01-08-2010, 16:24 | #166 (permalink) |
Junior Member Join Date: Jun 2007
Member: 521669 Status: Offline Thanks Meter: 3 | Right, but why is need to change to main mode my finger touch ? And after I touch on the cristal cover the box work just fine. There's an faulty somewhere around Y1, don't you think so ? Thanks |
01-08-2010, 16:32 | #167 (permalink) |
Insane Poster Join Date: Sep 2005 Age: 41
Member: 178595 Status: Offline Thanks Meter: 5 | i have a problem with cyclone pls help Nokia DCT4/WD2/BB5 Service Tool Initialization Started, Engine Revision: 1.0.0.8236 Handling device: [Cyclone Team], [Cyclone Bootloader] Initialization has failed -> No connection was established, or box is not in needed mode and to maintenance: Box Maintenance procedure started at 17:17:56 Handling device: [Cyclone Team], [Cyclone Bootloader] Bootloader: Cyclone Secure Bootloader v2.08, (Nov 14 2008 12:05:50), Type: Signed Production Application, For HW Rev E Service Tag: 7B58D85EFB4759D4FA0DEAB44E2B2F58 Connecting to Cyclone Server Cyclone Server (1.0.0.575), Cyclone Box Team 2008, 2009, 2010 - Ready. ========= Box Info ========= Box SN: C0000706 HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2008, wk27 Set: Box, TX2 Adapter, 100 Credits, 6 Months Warranty Box registration status: Registered OK Paired Card SN: D0000259 First Name: Cristea Surname: Ionut Nickname: glontz Address: Bucuresti Country: RomaniaE-Mail: [email protected] Reseller: gsm-box.net, Romania Warranty Start Date: 2009-08-07 Warranty Period (months): 6 Warranty Stop Date: 2010-02-07 Warranty active: Yes ============================ Updating Security Area... Security Area Update Skipped, Not allowed Updating Main Firmware... Main Firmware Update Skipped, Not allowed Updating Secure Bootloader... New Secure Bootloader (2.10) Avaiable, Updating... Spawning box in Main Mode... Handling device: [Cyclone Team], [Cyclone Bootloader] Box Maintenance Error -> No connection was established, or box is not in needed mode what do i have to do pls help??? |
01-08-2010, 19:26 | #172 (permalink) |
No Life Poster Join Date: Oct 2002 Location: Romania
Member: 16269 Status: Offline Sonork: 1604924 Thanks Meter: 62 | I have this problem after make update I install Cyclone in new windows make update again same problem ! Code: Updating Security Area... Security Area Update Skipped, Not allowed Updating Main Firmware... Main Firmware Update Skipped, Not allowed Updating Secure Bootloader... New Secure Bootloader (2.10) Avaiable, Updating... Spawning box in Main Mode... Handling device: [Cyclone Team], [Cyclone Bootloader] Box Maintenance Error -> No connection was established, or box is not in needed mode |
01-12-2010, 14:42 | #173 (permalink) |
Freak Poster Join Date: Feb 2007
Member: 456610 Status: Offline Thanks Meter: 19 | every time when I connect my box have the same problem "Initialization has failed -> No connection was established, gold box is not needed in mode Then I uninstall the drivers and I reinstalled again Please Cyclone box fix to problem |
01-12-2010, 17:25 | #174 (permalink) |
Junior Member Join Date: Mar 2008
Member: 735632 Status: Offline Thanks Meter: 0 | Nokia DCT4/WD2/BB5 Service Tool Initialization Started, Engine Revision: 1.0.0.8155 Handling device: [Cyclone Team], [Cyclone Bootloader] Initialization has failed -> No connection was established, or box is not in needed mode ??????? |
01-12-2010, 21:58 | #175 (permalink) |
No Life Poster Join Date: Sep 2006 Location: RETIRED ! Age: 47
Member: 348680 Status: Offline Thanks Meter: 1,273 | @Did13 Make sure you are using the latest FW version ( v01.15 ) @ gournabil Send PM to SiRoYa, with your Box S/N, wait till him change your box flag in server, then update box FW again, if doesnt work, maybe you have problems with the 12Mhz cristals. BR |
01-13-2010, 14:10 | #176 (permalink) | |
Member: 456610 Status: Offline Thanks Meter: 19 | Quote:
yes , i used the latest FW version " v01.15 " but still the same problem | |
01-13-2010, 14:59 | #177 (permalink) |
Member: 348680 Status: Offline Thanks Meter: 1,273 | @ Did13 If you are sure about the Software, Drivers, and your windows / PC are OK, then you can try to update the box FW again ( send PM to one of the Product managers with your BOX S/N and ask to allow to upgrade the FW again ). If the problem not solved with the FW upgrade, maybe the 12Mhz cristals are damaged, you can try to change them. or if your box is under warranty, contact your reseller for exchange. BR |
The Following User Says Thank You to ptt For This Useful Post: |
01-15-2010, 21:32 | #178 (permalink) |
Junior Member Join Date: Aug 2005 Location: C:\Root..... Help ! Age: 54
Member: 169123 Status: Offline Thanks Meter: 0 | Can anyone explain whats going on here, its started to drive me nuts. Been same issue for few weeks. Box Maintenance procedure started at 20:28:26 Handling device: [Cyclone Team], [Cyclone Bootloader] Bootloader: Cyclone Secure Bootloader v2.08, (Nov 14 2008 12:05:50), Type: Signed Production Application, For HW Rev E Service Tag: 727FA56287AFB24DCB7C5208644111AF Connecting to Cyclone Server Cyclone Server (1.0.0.576), Cyclone Box Team 2008, 2009, 2010 - Ready. ========= Box Info ========= Box SN: C0001980 HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk19 Set: Box, TX2 Adapter, 100 Credits, 6 Months Warranty Box registration status: Registered OK Paired Card SN: D3000489 First Name: **** Surname: ****** Nickname: ********* Address: ***************** Country: EU E-Mail: ***************** Reseller: Siroya, Worldwide Warranty Start Date: 2009-08-30 Warranty Period (months): 6 Warranty Stop Date: 2010-02-28 Warranty active: Yes ============================ Updating Security Area... Security Area Update Skipped, Not allowed Updating Main Firmware... Main Firmware Update Skipped, Not allowed Updating Secure Bootloader... New Secure Bootloader (2.10) Avaiable, Updating... Spawning box in Main Mode... Handling device: [Cyclone Team], [Cyclone Bootloader] Box Maintenance Error -> No connection was established, or box is not in needed mode Obviously Ive removed personal details, but the general idea I get is it wont connect to server |
01-15-2010, 23:27 | #179 (permalink) |
Member: 348680 Status: Offline Thanks Meter: 1,273 | @ sparky2k1 Send PM to Cyclonebox, Honey or SiRoYa ( only to one of them ) with your Box S/N, wait till him reply, and update your box again... BR |
problem with my cyclone box.box is not in needed mode | samih127 | Cyclonebox | 18 | 06-12-2010 06:05 |
Box is not in needed mode [SOLVED] | renren | Cyclonebox | 2 | 01-19-2010 22:38 |
::solve:: box is not in needed mode | mr khalid | Cyclonebox | 6 | 09-15-2009 08:36 |
Cyclone team (not connected) box is not in needed mode | tims | Cyclonebox | 17 | 06-29-2009 03:54 |
Box is not in needed mode. | masterunlock | Cyclonebox | 5 | 03-24-2009 16:44 |
