![]() | #1 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2011 Location: Cuba
Member: 1484663 Status: Offline Thanks Meter: 344 | c5-03 rm 697 CanŽt write rpl Establishing Connection with Box in Main Mode... Handling device: [Cyclone Team], [Cyclone Bootloader], [Platform: Classic] Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic] Initializing box... Box Firmware: Cyclone Main Application v02.11, (Nov 10 2012 00:51:46, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012 Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs Box Serial Number: C0004A00 HW Revision: B, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk45 / 2008, wk35 Initializing security card... Card Serial Number: D003022E Card Firmware Revision: 010A Card is activated Box is activated Started box selftests procedure USB Voltage 5.03v PASSED MCU Voltage 3.26v PASSED Core Voltage 1.77v PASSED VBAT Voltage 0.50v PASSED VBAT Voltage 5.02v PASSED Box VPP disabled VPP Voltage 0.04v PASSED Internal Box VPP Enabled VPP Voltage 4.92v PASSED Box VPP disabled VPP Voltage 0.02v PASSED External Box VPP Enabled VPP Voltage 0.04v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE XGold/Blackberry Service Running, Counter: 92 Avaiable Physical Memory: 2.589GB Avaiable Virtual Memory: 1.793GB Avaiable Pagefile: 3.1023GB Initializing FBUS... All initialized - Ready to work MCU Version V ICPR82_11w25.7 MCU Date 05-12-11 Product RM-697 (Nokia C5-03) Manufacturer (c) Nokia IMEI 12345610654321? IMEI Spare 1A32541660452301 IMEI SV 1332541660452301F7000000 PPM 256qPIHCI Version 12 (rev. 8192). LMP Version 12 (rev. 0). Manufacturer 12652.n256iV 22.0.007j V 22.0.00722.0.00722.0.007učk10.0.031_v0.002 PSN 30C4521AA Product Code 059C507 Module Code 0204650 Basic Product Code 059B215 PSD 0000000000000000 LPSN 0 APE SW V 22.0.007 APE Variant V 22.0.00722.0.00722.0.007 APE Test 10.0.031_v0.002 APE HW 256 APE ADSP 256 APE BT HCI Version 12 (rev. 8192). LMP Version 12 (rev. 0). Manufacturer 12652. RETU 40 TAHVO 00 AHNE 11 HW 4000o256qPIHCI Version 12 (rev. 8192). LMP Version 12 (rev. 0). Manufacturer 12652.n256iV 22.0.007j V 22.0.00722.0.00722.0.007učk10.0.031_v0.002 PCI o256qPIHCI Version 12 (rev. 8192). LMP Version 12 (rev. 0). Manufacturer 12652.n256iV 22.0.007j V 22.0.00722.0.00722.0.007učk10.0.031_v0.002 UEM 256qPIHCI Version 12 (rev. 8192). LMP Version 12 (rev. 0). Manufacturer 12652.n256iV 22.0.007j V 22.0.00722.0.00722.0.007k10.0.031_v0.002„22.0.000_ 014_U001 UPP 256qPIHCI Version 12 (rev. 8192). LMP Version 12 (rev. 0). Manufacturer 12652.n256iV 22.0.007j V 22.0.00722.0.00722.0.007k10.0.031_v0.002„22.0.000_ 014_U001 RFIC |Vapaus_6.5 | Mikki_1.1 DSP 11w48 LCD 256qPIHCI Version 12 (rev. 8192). LMP Version 12 (rev. 0). Manufacturer 12652.n256iV 22.0.007j V 22.0.00722.0.00722.0.007učk10.0.031_v0.002„22.0.00 0_014_U001 BT 256qPIHCI Version 12 (rev. 8192). LMP Version 12 (rev. 0). Manufacturer 12652.n256iV 22.0.007j V 22.0.00722.0.00722.0.007učk10.0.031_v0.002„22.0.00 0_014_U001 ADSP Sw 256qPIHCI Version 12 (rev. 8192). LMP Version 12 (rev. 0). Manufacturer 12652.n256iV 22.0.007j V 22.0.00722.0.00722.0.007k10.0.031_v0.002 ADSP DevID 256qPIHCI Version 12 (rev. 8192). LMP Version 12 (rev. 0). Manufacturer 12652.n256iV 22.0.007j V 22.0.00722.0.00722.0.007učk10.0.031_v0.002 ADSP RevID 256qPIHCI Version 12 (rev. 8192). LMP Version 12 (rev. 0). Manufacturer 12652.n256iV 22.0.007j V 22.0.00722.0.00722.0.007k10.0.031_v0.002„22.0.000_ 014_U001 AEM 256qPIHCI Version 12 (rev. 8192). LMP Version 12 (rev. 0). Manufacturer 12652.n256iV 22.0.007j V 22.0.00722.0.00722.0.007k10.0.031_v0.002„22.0.000_ 014_U001 Flip MCUSW 256qPIHCI Version 12 (rev. 8192). LMP Version 12 (rev. 0). Manufacturer 12652.n256iV 22.0.007j V 22.0.00722.0.00722.0.007učk10.0.031_v0.002„22.0.00 0_014_U001 Failed to read info -> Failed to read SP info Ok, i I flashed the phonewith a higher version I got buckups of both pm and rpl. IŽm using Yellow adapter with GPG 2012 clamps and getting this error when I try to recover RPL: Skipping RPL decryption... Parsing decrypted RPL... Processing FBUS Part... Writing Product Code... Writing PSN... Writing HWID... Writing Simlock... Handling as SL3 Simlock Data Handling as SIMLOCK1 Format Reading Security Block... Security block OK and saved to "RM-697_12345610654321_4272013_21233 PM.SecurityBlock.PM" 20 Digits NCK Found Simlock ACCEPTED OK ! Writing Superdongle key... Superdongle Key ACCEPTED OK ! Writing CMLA key... CMLA Key ACCEPTED OK ! Writing WMDRM PD Data... WMDRM PD Data ACCEPTED OK ! Processing FLASHBUS Part... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000030000022600010007600C192102031104 CMT_EM_ASIC_ID: 00001040 CMT_EM_ASIC_ID: 00001060 CMT_PUBLIC_ID: 23B0000643DC034455F84E87E44994CAE9FD38D4 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 916F75217F32081248B15C38DFC8E81B CMT_BOOT_ROM_CRC: E693EF0D CMT_SECURE_ROM_CRC: AC22615B CMT Ready! Searching for BootCode: DualLine 32Bit RAPUv11_2nd.fg, Type: 2nd Boot Loader, Rev: 768.12.14.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. CBUS Request Error -> CBUS Response wrong header Prepare phone failed with message -> Failed to get CMT Configuration Failed to Write RPL File -> Failed to Boot / Prepare Phone What can I do? ![]() |
