07-30-2009, 22:41 | #1 (permalink) |
Freak Poster Join Date: Apr 2004 Location: RIFF BOX Age: 45
Member: 64014 Status: Offline Sonork: 100.1603152 Thanks Meter: 255 | Box Selftests Failed -> VBAT Supply nitializing box... Box Firmware: Cyclone Nokia Application v1.05, (Jun 22 2009 12:23:29, gcc-4.2.2, RTOS v5.2.0), Type: Signed Production Application, Flags: CONST-TX2-PIN ; VISTA-SUPPORT ; BB5-NCK-CALC Box Serial Number: C0000CBF HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk01 / wk06 Initializing security card... Card Serial Number: D20006B9 Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 5.03v PASSED MCU Voltage 3.28v PASSED Core Voltage 1.78v PASSED VBAT Voltage 2.02v PASSED Box Selftests Failed -> VBAT Supply Voltage test failed, 2.24v is out of valid range Initializing FBUS... where is the problem |
07-30-2009, 23:01 | #2 (permalink) |
No Life Poster Join Date: Sep 2006 Location: RETIRED ! Age: 47
Member: 348680 Status: Offline Thanks Meter: 1,273 | Hi, conect an F-Bus cable, and check if the voltage present at BAT terminals.... If you get 2,4V your box is faulty, contact your reseller.... If 4,2V or more all is OK, just thick "Skip Box selftest" in General settings... BR |
07-31-2009, 02:42 | #3 (permalink) |
Member: 64014 Status: Offline Sonork: 100.1603152 Thanks Meter: 255 | my pcb is new interface [IMG]Photo-0049.jpg (587 KB)[/IMG] |
07-31-2009, 06:07 | #4 (permalink) | |
No Life Poster Join Date: Nov 2004 Location: Capetown
Member: 91045 Status: Offline Thanks Meter: 8,696 | Quote:
then its box problem but u can skip box self tests and work (in settings then general) | |
07-31-2009, 21:37 | #6 (permalink) |
Member: 348680 Status: Offline Thanks Meter: 1,273 | @ HackGsm Check te voltage at the Battery terminals of the F-Bus Cable (conect to service port without a phone) or if you have a UNIFBUS cable, conect it, and check with a multimeter the voltage between RED (+) clip and Black (GND) clip, if you get a value near to 4 - 5 V your Box is OK, dont worry.... if you measure the 2.24v ( as Box selftest say ) your Box have a HW problem.... BR |
08-01-2009, 04:51 | #7 (permalink) |
Member: 91045 Status: Offline Thanks Meter: 8,696 | if u search previous threads few users get this problem before ...either u can exchange BOX as its in under 6 month warrenty or Skip BOXselftest as i said above |
Box Selftests Fail, What to do.... | ptt | Cyclonebox | 154 | 05-21-2013 19:02 |
Box Selftests Failed -> VBAT Supply Voltage test failed, 4.17v is out of valid range | kosta25 | Cyclonebox | 2 | 11-04-2009 13:40 |
Box selftests fail? | Fredde_GSM | Cyclonebox | 7 | 08-09-2009 17:52 |
Box Selftests Failed -> VBAT Supply Voltage test failed, 4.08v is out of valid range | azad4u | Cyclonebox | 7 | 07-08-2009 14:48 |
Box Selftests Failed | hassan1975 | Cyclonebox | 5 | 05-16-2009 20:52 |
