![]() | #592 (permalink) |
Insane Poster ![]() ![]() ![]() Join Date: Oct 2009
Member: 1132097 Status: Offline Thanks Meter: 4 | same here, on label of the box: serial CYA08253 don't update because same error, already tested many computers, cables, ports, total unnistall e erase the cyclonebox folder, install again e try update and nothing works: Establishing Connection with Box in Main Mode... Handling device: [Cyclone Team], [Cyclone Bootloader], [Platform: Classic] Initialization has failed -> No connection was established, or box is not in needed mode |
![]() | #593 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2005 Location: Poland
Member: 209842 Status: Offline Sonork: 100.93537 Thanks Meter: 3,386 | Quote:
![]() | #595 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Aug 2004 Location: hungary Age: 44
Member: 78731 Status: Offline Thanks Meter: 4 | Establishing Connection with Box in Main Mode... Handling device: [Cyclone Team], [Cyclone Bootloader], [Platform: Classic] Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic] Initializing box... Box Firmware: Cyclone Main Application v02.05, (Aug 22 2012 23:26:51, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012 Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs Box Serial Number: C00020F8 HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk27 Initializing security card... Card Serial Number: D60001B9 Card Firmware Revision: 0109 Initialization has failed -> Security Card is expired. so i try to many but not work 3 nother pc but update is error 500 no have antivirus and firewall pls help |
![]() | #596 (permalink) | |
![]() | #597 (permalink) |
Major Poster ![]() ![]() Join Date: May 2001 Location: Budapest, Hungary Age: 59
Member: 4755 Status: Offline Thanks Meter: 6 | Dear Kaisak! The registration of my box until 2,5 years were the end of emails from karwos the next: "This email was sent to you because you are registered user of Cyclone Box (Device assigned to this mail, Serial Number: C000188C, Activated at: 2009-09-02). If you don't want to receive furhter mails, reply to this mail." From march(?) of 2012 the end of emails from karwos is changed (but my E-mail address is the same!!!): "This email was sent to you because you are registered user of Cyclone Box (Device assigned to this mail, Serial Number: C000119C, Activated at: 2009-07-20). If you don't want to receive furhter mails, reply to this mail." My box were never open, never repaired, the original strip is untouched. Last working day of my box was the next log: "Nokia DCT4/WD2/BB5 Service Tool Initialization Started, Engine Revision: 1.0.1.713 Establishing Connection with Box in Main Mode... Handling device: [Cyclone Team], [Cyclone Bootloader], [Platform: Classic] Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic] Initializing box... V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012 Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs Box Serial Number: C000188C 2009, wk19 Initializing security card... Card Serial Number: D3000129 Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 5,14v PASSED MCU Voltage 3,30v PASSED Core Voltage 1,78v PASSED VBAT Voltage 0,01v PASSED VBAT Voltage 5,10v PASSED Box VPP disabled VPP Voltage 0,04v PASSED Internal Box VPP Enabled VPP Voltage 5,06v PASSED Box VPP disabled VPP Voltage 0,07v PASSED External Box VPP Enabled VPP Voltage 0,04v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE XGold/Blackberry Service Running, Counter: 100 Avaiable Physical Memory: 3.1023GB Avaiable Virtual Memory: 1.781GB Avaiable Pagefile: 3.1023GB Initializing FBUS... All initialized - Ready to work" I have never a box with serial number C000119C !!!! I have in july of 2009 NO Cyclone box, i buyed first time in begin of september. This may not be my mistake!!!!! Please clear the situation ASAP!!!!! |
![]() | #598 (permalink) | |
problem with my cyclone box.box is not in needed mode | samih127 | Cyclonebox | 18 | 06-12-2010 06:05 |
Box is not in needed mode [SOLVED] | renren | Cyclonebox | 2 | 01-19-2010 22:38 |
::solve:: box is not in needed mode | mr khalid | Cyclonebox | 6 | 09-15-2009 08:36 |
Cyclone team (not connected) box is not in needed mode | tims | Cyclonebox | 17 | 06-29-2009 03:54 |
Box is not in needed mode. | masterunlock | Cyclonebox | 5 | 03-24-2009 16:44 |
