 press 277634#*# LG U400 press 2945#*88110# LG KC550 press 2945#*71001# LG KU580 press 2945#*580# LG KT520 press 2945#*520# LG KF750 press 2945#*750# LG KF600 press 2945#*71001# LG KG275 press 2945#*20001# LG KU380 press 2945#*380# LG KU311 press 815118#*# LG KU800 press 82652#*# LG L600v press 815118#*# LG U8150 press 277634#*# LG U8210 press 277634#*# LG U8500 press 277634#*# LG C3100 press 2945#*3101# LG C3380 press 2945#*7101# LG F2300 press 2945#*7101# LG KE260 press 2945#*2601# LG KG120 press 2945#*1201# LG KG220 press 2945#*1201# LG KG240 press 2945#*3311# LG KG280 press 2945#*7101# LG KG290 press 2945#*7101# LG KU250 press 2945#*250# Enter NCK and press OK. ================================================== ====== How to enter Unlock Code on Samsung Samsung i8910 ( hd+ others ) switch fone on , no sim card and dial . hash pw+ Nck + 1 hash ( its same like a nokia fone ) Model : Samsung i900 / Omnia 1 - Switch ON your phone with a NON Accepted SIM Card, 2 - Enter the pin code of this refused Simcard 3 - Device is now asking for another pin code 4 - Then enter the Unlock Code ! Model : Samsung Zxxx, Dxxx, Pxxx & F490 (ex : Z140, D520, P200, etc...) 1 - Switch ON your phone with a not Accepted SIM Card, 2 - Compose : #7465625*638*CODE# Model : Samsung Z510 et Z320i et Z650i : 1 - Switch ON your phone with a not Accepted SIM Card, 3 - Compose **CODE# Model : All others Samsung 1 - Switch ON your phone with a not Accepted SIM Card, 2 - Phone will ask for "Password", 3 - You can now enter the Unlock Code we send to you. OR (if phone show "Insert Correct SIM Card") 1 - Switch ON your phone with a not Accepted SIM Card, 2 - Compose : #0111*CODE# Model : Samsung i450 & i560 1 - Switch ON your phone without SIM Card, 2 - Compose #PW+CODE+1# The letter P appear after press 3 times quickly the button star ( * ) The letter W appear after press 4 times quickly the button star ( * ) The letter + appear after press 2 times quickly the button star ( * ) Model : Samsung i780 1. Insert an unaccepted SIM card 2. Enter the pin code to simcard 3. At the top of screen an "exclamation mark" icon will appear 6. Click on "exclamation mark" icon 7. There will appear link "settings" - click on it 8. Virtual keyboard appears on screen with Enter PIN prompt. 9. Enter your 8-digit unlock code. ================================================== ==== How to enter Unlock Code on SonyEricsson Model : All SonyEricsson 1 - Switch ON your phone without SIM Card, 2 - Press 1 time the left arrow, 3 - Press 2 times the button * , 4 - Press 1 time the left arrow, 5 - The message "Personalize with MNC2" will appear, 6 - You can now enter the Unlock Code we send to you. If your phone have a "JOGDIAL" (ex : SonyEricsson K700i) you must press "down arrow" instead of "left arrow" for step 2 & 3. We mean by "Down Arrow" to direct the Jogdial down ! ================================================== ======== Model : All SPV 1 - Switch ON mobile with a not Allowed SIM Card, 2 - Enter Unlock Code we send to you. Model : SPV C500 1 - Switch ON mobile with a not Allowed SIM Card, 2 - The message "PUK2" appear, 3 - Enter the Unlock Code we send to you. 4 - Phone ASK for New Code PIN enter : 0000 ================================================== ======== 5 - Confirm and compose : 0000** 6 - Click "Finish" and phone will show "Network is locked..." 7 - Enter the Unlock Code we send to you and click "Finish" 8 - Restart the Mobile who is Unlocked ! |
How To Enter Unlock Code ?? Model : AlcatelModel : 531 - 535 Without sim card : holding the "*" and compose 787292 menu "unlock network" activated select YES and enter recived code Other model - Switch on your phone with a not accepted SIM Card, - When the message "Enter Network Key" appear enter the Code recived Model : Method Generic 1 - Switch ON your phone without SIM Card, 2 - Then compose : *#0000*CODE#, 3 - To finish compose : *#0001*CODE#. Model : All Sharp 1 - Turn your phone with a SIM card accepted 2 - Dial: * 01763 * 6371 #, 3 - Then go to the menu "parameter" and "LOCK MEP" 4 - Select "Enter the code" (code secu origin = 0000=9999) 5 - Enter now Unlock Code Model :Treo 650, 680 1-Power on phone with a non-original SIM card inserted 2-Turn wireless off 3-It will then say "Your phone cannot be used with this SIM card" ("SIM not allowed" in case of Treo 650). Click OK 4-Click dialpad tab, bottom of the screen far left 5-Using stylus enter *#*#unlock code# and press the green button 6-It will say "The sim lock has been removed from your phone" 7-Your phone is unlocked Model :Treo 750 1-Power on phone with a non-original SIM card inserted 2-Turn wireless off 3-Using onscreen keyboard enter the supplied unlock code 4-Your phone is unlocked ================================================= |
