Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cyclonebox
Old 11-07-2009, 14:22   #1 (permalink)
andy-r's Avatar
Member: 568295
Thanks Meter: 162
2720a-2b RM-520 v8.62 successfully convert to RM-520 v8.20 and unlocked by cyclone
2720a-2b RM-520 v8.62 successfully convert to RM-520 v8.20 and unlocked by cyclone with procedure...
1. Box: Cyclone Box with DCT4 plus activated
2: Cable: UFC Cable set to 5.1k
3. Flash phone using RM-519 v8.20 firmware to downgrade
= download the firmware at cyclone support site =
4. Write PM file
= download PM file = here
5. Unlock and repair BT if necessary
6. Do hardware modification
Here's the logs:
Phone unit:
Flashing:
Write PM:
Unlocking:
Pinout:
Hardware Modification:
= Make a jumper and follow the red line =
Finish Product:
Hope it helps... thanks...
The Following 92 Users Say Thank You to andy-r For This Useful Post:
Old 11-07-2009, 17:49   #2 (permalink)
denisirias's Avatar
Member: 309299
Thanks Meter: 259
dear mate you made that modification cause you want to use phone in 900/1800 networks or im wrong what if i want to use phone in 850/1900 should i write pm and make modification on pcb or not
The Following 2 Users Say Thank You to denisirias For This Useful Post:
Old 11-07-2009, 18:59   #3 (permalink)
andy-r's Avatar
Member: 568295
Thanks Meter: 162
there's no need to write pm files and modification if you want to use it in 850mhz/1900mhz band, just flash it to downgrade and unlock...
The Following 7 Users Say Thank You to andy-r For This Useful Post:
Old 12-05-2009, 19:26   #4 (permalink)
Crazy Poster
Member: 793990
Thanks Meter: 18
thanks andy
good job for unlock nokia 2720
The Following User Says Thank You to iber For This Useful Post:
Old 12-11-2009, 02:30   #5 (permalink)
Member: 122196
i am new to this.
but to flash how do i connect the cables to the pins you have shown in the pic
The Following User Says Thank You to mathewsmt For This Useful Post:
Old 12-17-2009, 15:50   #6 (permalink)
Member: 426947
Thanks Meter: 35
Arrow 2720f unlock ok 100000000000%
Nokia DCT4/WD2/BB5 Service Tool Initialization Started, Engine Revision: 1.0.0.7918
Handling device: [Cyclone Team], [Cyclone Bootloader]
Handling device: [Cyclone Team], [Cyclone Box]
Initializing box...
Box Firmware: Cyclone Nokia Application v01.0C, (Nov 25 2009 03:18:28, gcc v4.3.2, RTOS V6.0.0), Type: Signed Production Application
Box Serial Number: C0000589
HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2008, wk27
Initializing security card...
Card Serial Number: D100029C
Card Firmware Revision: 0109
Card is activated
Box is activated
Started box selftests procedure
USB Voltage 4.85v PASSED
MCU Voltage 3.28v PASSED
Core Voltage 1.78v PASSED
VBAT Voltage 0.01v PASSED
VBAT Voltage 4.63v PASSED
Box VPP disabled
VPP Voltage 0.02v PASSED
Internal Box VPP Enabled
VPP Voltage 4.57v PASSED
Box VPP disabled
VPP Voltage 0.04v PASSED
External Box VPP Enabled
VPP Voltage 0.04v FAILED - IGNORED - Probably power supply is not connected
Box VPP disabled
All box selftests passed!
Super DCT4 Activation: TRUE
Initializing FBUS...
All initialized - Ready to work
MCU Version V 08.20
MCU Date 30-06-09
Product RM-519
Manufacturer (c) Nokia
IMEI 012046000908623
Mastercode 335152174
IMEI Spare 0A21400600096802
IMEI SV 0321400600096832F9000000
PPM V 08.20, 30-06-09, RM-519, (c) Nokia , AA
CNT Content: aa_blac, V 08.20, 30-06-09, RM-519, (c) Nokia ,
PSN IQF594992
Product Code 0582187
Module Code 0204102
Basic Product Code 0572278
PSD 0000000D00000000
LPSN 0
HW 1000
UEM 4386
UPP 12648
RFIC 0500
DSP ICPR72_09w24_U
LCD SUEZ
BT 1673-46032
Asic 11
HW Signature 61BB1CE9F0D51AA8
Simlock Server SIMLOCK SERVER
Simlock Key 3102000000000000
Simlock Profile 800000000003000B
Simlock Aux 000B5555
Simlock IMEI 00550120460009086200
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Simlock [1,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 310160
Simlock [2,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 310200
Simlock [3,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 310210
Simlock [4,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 310220
Simlock [5,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 310230
Simlock [6,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 310240
Simlock [7,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 310250
Simlock [8,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 310260
Simlock [9,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 310270
Simlock [10,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 310310
Simlock [11,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 310580
Simlock [12,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 310660
Simlock [13,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 310800
Simlock [14,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 310490
MCU Version V 08.20
MCU Date 30-06-09
Product RM-519
Selecting unlock method...
Using Super DCT4 Activation
Search in: C:\Program Files\Cyclone Box\UnlockData\
Searching for: RM-519_V 08.20.sunlock_img
Writing patch file...
Booting UPP...
