@ q_ilabo_t Hi, here you answer: http://forum.gsmhosting.com/vbb/show...37&postcount=1 " 3- VBAT Supply test fail " and make sure you don t have conected anyting to "Service port" when you start the software BR |
hi all, i'm a newbie here, can i know how to check the problem "vbatt Supply test fail"? where to check? any picture can post here how to check? thanks!!! |
Cyclone Support Check This Problem with YOUR NEW Boxes what about this problem got new BOX Register OK after that BOX Maintenance OK Now if open Software you can USE only BOX Maintenance Option work profect check Pic and if click on DCT4/WD2/BB5 BOX alway's give this msg Initialization has failed -> No connection was established, or box is not in needed mode reconnect Box restart Pc reinstall sw Change USB cable Change Port change PC what to Do. not only one facing this problem this is my 3rd Box same ERROR any other Box work fine on same port |
Unplug And Plug Again IF same Then Here is Little Help. http://forum.gsmhosting.com/vbb/showthread.php?t=797559 |
read carefully Bro reconnect Box restart Pc reinstall sw Change USB cable Change Port change PC what to Do. already done those Step you hav'nt check Pic if any problem with driver then How came Box MAINTANENCE work fine every time Only other Option not see some more Pic http://img199.imageshack.us/img199/3990/cardmanager.jpg in bottom it's show box connected same if read creadts http://img3.imageshack.us/img3/865/creditsmk.jpg same shows box connected but ERROR same Initialization has failed -> No connection was established, or box is not in needed mode |
For Maintenance Box Need only Boot loader Mode And For Other Operation Need Main Mode ,And If You Dont Install Driver of Main mode So Always Face Error. |
i think you have driver problem pls remove driver and instal again b.r senkron24 |
where is Cyclone team to sort-Out this Problem |
BR |
Authenthication error -> No connection was established, or box is not in needed mode how many pc i have to try now tell us Cyclone team ............ what's this |
when you click any option like refill card credits DCT4/WD2/BB5 Box just try to connect in MAIN MODE but nothing happend and shown this msg Authenthication error -> No connection was established, or box is not in needed mode |
Problem Solved Credit goes to MR. SiRoYa Problem Solved Credit goes to MR. SiRoYa for Great Support and Help great work SiRoYa really appreciated Thanks |
Glad to see you solve your problem.... i tell you to contact Mr. Siroya... BR |