other tips Model : VK530 1 - Switch the handset ON without SIM Card - screen will display Insert Card. 2 - Compose : *#83*737# (press and hold # for 1 sec) - this will give access to the personalisation menu 3 - Select Disable Personalisation 4 - Type Unlock Code we send to you and press the ok button 5 - Handset should now be unlocked Model : LG KE850 1. Make "read unlock codes" 2. Power-On phone with original accepted SIM card 3. Enter SIM pin if required. 4. Enter 2945#*8501# and press the call button (middle button bottom of the screen). 5. SIM unlock mode will appear on screen. 6. Enter unlock code 7. Select Reboot. 8. Switch phone off, and then turn back on again. Model : LG KP100 1. Make "read unlock codes" 2. Power-On phone with accepted SIM card 3. Type: 2945#*20001# 4. MENU -> SETTINGS -> SECURITY -> desactivate network codes -> OK -> enter unlock code |
Service Codes / Reset / Lang @ THX TO> IRAN GSM FOR THIS . Service codes ZTE: A35 software version: *983*7469# Service codes Panasonic: X500 software version: *#9999# X500 software version: #02#* X500 system reset: **0102# Service codes Alcatel: C820, C825, C700, C701, C707, C717, Elle-N3 set language to English: *#0044# C820, C825, C700, C701, C707, C717, Elle-N3 set language to Russian: *#0007# C820, C825, C700, C701, C707, C717, Elle-N3 set language to French: *#0033# E101, E207 software version: *#4837*# E101, E207 auto call test: *#2255*# E101, E207 memory status: *#6362*# E101, E207 reset menu: *#7378*# S520 factory mode: *#3228# S520 engineer mode: *#364463# S520 software version: *#837# S520 auto test: *#2886# S520 clean test records: *#3872# S520 restore default settings: *#73738# S520 something unknown: *#200709*01# Service codes Motorola CDMA: w150, w150i, w170, w170c, w200, w210, w355: Set English language: 1. Menu 2. Down 7 times, Right soft button 3. Down 3 times, Right soft button 4. Down 1 times, Right soft button 5. Down 4 times, Right soft button 6. select language now Service codes Samsung: E900 software version: *#5002*8376263# E900 full reset: *2767*3855# Service codes Spice: S404 enable COM port: *#42253646633# -> Device -> Set UART -> PS -> UART1/115200 S410 enable COM port: *#3646633# -> Device -> Set UART -> PS -> UART1/115200 S410 engineer mode: *#3646633# S900 software version: *#8375# S900 serial no: *#33778# Service codes Philips: S200 enable COM port: *#3338913# -> Device -> Set UART -> PS -> UART1/115200 Service codes Virgin-Lobster-544: Enable COM port: *#110*01# -> Device -> Set UART -> PS Config -> UART1/115200 Service codes "Chinese" models: default user code: 1122, 3344, 1234, 5678 Engineer mode: *#110*01# Factory mode: *#987# Enable COM port: *#110*01# -> Device -> Set UART -> PS Config -> UART1/115200 Restore factory settings: *#987*99# LCD contrast: *#369# software version: *#800# software version: *#900# set default language: *#0000# Send set English language: *#0044# Send set English language: *#0001# Send set English language: *#001# Send Service codes BenQ: software version: *#300# test mode: *#302*20040615# Service codes Pantech: software version: *01763*79837# service menu: *01763*476# reset defaults (phone/user code reset to default value 1234): *01763*737381# Service codes VK-Mobile 3xx, 5xx: software version: *#79# software version: *#837# service menu: *#85*364# (hold #) Service codes VK200, VK2000, VK2010, VK2020, VK4000: software version: *#79# service menu: *#9998*8336# (hold #) enable hidden languages: *#9998*8336# (hold #) -> change Region reset defaults (phone/user code reset to default): *#9998*7328# (hold #) Service codes LG: default security code: 0000 clear user code/user lock: 2945#*# -> Factory Reset software version: 2945#*# -> S/W version KG300 NVRAM format: 2945#*# -> menu 15 more information: 2945#*45# simlock menu: 2945#*20001#>/li> Service codes Sony-Ericsson: J100 software version: #82# K200i, K205i, K220i service info: *** (w/o sim) Service codes Fly: M90 reset user code: *2100# M100 software version: ####0000# M110 reset user code: *2100# 2040(i) reset defaults: *#987*99# Send MX200 reset defaults: *#987*99# Send MX200 software version: *#900# Send SL300m reset defaults: *#987*99# Send SL300m software version: *#900# Send SL500m reset defaults: *#987*99# Send SL500m software version: *#900# Send MP500 reset defaults: *#987*99# Send MP500 software version: *#900# Send Set language to English: *#0044# Set language to Russian: *#0007# Enable COM port: *#110*01# -> Device -> Set UART -> PS Config -> UART1/115200 Service codes Konka: C926 software version: *320# Send C926 set default language: *#0000# Send C926 set English language: *#0044# Send Service codes GStar: GM208 (Chinese Nokea 6230+) engineering menu: *#66*# Set language to English: *#0044# Set language to Russian: *#0007# Service codes Motofone-F3: Motofone F3 software version: **9999* Send ***300* Set SIM Pin ***310* / ***311* SIM Pin ON | OFF ***000* Reset Factory settings ***644* Set Voicemail number ***260* / ***261* Auto keypad lock ON | OFF ***510* / ***511* Voice Prompts ON | OFF ***160* / ***161* Restricted Calling (Phonebook only) ON | OFF ***200608* Send: software version ***200606* Send: software version ***200806* Send: flex version ***250* / ***251* Keypad tones ON | OFF ***470* Select time format ***500* /***501* Prepaid Balance Display ON | OFF ***520* Change language Service codes Motorola: C113, C114, C115, C115i, C116, C117, C118, C122 software version: #02#* C113, C114, C115, C115i, C116, C117, C118, C122 reset defaults: **0102# C138, C139, C140 software version: #02#* C138, C139, C140 reset defaults: **0102# C155, C156, C157 software version: #02#* C155, C156, C157 reset defaults: **0102# C257, C261 software version: #02#* V171, V172, V173 software version: #02#* V171, V172, V173 reset defaults: **0102# V175, V176, V176 software version: #02#* C168, C168i, W220 software version: *#**837# C168, C168i, W220 master reset: *#**367628# Send C168, C168i, W220 E2p reset: *#**778337# Send W205, W208, W375 software version: #02#* |
With Nokia codes or Nokia secret codes you can access hidden features and gain information about your Nokia phone. Many of the Nokia codes are only normally used by Nokia engineers. we take no responsibility for any data loss resulting in using these Nokia codes. Nokia code Code function *3370# This Nokia code activates Enhanced Full Rate Codec (EFR) - Your Nokia cell phone uses the best sound quality but talk time is reduced my approx. 5% #3370# Deactivate Enhanced Full Rate Codec (EFR) *#4720# Activate Half Rate Codec - Your phone uses a lower quality sound but you should gain approx 30% more Talk Time *#4720# With this Nokia code you can deactivate the Half Rate Codec *#0000# Displays your phones software version, 1st Line : Software Version, 2nd Line : Software Release Date, 3rd Line : Compression Type *#9999# Phones software version if *#0000# does not work *#06# For checking the International Mobile Equipment Identity (IMEI Number) #pw+1234567890+1# Provider Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols) #pw+1234567890+2# Network Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols) #pw+1234567890+3# Country Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols) #pw+1234567890+4# SIM Card Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols) *#147# This lets you know who called you last (Only vodofone) *#1471# Last call (Only vodofone) *#21# This phone code allows you to check the number that "All Calls" are diverted to *#2640# Displays phone security code in use *#30# Lets you see the private number *#43# Allows you to check the "Call Waiting" status of your cell phone. *#61# Allows you to check the number that "On No Reply" calls are diverted to *#62# Allows you to check the number that "Divert If Unreachable (no service)" calls are diverted to *#67# Allows you to check the number that "On Busy Calls" are diverted to *#67705646# Phone code that removes operator logo on 3310 & 3330 *#73# Reset phone timers and game scores *#746025625# Displays the SIM Clock status, if your phone supports this power saving feature "SIM Clock Stop Allowed", it means you will get the best standby time possible *#7760# Manufactures code *#7780# Restore factory settings *#8110# Software version for the nokia 8110 *#92702689# Displays - 1.Serial Number, 2.Date Made, 3.Purchase Date, 4.Date of last repair (0000 for no repairs), 5.Transfer User Data. To exit this mode you need to switch your phone off then on again *#94870345123456789# Deactivate the PWM-Mem **21*number# Turn on "All Calls" diverting to the phone number entered **61*number# Turn on "No Reply" diverting to the phone number entered **67*number# Turn on "On Busy" diverting to the phone number entered 12345 This is the default security code press and hold # Lets you switch between lines every little helps :) ........... br, |
