![]() | #1 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Aug 2006 Location: Nord Romania Age: 43
Member: 323481 Status: Offline Thanks Meter: 43 | Box Selftests Failed -> VBAT Supply Voltage test failed, 4.17v is out of valid range Box Selftests Failed -> VBAT Supply Voltage test failed, 4.15v is out of valid range. I never used a power suply to the box and from the begining, without to conect one phone, I got the error.. I have contacted the resseler and his advice was to change LM340IS. Thats I have done already. But the error is the same .... Box Selftests Failed -> VBAT Supply Voltage test failed, 4.15v is out of valid range. The box not work good...i became erros when i press check flash bus, phone is not stable in test mode or test mode missing at all. I have tryed with and without TMA adaptor ver. 2. I have tryed in two computers also. Please help! Last edited by kosta25; 11-03-2009 at 13:32. |
![]() | #2 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Sep 2006 Location: RETIRED ! Age: 48
Member: 348680 Status: Offline Thanks Meter: 1,273 | check ( with a multimeter ) if you have the correct voltage at F-Bus Battery contacts.... or if using an Unifbus, between red an black clips ( normal values are close to USB Voltage ). And the IC that switches the VBAT is the U3 ( LM1950T ) ( or CS8240 or LM3526H in the newest Box HW rev. ) not the LM3940IS ( it is the 3.3V voltaje reg for the AT32UC3A1512 ) . BR |
![]() | #3 (permalink) |
Member: 323481 Status: Offline Thanks Meter: 43 | The output voltage is 4.15v and is the same indicated by the box. But somes phones are not stable in test mode with this voltage. I have tryed another box and is big differece...I will send back tro resseler. Thanks ! Last edited by kosta25; 11-04-2009 at 13:47. |
VBAT Supply Voltage test failed!? | hrco | Cyclonebox | 10 | 03-22-2010 14:45 |
usb supply voltage test failed 4.02v | bakkougsm | Cyclonebox | 3 | 01-28-2010 19:14 |
Box Selftests Failed -> VBAT Supply | hackgsm | Cyclonebox | 6 | 08-01-2009 04:51 |
Box Selftests Failed -> VBAT Supply Voltage test failed, 4.08v is out of valid range | azad4u | Cyclonebox | 7 | 07-08-2009 14:48 |
phone has network signal but operator says out of network range | SuperPurgen | Hardware Repair by brands | 0 | 05-21-2008 13:55 |
