![]() | #1 (permalink) |
Junior Member Join Date: Sep 2011 Location: mexico
Member: 1654164 Status: Offline Thanks Meter: 0 | ![]() this is my problem :Establishing Connection with Box in Main Mode... Handling device: [Cyclone Team], [Cyclone Bootloader], [Platform: Classic] Box Open Error -> Not found needed Cyclone device Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic] Initializing box... CBUS Request Error -> CBUS Problem, Lost handle (Write Pipe) Box Firmware Version Read Failed -> No answer from CBUS this my serial : B0002BC9 |
![]() | #3 (permalink) | |
Member: 1654164 Status: Offline Thanks Meter: 0 | ![]() Quote: Please help me because I was looking for, but I could not post in the other topic my log where the error because it was closed, it would be so kind to help me, I can not use this box and acquired by whichis very good be patient | |
![]() | #4 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Sep 2006 Location: RETIRED ! Age: 48
Member: 348680 Status: Offline Thanks Meter: 1,273 | Those Threads are closed because the Issue is SOLVED..... Have you done as instructed on those posts.... You Just need READ Carefully.... You Dont Need to Post ... You Need to Read ![]() http://forum.gsmhosting.com/vbb/9379977-post7.html http://forum.gsmhosting.com/vbb/9379184-post3.html http://forum.gsmhosting.com/vbb/9312612-post6.html |
The Following User Says Thank You to ptt For This Useful Post: |
![]() | #5 (permalink) | |
Thank you very much you are very kind friend finally solved what I thought could not not make use of it; here the log Establishing Connection with Box in Main Mode ... Handling device: [Cyclone Team], [Cyclone Bootloader], [Platform: Classic] Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic] Initializing box ... Box Firmware: Cyclone Main Application v02.11, (November 10, 2012 00:51:00, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012 Hardware Platform: Cyclone Reloaded Flasher Interface (c) 2012 KarwosLabs Box Serial Number: B0002BC9 HW Revised: A, Suitable for: Production, Case: Reloaded Box Casing, MCU Manufacture Time: Unknown Box is activated Started selftests box procedure USB Voltage 4.95v PASSED MCU Voltage 3.27v PASSED Core Voltage 1.76v PASSED PASSED VBAT Voltage 0.03V VBAT Voltage 4.98v PASSED Box VPP disabled VPP Voltage 0.04V PASSED Internal Box VPP Enabled VPP Voltage 4.92v PASSED Box VPP disabled VPP Voltage 0.02V PASSED All box selftests passed! Super DCT4 Activation: TRUE XGold / Blackberry Service Running, Counter: 100 Avaiable Physical Memory: 1.671GB Avaiable Virtual Memory: 1.911GB Avaiable Pagefile: 3.538GB Initializing FBUS ... All initialized - Ready to work It is very good person with a great day, greetings from Mexico | |