UPP ID: 3168 [HW_UNKNOWN]
shadow, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM
Flashbus Write baud set to 100Kbits
u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4
Box VPP disabled
Internal Phone VPP Selected
PLL Factor: 3
FlashChip[0]: 0x00898981 @ 0x01000000, Intel, SectorSize: 128kB, Ext: 00009221
FlashChip[1]: 0x00898981 @ 0x02000000, Intel, SectorSize: 128kB, Ext: 00009221
Signature: AD7EB61B23100340C605E40120A20000
Flashbus Write baud set to 1.0Mbits
Flashbus Read baud set to 51Kbits
u3_intel.fia, Type: Algorithm, Target: FlashChip[0] 0x00898981 (256Mbits), Rev: 7.4.80.0, Algo: DCT4 ALGORITHM
Nominal VPP Voltage: 9V, Detected: 0.02V
MSID-Crypted: 8427939D942483C74435021596
MSID-Plain: 2C40BAE9004EE569A9000000
FAID-Crypted: C152FFC7CE3317548F5278EE
Flashbus Write baud set to 6.50Mbits
4 Region(s) to erase
Erasing NOR Region [0x01220000-0x0123FFFF]
Erasing NOR Region [0x01440000-0x0145FFFF]
Erasing NOR Region [0x014C0000-0x014DFFFF]
Erasing NOR Region [0x01CC0000-0x01CDFFFF]
Erase taken 2.235s
Writing 32 blocks...
Sending Super DCT4 Emulator...
Emulator sent OK!
All blocks written OK! Time taken 34.766s
Terminating flash session
Box VPP disabled
Asic 11
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Asking card to sign HW Signature...
Signed OK (F0DD66F9FADE7F49F1FA215D0D1946A40CBF63D9)
Simlock Security - UNKNOWN
Writing SP...
New SP Accepted OK!
Phone unlocked OK!
The Following 2 Users Say Thank You to goverdhan For This Useful Post:
Old 12-17-2009, 17:00   #7 (permalink)
adriano II's Avatar
Member: 155242
Thanks Meter: 136
tested 100% and working
The Following 2 Users Say Thank You to adriano II For This Useful Post:
Old 12-24-2009, 20:31   #8 (permalink)
ysraeldark's Avatar
Member: 451390
Thanks Meter: 29
i have 2720 i fahing and unlock but no signal th cellphone is orignal of spain the freccuenzy is 900 and 1900 and i need freceunzy 850 and 1900 please help for full signal with freceuzys 850 and 1900
Old 12-26-2009, 03:10   #9 (permalink)
andy-r's Avatar
Member: 568295
Thanks Meter: 162
Originally Posted by mathewsmt View Post
i am new to this.
You need UFC Cable to connect with your phone...
Old 12-26-2009, 03:13   #10 (permalink)
andy-r's Avatar
Member: 568295
Thanks Meter: 162
Just downgrade it and unlock...
Old 12-26-2009, 05:32   #11 (permalink)
IBRAHIM BANGURA's Avatar
Member: 194431
Thanks Meter: 22
Wink cable for 2720a
hello bro , which cable really read this phone as i tried with small pin but it doesnot enter can you plz help
Originally Posted by iber View Post
thanks andy
Old 12-26-2009, 05:46   #12 (permalink)
kalpeshoza's Avatar
Member: 462292
Thanks Meter: 397
Do with UFC cable see the image
The Following 2 Users Say Thank You to kalpeshoza For This Useful Post:
Old 12-26-2009, 19:12   #13 (permalink)
ysraeldark's Avatar
Member: 451390
Thanks Meter: 29
but i donwgrade and unlock and not signal i modific the cellphone the componentes of signal and not searching mmm no signal pelase guide how use signal 850 to 1900 for nokia 2720
Old 12-27-2009, 01:29   #14 (permalink)
andy-r's Avatar
Member: 568295
Thanks Meter: 162
Post logs for more info so i can guide you exactly what you need to do about your phone... is your phone 2720 or 2720a?
Old 12-27-2009, 15:37   #15 (permalink)
aslam870's Avatar
Member: 383033
Sonork: 100.1580642
Thanks Meter: 441
Smile
Yes, this pinout works 100% Tested by me. See on this post:
http://forum.gsmhosting.com/vbb/show...&postcount=231
I will try now with this solution of conversion. I have made many convertion in DCT4 phones but always is needed hardware modifications. In my country we only work in 900 MHz band.
Best Regards.................aslam870
The Following User Says Thank You to aslam870 For This Useful Post:
RM293 2660B v8.25 cannot convert to 2660 rm 292 jins jisha Cyclonebox 5 07-07-2011 12:13
2680 s 2b rm 393 converted to rm 392 but bluettoth not working unlock_solution Universalbox 2 10-23-2009 19:22
Nokia E71 successfully unlocked by Cyclone Box! Dj King Cyclonebox 2 05-09-2009 15:25
2680s-2b RM-393 Converted to RM-392 Working 900mhz-1800mhz But Camera Failure bigmac1204 Nokia Hardware & Hardware Repair 3 04-06-2009 19:15
6133 RM-126 v.5.60 successfully converted to RM115 v.5.50 and UNLOCKED! jjogola UID - Box 9 02-03-2009 22:57
Page generated in 0.26180 seconds with 11 queries
