![]() | #121 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Sep 2006 Location: RETIRED ! Age: 48
Member: 348680 Status: Offline Thanks Meter: 1,273 | Check if the Ic that get hot is the U1 ( LM3526 located mear the RJ-48 sockets at top side of the PCB ) I think you need to replace it ( it is the VBAT IC SW ) BR |
![]() | #122 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Sep 2005 Location: quantity or quality? :)
Member: 179142 Status: Offline Thanks Meter: 42 | @ptt i've change the lm3526 here is the logs Card is activated Box is activated Started box selftests procedure USB Voltage 4,69v PASSED MCU Voltage 3,30v PASSED Core Voltage 1,78v PASSED VBAT Voltage 0,01v PASSED VBAT Voltage 4,63v PASSED Box VPP disabled VPP Voltage 0,04v PASSED Internal Box VPP Enabled VPP Voltage 4,70v PASSED Box VPP disabled VPP Voltage 0,04v PASSED External Box VPP Enabled VPP Voltage 0,02v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE Initializing FBUS... All initialized - Ready to work Processing pre-flash tasks... Pre-flash tasks finished Booting UPP... Box VPP disabled Processing Flash Image Failed -> UPP Not Responding Failed to Flash -> Problem with processing MCU Image file but it wont detected a phone, is it a cable problem? Last edited by derrytea; 08-04-2010 at 12:36. |
![]() | #123 (permalink) |
Insane Poster ![]() ![]() ![]() Join Date: Jul 2006
Member: 312000 Status: Offline Thanks Meter: 3 | Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia Application v01.46, (Jul 24 2010 23:54:36, gcc v4.3.2, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2010 wk27 Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs Box Serial Number: C00002D3 HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2008, wk32 Initializing security card... Card Serial Number: D00000C0 Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 5.02v PASSED MCU Voltage 3.28v PASSED Core Voltage 1.82v PASSED VBAT Voltage 0.00v PASSED VBAT Voltage 4.91v PASSED Box VPP disabled VPP Voltage 0.04v PASSED Internal Box VPP Enabled VPP Voltage 5.01v PASSED Box VPP disabled VPP Voltage 0.04v PASSED External Box VPP Enabled VPP Voltage 0.02v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE Initializing FBUS... All initialized - Ready to wo Support Check This Problem |
![]() | #124 (permalink) |
Member: 348680 Status: Offline Thanks Meter: 1,273 | @ derrytea Now your box seems to be fine ( the Selftest is OK ) Is your phone in "localmode" ? Maybe cable problem, check cable, also clean phone contacts, and before try to flash do a "Check Flashing Bus" and see if all ok. BR |
![]() | #125 (permalink) | ||
Member: 348680 Status: Offline Thanks Meter: 1,273 | @ ibragulf Quote:
![]() | #126 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2002 Location: Satcom Bangalore INDIA Age: 54
Member: 17098 Status: Offline Thanks Meter: 51 | Need Cyclonebox Schematics Dear Support Team, My Cyclonebox service port rj-45 pin is damaged.......I replaced with new one, Now i get the following responsc....... Handling device: [Cyclone Team], [Cyclone Bootloader] Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia Application v01.46, (Jul 24 2010 23:54:36, gcc v4.3.2, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2010 wk27 Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs Box Serial Number: xxxxxxxx HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2008, wk32 Initializing security card... Card Serial Number: xxxxxxxx Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure Box Selftests Failed -> USB Supply Voltage test failed, 0.01v is out of valid range Super DCT4 Activation: TRUE Initializing FBUS... All initialized - Ready to work Help me by posting Cyclonebox Schematics. Regards Satcom |
![]() | #127 (permalink) |
Member: 348680 Status: Offline Thanks Meter: 1,273 | @ ssatcom Connect the usb cable to your box, and measure the voltage at pin 1 of the LM3940 ( located at bottom side of the PCB ) if you get 5V all is OK your box only have "calibration resistor" problem, just disable "Box Selftest" in settings and continue using your Cyclone Box. LM3940 is a 3,3V regulator, pinout is: 1: IN (5V) 2: GND 3: OUT (3,3V) BR |
