Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cyclonebox
Old 05-12-2009, 00:05   #1 (permalink)
Member: 111373
Thanks Meter: 25
1680c-2 RM-394 v6.82 failed
Hi,
Please help, cant unlock 1680
Nokia DCT4/WD2/BB5 Service Tool Initialization Started, Engine Revision: 1.0.0.7396
Handling device: [Cyclone Team], [Cyclone Bootloader]
Handling device: [Cyclone Team], [Cyclone Box]
Initializing box...
Box Firmware: Cyclone Nokia Application v1.03, (May 1 2009 17:13:05, gcc-4.2.2, RTOS v5.2.0), Type: Signed Production Application, Flags: CONST-TX2-PIN ; VISTA-SUPPORT
Box Serial Number: xxxxxxxxxxxx
HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2008, wk32
Initializing security card...
Card Serial Number: xxxxxxxxx
Card Firmware Revision: 0109
Card is activated
Box is activated
Started box selftests procedure
USB Voltage 5.15v PASSED
MCU Voltage 3.28v PASSED
Core Voltage 1.81v PASSED
VBAT Voltage 0.33v PASSED
VBAT Voltage 5.08v PASSED
Box VPP disabled
VPP Voltage 0.04v PASSED
Internal Box VPP Enabled
VPP Voltage 4.97v PASSED
Box VPP disabled
External Box VPP Enabled
VPP Voltage 0.00v FAILED - IGNORED - Probably power supply is not connected
Box VPP disabled
All box selftests passed!
Initializing FBUS...
All initialized - Ready to work
MCU Version V 06.82
MCU Date 26-09-08
Product RM-394
Manufacturer (c) Nokia
IMEI 354188024801578
Mastercode 4021365153
IMEI Spare 3A45810842085107
IMEI SV 3345810842085147F5000000
PPM V 06.82, 26-09-08, RM-394, (c) Nokia, ED
CNT Content: ed, V 06.82, 26-09-08, RM-394, (c) Nokia,
PSN HAB171000
Product Code 0567882
Module Code 0203777
Basic Product Code 0556746
PSD 0000000D00000000
LPSN 0
HW 1000
UEM 1328
UPP 12642
RFIC 0500
DSP ICPR62_08w27_U
LCD SUEZ
Asic 11
HW Signature DFAB837156C66DB7
Simlock Server SIMLOCK SERVER
Simlock Key 2340000300000000
Simlock Profile 800000000001000B
Simlock Aux 000B5555
Simlock IMEI 00553541880248015700
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Simlock[1,1] State: CLOSED Type: MCC-MNC Data: 23410F
Simlock[1,2] State: CLOSED Type: GID Data: 0A
MCU Version V 06.82
MCU Date 26-09-08
Product RM-394
Asic 11
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Selecting unlock method...
Search in: C:\Program Files\Cyclone Box\UnlockData\
Searching for: RM-394_V 06.82.unlock_img
Asking card to sign HW Signature...
Signed OK (0FA153EEB2D6B071C776175D5B5B4505E84CD9D0)
Writing patch file...
Booting UPP...
Box VPP disabled
Processing Flash Image Failed -> UPP Not Responding
Failed to Unlock DCT4 -> Failed to write patch file
MCU Version V 06.82
MCU Date 26-09-08
Product RM-394
Asic 11
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Booting UPP...
Box VPP disabled
MCU Version V 06.82
MCU Date 26-09-08
Product RM-394
Asic 11
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Writing SP...
Failed to Unlock DCT4 -> Possible cause: Signature Invalid (Phone not patched properly)
MCU Version V 06.82
MCU Date 26-09-08
Product RM-394
Asic 11
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Booting UPP...
