Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cyclonebox
Old 08-07-2011, 00:42   #421 (permalink)
SiRoYa's Avatar
Member: 16107
Sonork: 100.58402
Thanks Meter: 26,411
Originally Posted by tong83 View Post
pls add ticket again. after few hours updating i got same problem again
Paired Card SN: D5000129
i have added 5 credits for update
so please check ur connection and make sure u are firewall is off
then update your box again
Old 08-16-2011, 01:45   #422 (permalink)
Member: 45477
Thanks Meter: 22
I have problem with updating. software is installed correctly because the other box I have updates normally.
Updating Security Area...
Security Area Update Skipped, Not allowed
Updating Main Firmware...
Main Firmware Update Skipped, Not allowed
Updating COM Emulator Firmware...
COM Emulator Update Skipped, Not allowed
Updating Secure Bootloader...
Handling device: [Cyclone Team], [Cyclone Bootloader]
Failed to Upgrade Bootloader -> No connection was established, or box is not in needed mode
Secure Bootloader Update Skipped
Disconnected from Cyclone Server
Box Maintenance finished successfully
Paired Card SN: D0090609
Old 08-17-2011, 23:11   #423 (permalink)
Member: 45477
Thanks Meter: 22
Old 08-17-2011, 23:34   #424 (permalink)
SiRoYa's Avatar
Member: 16107
Sonork: 100.58402
i don't see any problem with your box , box seems already up to date
but anyway update credits are added in your account
you can update box again from maintenance tool
br
SiRoYa
The Following User Says Thank You to SiRoYa For This Useful Post:
Old 08-18-2011, 02:03   #425 (permalink)
Member: 45477
Thanks Meter: 22
siroya
thanks, that allowed to update the box
Old 10-26-2011, 05:45   #426 (permalink)
Member: 767328
Sonork: cilunkz
Thanks Meter: 2
Box Open Error -> Security problem #1
Initialization has failed -> No connection was established, or box is not in needed mode
how to solve this??
need solution..
Old 10-26-2011, 12:52   #427 (permalink)
ptt
ptt's Avatar
Member: 348680
Thanks Meter: 1,273
how to solve this??
need solution..
Please do some Search before post:
http://forum.gsmhosting.com/vbb/f528...m-1-a-1315919/
http://forum.gsmhosting.com/vbb/f528...olved-1264680/
http://forum.gsmhosting.com/vbb/f528...m-1-a-1240904/
http://forum.gsmhosting.com/vbb/f528...olved-1232447/
Old 11-01-2011, 14:18   #428 (permalink)
Member: 767328
Sonork: cilunkz
Thanks Meter: 2
I need solution this cannot be open..it says connected listed
Old 11-01-2011, 14:42   #429 (permalink)
Member: 209842
Sonork: 100.93537
Thanks Meter: 3,386
http://forum.gsmhosting.com/vbb/f528...olved-1372860/
Old 11-28-2011, 06:51   #430 (permalink)
Member: 695023
Thanks Meter: 53
Product Supporter need help
after i succesfully fill credits becaused of security failed issue
i tried to update my box in Box maitenance with latest version and a new found hardware pop-up ( cyclonebox usb-uart stack) and succesfully installed...
but problem occured
tried the solution posted aboved but no luck
tried to install to a fresh pc but same error
how can i solved this
Box Serial Number: C0000C09
Old 11-28-2011, 08:18   #431 (permalink)
Mr.3.'s Avatar
Member: 962029
Sonork: OEM Lock : ON
Thanks Meter: 4,139
did you update box through Box maintance
The Following User Says Thank You to Mr.3. For This Useful Post:
Old 11-28-2011, 08:27   #432 (permalink)
Member: 695023
Thanks Meter: 53
yes sir trying to update now
Box Maintenance procedure started at 3:28:42 PM
Handling device: [Cyclone Team], [Cyclone Bootloader], [Platform: Classic]
Bootloader: Cyclone Secure Bootloader v2.13, (Oct 5 2010 17:21:58), Type: Signed Production Application, Added Clip Support
Service Tag: 15F3365B2912D33DBE915C01710C7912
Connecting to Cyclone Server
Box Maintenance Error -> Can't connect to Cyclone Server
Old 11-28-2011, 09:05   #433 (permalink)
Member: 695023
Thanks Meter: 53
i used search button and followed sticky post
folowed tpis and tricks
but same problem
update now from box maintenance but no luck
Old 11-28-2011, 09:19   #434 (permalink)
Mr.3.'s Avatar
Member: 962029
Thanks Meter: 4,139
post your box serial number.. we will add tickets to your box..
Old 11-28-2011, 09:40   #435 (permalink)
Member: 209842
Sonork: 100.93537
Thanks Meter: 3,386
but problem occured
On Your fresh pc pls make Maintenance box.
The Following User Says Thank You to kaisak For This Useful Post:
problem with my cyclone box.box is not in needed mode samih127 Cyclonebox 18 06-12-2010 06:05
Box is not in needed mode [SOLVED] renren Cyclonebox 2 01-19-2010 22:38
::solve:: box is not in needed mode mr khalid Cyclonebox 6 09-15-2009 08:36
Cyclone team (not connected) box is not in needed mode tims Cyclonebox 17 06-29-2009 03:54
Box is not in needed mode. masterunlock Cyclonebox 5 03-24-2009 16:44
Page generated in 0.21112 seconds with 10 queries