The Following User Says Thank You to ptt For This Useful Post: |
![]() | #128 (permalink) | |
Member: 17098 Status: Offline Thanks Meter: 51 | Quote:
Give me the resistor value of R55 and R4 , This two resistor are mising my box. | |
![]() | #130 (permalink) |
Member: 17098 Status: Offline Thanks Meter: 51 | Thanks Mr.ptt, Now my box working fine......... Handling device: [Cyclone Team], [Cyclone Bootloader] Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia Application v01.46, (Jul 24 2010 23:54:36, gcc v4.3.2, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2010 wk27 Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs Box Serial Number: xxxxxxxx HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2008, wk32 Initializing security card... Card Serial Number: xxxxxxxx Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 4.99v PASSED MCU Voltage 3.29v PASSED Core Voltage 1.86v PASSED VBAT Voltage 0.01v PASSED VBAT Voltage 4.91v PASSED Box VPP disabled VPP Voltage 0.00v PASSED Internal Box VPP Enabled VPP Voltage 4.83v PASSED Box VPP disabled VPP Voltage 0.09v PASSED External Box VPP Enabled VPP Voltage 0.04v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE Initializing FBUS... All initialized - Ready to work |
![]() | #132 (permalink) | |
Member: 179142 Status: Offline Thanks Meter: 42 | Quote:
for bb5 phone, it was detected but stuck at 2nd loader (using adapter or without adapter its still the same), heres the log Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006030C192101033000 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 0CA0000E61297D5653D16C7242203992C4C437EA CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! Searching for BootCode: DualLine 32Bit RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.6.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL Prepare phone failed with message -> CMT Secondary Loader was not accepted Failed to Check BB5 Flashing Bus -> Failed to Boot / Prepare Phone and if i bent the cable up (in front of rj48 service socket) everything seems to be fine for both dct4 or bb5 phone... heres the log Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006030C192101033000 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 0CA0000E61297D5653D16C7242203992C4C437EA CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! Searching for BootCode: DualLine 32Bit RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.6.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL FlashChip[0,CMT]: 0x0089898200008A31, Intel, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit FlashChip 0x00898982 (Intel), Size: 64MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.6.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 0C917F11196FDB7378C18EF7260698CA4489DCA0 APE Boot skipped on user request Flashbus Write baud set to 5.0Mbits Restarting MCU... @ptt i would like to trace the tx and rx of the box could you help me? i gotta feeling there was some resistor or capacitor damaged ![]() ![]() | |
![]() | #133 (permalink) | |
i wonder, will supporter help me here? | |
![]() | #134 (permalink) |
Member: 348680 Status: Offline Thanks Meter: 1,273 | On August 27 i sent PM answering your PM ( sent on august 27 ) an tell to you that i dont have the full schematics of the Box and also i tell you to Contact Kaisak on ICQ about your issue. what else you want ? BR |
![]() | #135 (permalink) | |
![]() 2nd i was contact kaisak on ym but seems to be doesnt have any information about the schematics.... kaisak says only mr. karwos has it. and he wasnt at the office then i pointed this thread to kaisak so mr. karwos will notice it if he was available. but untill today it seewms that he wasnt available at this thread ![]() | |
Box Selftests Failed -> VBAT Supply Voltage test failed, 4.17v is out of valid range | kosta25 | Cyclonebox | 2 | 11-04-2009 13:40 |
Box Selftests Failed -> VBAT Supply Voltage test failed, 4.08v is out of valid range | azad4u | Cyclonebox | 7 | 07-08-2009 14:48 |
just got box, dont know what to do | masterunlocking | VygisToolbox | 2 | 11-11-2007 17:36 |
6280 flashing failed! what to do? | rakhpai | Universalbox | 2 | 08-10-2006 18:33 |
