07-03-2009, 05:46 | #1 (permalink) |
No Life Poster Join Date: Apr 2007 Location: DUBAI, UAE
Member: 497374 Status: Offline Sonork: 1587252:AZAD Thanks Meter: 93 | Box Selftests Failed -> VBAT Supply Voltage test failed, 4.08v is out of valid range AND OTHER MESSAGE IS BOX AS FAILED ONE OR MORE SELFTESTS DIAGNOSTIC . THIS MAY BE TEMPORARY FAILURE , OR PERMANENT HW DAMAGE . CONTACT SUPPORT IF ANY PROBLEM WITH USING THIS DEVICE WILL OCCUR .THIS IS THE MAIN POBLEM PLEASE HELP ME I WAS NEW USER FOR THIS BOX . |
07-03-2009, 21:45 | #5 (permalink) |
No Life Poster Join Date: Sep 2006 Location: RETIRED ! Age: 47
Member: 348680 Status: Offline Thanks Meter: 1,273 | This error apear with a phone conected to the box? Try only Box, no phone, no F-Bus cable conected to the Box... Are you using a USB Hub? Try direct to PC USB port... |
07-03-2009, 22:17 | #6 (permalink) | |
No Life Poster Join Date: Oct 2008 Location: HPS
Member: 878925 Status: Offline Sonork: ;-) Thanks Meter: 786 | Quote:
also connect all you want after the Box Selftests , BR . | |
07-08-2009, 14:48 | #8 (permalink) |
No Life Poster Join Date: Feb 2005 Location: Poland Age: 34
Member: 117496 Status: Offline Sonork: 100.83919 Thanks Meter: 22,689 | It is not big problem in fact, it may be because of connected phone which taking too much current upon startup, so you can ignore it at all. |
VBAT Supply Voltage test failed!? | hrco | Cyclonebox | 10 | 03-22-2010 14:45 |
usb supply voltage test failed 4.02v | bakkougsm | Cyclonebox | 3 | 01-28-2010 19:14 |
Box Selftests Failed -> VBAT Supply Voltage test failed, 4.17v is out of valid range | kosta25 | Cyclonebox | 2 | 11-04-2009 13:40 |
Box Selftests Failed -> VBAT Supply | hackgsm | Cyclonebox | 6 | 08-01-2009 04:51 |
phone has network signal but operator says out of network range | SuperPurgen | Hardware Repair by brands | 0 | 05-21-2008 13:55 |
