06-22-2009, 18:58 | #1 (permalink) |
Insane Poster Join Date: Mar 2008
Member: 725226 Status: Offline Thanks Meter: 73 | !!! 5220 not supported hash !!! Code: BB5 Unlock Started... MCU Version V 05.20 MCU Date 15-10-08 Product RM-411 Manufacturer (c) Nokia IMEI 356840025762450 Mastercode 207516744 Simlock Server SIMLOCK SERVER Simlock Key 2140300000000000 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 21403F Reading Security Block... Security block OK! Determining PA Simlock... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006030C192101033000 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1940000282135950236C61E755EA79A287478212 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT_ROM_ID: 273F6D55DFAAF68F RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x0089898200000000, Intel, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 4.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: D93826B23E9B093BE4DD7304FBAA6778996AE60B APE Boot skipped on user request Restarting MCU... Determined PA Simlock: PA_SL2 Checking for Rootkey Hash support... BB5 Unlock Failed -> Unsupported Rootkey Hash, this is critical WBR |
06-22-2009, 19:31 | #3 (permalink) |
No Life Poster Join Date: Jan 2009 Location: England Age: 59
Member: 947561 Status: Offline Thanks Meter: 14,053 | Is just a beta.. the Hash are already in.. they are working on it I Think.. this update has been released early cause the pressure of the users.. but I'm waiting for the big bomb soon :-) BR Alex |
The Following User Says Thank You to moulnisky For This Useful Post: |
06-22-2009, 19:34 | #5 (permalink) | |
Member: 725226 Status: Offline Thanks Meter: 73 | Quote:
That is for sure , i will test and put all logs for all the users that are curios WBR | |
The Following User Says Thank You to sirbigman For This Useful Post: |
06-22-2009, 19:44 | #7 (permalink) |
Banned Join Date: May 2003 Location: www.CentralMobile.net/vbb
Member: 28188 Status: Offline Thanks Meter: 579 | |
06-22-2009, 19:59 | #11 (permalink) |
Member: 28188 Status: Offline Thanks Meter: 579 | @sirbigman Mate, check this post and redo the test, I have not this model in hand http://forum.gsmhosting.com/vbb/show...5&postcount=31 However cyclonebox said nothing Best regards |
06-22-2009, 20:11 | #12 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Pakistan
Member: 265626 Status: Offline Sonork: 100.1591486 Thanks Meter: 2,982 | HASH is there that means this model is 100% unlockable if u can't than just wait for full version u will see this feature and don't forget Cyclone will be the first with this feature |
The Following User Says Thank You to hasnain For This Useful Post: |
06-22-2009, 21:38 | #13 (permalink) |
No Life Poster Join Date: Apr 2005 Location: ALGERIA, Tlemcen, Tounane Age: 37
Member: 135039 Status: Offline Thanks Meter: 1,486 | same hash in 6600s lock the logs Code: BB5 Unlock Started... MCU Version V 04.81 MCU Date 29-07-08 Product RM-414 Manufacturer (c) Nokia IMEI 356383027433135 Mastercode 5772323060 Simlock Server SIMLOCK SERVER Simlock Key 2081000000000000 Simlock Profile 8000000000000002 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 20810F Simlock [2,1] State: CLOSED Type: MCC-MNC Data: 64710F Reading Security Block... Security block OK! Determining PA Simlock... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006030C192101023000 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1F5001081C2D5750A95DF74FE009442A13F57DAD CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT_ROM_ID: 273F6D55DFAAF68F RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x0001003F00008A21, AMD, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 4.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: A4B03CEB0AC8A915C4ECE9894BC44D6CE68F3AA4 APE Boot skipped on user request Restarting MCU... Determined PA Simlock: PA_SL2 Checking for Rootkey Hash support... BB5 Unlock Failed -> Unsupported Rootkey Hash, this is critical |
06-22-2009, 21:46 | #14 (permalink) |
Member: 265626 Status: Offline Sonork: 100.1591486 Thanks Meter: 2,982 | U CAN UNLOCK SL2 New Security with Unprotected Firmware . RAPS_V3.03-PA_SL2 CPU * 3600 slide * 5220 XpressMusic * 7210 Supernova * 7310 Supernova * 7610 Supernova * 7510a ================================================== == U CANNOT UNLOCK 5310 6500s .... SL2 New Security with Protected Firmware RAP3Gv3 PA_SL2 CPU USERS Called them SL3 |
06-22-2009, 22:21 | #15 (permalink) |
No Life Poster Join Date: Oct 2002 Age: 39
Member: 16107 Status: Offline Sonork: 100.58402 Thanks Meter: 26,411 | atm RAPS v3.03 is not supported in current beta release but who knows wht comes next wbr SiRoYa |
The Following 5 Users Say Thank You to SiRoYa For This Useful Post: |
5220 Not supported HASH problem | tnasoft | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 12-30-2009 13:41 |
nokia with not supported hash Err1 0x05 | PETERB | Genie Universal | 5 | 06-30-2009 09:01 |
Not supported HASH or ROM ID by zulea | hassanlou | Nokia Base Band 5 ( BB-5 ) | 2 | 04-03-2009 12:39 |
Version Not Supported!- Hash Table : 04 22 05 | Nurettin Duman | SwS_SaG_BoX | 2 | 01-09-2007 04:05 |
c3-2 not supported Hash A00E01 | ..:: i-MAX ::.. | SwS_SaG_BoX | 0 | 05-10-2006 18:52 |