Box VPP disabled
The Following 2 Users Say Thank You to rajSE For This Useful Post:
Old 05-12-2009, 00:28   #2 (permalink)
SiRoYa's Avatar
Member: 16107
Sonork: 100.58402
Thanks Meter: 26,411
this bug is fixed in new box firmware v1.4
so please update ur box from maintanence tool and then try unlock
wbr
SiRoYa
The Following User Says Thank You to SiRoYa For This Useful Post:
Old 05-12-2009, 02:35   #3 (permalink)
oscarjr85's Avatar
Member: 978651
Sonork: 1672421
Thanks Meter: 89
if you continue trying or if the power to give upp the phone and ready, still trying
greetings
oscar jr
The Following User Says Thank You to oscarjr85 For This Useful Post:
Old 05-12-2009, 07:55   #4 (permalink)
hasnain's Avatar
Member: 265626
Sonork: 100.1591486
Thanks Meter: 2,982
greetings
oscar jr
now no need of such things now
just update firmware of cyclone box and enjoy
The Following User Says Thank You to hasnain For This Useful Post:
Old 07-03-2009, 14:44   #5 (permalink)
Member: 681328
thinks my frinde for this file
Old 07-12-2009, 09:22   #6 (permalink)
Member: 755604
Sonork: 00923066261112
Thanks Meter: 19
1680 not flashing but cnt error on 25% in flashing the mobile
Old 07-12-2009, 09:37   #7 (permalink)
Member: 247347
Thanks Meter: 58
Use easy cable, flash WO battery and when he says booting upp insert batt and each time when he boot upp remove and insert quickly. Same when you try to unlock, works 100%.
The Following User Says Thank You to ovidiucosti For This Useful Post:
Old 11-18-2009, 20:50   #8 (permalink)
Dr_Wolodya's Avatar
Member: 75408
Thanks Meter: 1,195
Originally Posted by rajSE View Post
Booting UPP...
Box VPP disabled
Even with Box Firmware: Cyclone Nokia Application v01.0A - same problem during unlocking.
MCU Version	V 07.60
MCU Date	10-04-09
Product		RM-394
IMEI		011680003595606
Mastercode	564423361
Using Super DCT4 Activation
Searching for: RM-394_V 07.60.sunlock_img
Booting UPP...
UPP ID: 3168 [HW_UNKNOWN]
Box VPP disabled
Processing Flash Image Failed -> Given Image not maches with readen UPP Id or Image problem
Old 11-18-2009, 21:33   #9 (permalink)
Dr_Wolodya's Avatar
Member: 75408
Thanks Meter: 1,195
I think problem next:
- unlock patch file RM-394_V 07.60.sunlock_img maked for UPP ID: 3162 but in phone UPP ID: 3168.
Old 11-19-2009, 11:12   #10 (permalink)
imran_qasim's Avatar
Member: 133436
Sonork: 100.1577364
Thanks Meter: 191
MCU Version    V 07.60
MCU Date    10-04-09
Product        RM-394
Booting UPP...
Box VPP disabled
i've got the same problem with one 1680c , what i did
1) Goto DCT4/WD2 Flash Tab
2) from the SKIP panel Check the box UPP ID Check
3) Now From Security press Initilize. be sure form what to do Unlock is selected.
i hope this will resolve your problem also.
NOTE TO CYCLONE TEAM: IS THIS A BUG OR WHAT
Take Care
ENJOY
The Following User Says Thank You to imran_qasim For This Useful Post:
Old 11-19-2009, 12:58   #11 (permalink)
Dr_Wolodya's Avatar
Member: 75408
Thanks Meter: 1,195
Checking the box UPP ID Check help me but no network after (filters changed, euro pm writed).
Old 11-19-2009, 14:46   #12 (permalink)
Member: 970764
Thanks Meter: 38
flash with 5.63 version u r problem solve 10000000%
Old 11-19-2009, 15:07   #13 (permalink)
Member: 765909
Sonork: 100.1608098
Thanks Meter: 855
flash latest version than unlock
Old 11-19-2009, 15:34   #14 (permalink)
/\/\A/\/|'s Avatar
Member: 900083
Thanks Meter: 601
brother just try with other device like mxkey 100% tested many time
Old 11-19-2009, 15:49   #15 (permalink)
Dr_Wolodya's Avatar
Member: 75408
Thanks Meter: 1,195
With v5.63 phone do not turning on because this fw do not support cpu with id 3168.
I think 7.60 - latest. Or not?
Because in supported list this model and this fw ver adn this UPP ID exist and this phone with this fw ver must be unlockable.
Stop post answers like your - this is Cyclone support thread not mxkey.
1680c-2 RM-394 sw 07.60 hallo Universalbox 7 06-01-2010 17:18
Nokia 1680c-2 RM-394 V 06.82 Unlock Black_Daimond HWK 28 01-12-2010 14:36
2760 RM-259 v6.82 failed to unlock jepetu Cyclonebox 1 12-07-2009 20:16
1680C RM-394 06.82 inextricably locked version, gfxz J.A.F. By Jafsupport.com 3 05-22-2009 10:55
Page generated in 0.23899 seconds with 9 queries
