03-07-2010, 10:58 | #107 (permalink) |
Registered User Join Date: Feb 2005
Member: 113765 Status: Offline Thanks Meter: 0 | No, it is not working And I can not to make update: ============================ Updating Security Area... Security Area Update Skipped, Not allowed Updating Main Firmware... Main Firmware Update Skipped, Not allowed Updating Secure Bootloader... Secure Bootloader Update Skipped, Not allowed or not needed Disconnected from Cyclone Server Box Maintenance finished successfully |
04-14-2010, 16:05 | #110 (permalink) | |
Freak Poster Join Date: Apr 2004 Location: RIFF BOX Age: 45
Member: 64014 Status: Offline Sonork: 100.1603152 Thanks Meter: 255 | Quote:
this error with out phone conected to box or cable .... change u1 | |
05-09-2010, 09:35 | #111 (permalink) |
Junior Member Join Date: Dec 2007 Location: Indonesian
Member: 649509 Status: Offline Thanks Meter: 2 | Help...... Box VPP disabled Box Selftests Failed -> VPP Supply Voltage test failed, 5.01v is out of valid range Super DCT4 Activation: TRUE Initializing FBUS... All initialized - Ready to work |
06-08-2010, 12:56 | #113 (permalink) |
No Life Poster Join Date: May 2009 Location: Srilanka
Member: 1026122 Status: Offline Sonork: 100.1640842 Thanks Meter: 184 | Dear Cyclone team I have the following error... 2009, wk27 Initializing security card... Card Serial Number: D7000023 Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 4.99v PASSED MCU Voltage 3.29v PASSED Core Voltage 1.79v PASSED VBAT Voltage 1.26v PASSED VBAT Voltage 4.96v PASSED Box VPP disabled VPP Voltage 0.63v PASSED Internal Box VPP Enabled Box Selftests Failed -> VPP Supply Voltage test failed, 0.54v is out of valid range Super DCT4 Activation: TRUE Initializing FBUS... All initialized - Ready to work Scanning avaiable products... Processing C:\Program Files\Nokia\Phoenix\Products\... Found 52 products, Filtering DCT4 Products - wait... Is this is normal or what.....???? also I like to know if I install the firmware eg DCT$ rm-74..it is not coming in the PRODUCT box....so I checked the path...it is ok (crog\nokia\phonex\product..) So what is the problem?? |
06-11-2010, 16:13 | #114 (permalink) | |
Junior Member Join Date: Sep 2006 Location: Hail,KSA/Isabela,PH Age: 38
Member: 354742 Status: Offline Sonork: 88888 Thanks Meter: 18 | dear Cyclone Team, i just want to know what is this is normal or no? this is the logs.... Quote:
TIA. Last edited by squallx2006; 06-11-2010 at 16:21. | |
06-11-2010, 22:21 | #115 (permalink) | |
No Life Poster Join Date: Sep 2006 Location: RETIRED ! Age: 47
Member: 348680 Status: Offline Thanks Meter: 1,273 | Quote:
Check the first ( #1 ) post of this thread.... in that post is your answer... BR | |
The Following User Says Thank You to ptt For This Useful Post: |
06-13-2010, 07:35 | #116 (permalink) | |
Member: 1026122 Status: Offline Sonork: 100.1640842 Thanks Meter: 184 | Quote:
Dear CYCLONE Team ... I am waiting for Your answer....Pls advice me. | |
06-13-2010, 14:30 | #117 (permalink) |
Member: 348680 Status: Offline Thanks Meter: 1,273 | @ sky_finder Read this post: http://forum.gsmhosting.com/vbb/5952329-post115.html and about the path & flash files, if your flash file dont have inside the VPL file, Cyclone dont read it....in this case you must select the files manually. BR |
08-02-2010, 07:22 | #120 (permalink) |
Freak Poster Join Date: Sep 2005 Location: quantity or quality? :)
Member: 179142 Status: Offline Thanks Meter: 42 | please help me sir. Started box selftests procedure USB Voltage 4,79v PASSED MCU Voltage 3,30v PASSED Core Voltage 1,79v PASSED Box Selftests Failed -> VBAT Supply Voltage test failed, 3,93v is out of valid range Super DCT4 Activation: TRUE Initializing FBUS... All initialized - Ready to work i've resolder the lm3526 but remain the same the board was a bit hot, the usb led on some operation is blink after the nokia tool opened the led is off(is it normal) but the vbat led was always on ps : my box was loose the warranty already |
Box Selftests Failed -> VBAT Supply Voltage test failed, 4.17v is out of valid range | kosta25 | Cyclonebox | 2 | 11-04-2009 13:40 |
Box Selftests Failed -> VBAT Supply Voltage test failed, 4.08v is out of valid range | azad4u | Cyclonebox | 7 | 07-08-2009 14:48 |
just got box, dont know what to do | masterunlocking | VygisToolbox | 2 | 11-11-2007 17:36 |
6280 flashing failed! what to do? | rakhpai | Universalbox | 2 | 08-10-2006 18:33 |
