GSM-Forum (https://forum.gsmhosting.com/vbb/)
-   Cyclonebox (https://forum.gsmhosting.com/vbb/f528/)
-   -   Complete guide to the unlock of SL3 mobiles using oclhashcat-lite (https://forum.gsmhosting.com/vbb/f528/complete-guide-unlock-sl3-mobiles-using-oclhashcat-lite-1279759/)
benguetcowboy1 06-02-2011 09:11
2 Attachment(s)
simplified instructions below is for ati amd gpu cards using windows7, 32 and 64bit system only other gpu is not included since it takes years to calculate master code...
1. download and extract to c:\ Download oclHashcat-lite-0.05.7z - hashcat, advanced password recovery
http://i83.photobucket.com/albums/j3...tcowboy1/1.jpg
2. download and extract the attached bat file (short-cut to hashcat folder to save time on typing)
http://i83.photobucket.com/albums/j3...tcowboy1/2.jpg
3. prepare a command line from readed bruteforce data (refer to attached sample command line and edit with your readed data)
ex:
oclHashcat-lite64 96F68C3C9EBE65ACEDFC5D57FF2E7C4EFB23F869:003527100497509600 -1 00010203040506070809 -m 1900 ?1?1?1?1?1?1?1?1?1?1?1?1?1?1?1 -n 160 --outfile-format=1 --outfile=352710049750969_COD.txt
red line represents sha (40 digit)
yellow is your imei (14 digit)
violet is your imei (15 digit)
light blue (use oclHashcat-lite64 if using 64bit system, use oclHashcat-lite32 if using 32bit system
or simply run the bat file readed by cyclone in your hashcat folder and voila!!
sample for 32 and 64 bit system below:
http://i83.photobucket.com/albums/j3...tcowboy1/3.jpg
http://i83.photobucket.com/albums/j3...tcowboy1/4.jpg
4. how to use restore (do not run bat file again or run the command line else lbf will start from 0%) simply use the following restore commands
for Windows 7 64 bit ATI AMD Card
oclHashcat-lite64 --restore
for Windows 7 32 bit ATI AMD Card
oclHashcat-lite32 --restore
ex.
http://i83.photobucket.com/albums/j3...tcowboy1/5.jpg
http://i83.photobucket.com/albums/j3...tcowboy1/6.jpg
5. How to skip scan (can be used if restore bin is deleted or corrupted) use only if you are sure of where your lbf job stopped.
sample below shows how to start or resume scan at 60% you may edit according to what you want just add --pw-skip=60000000000
oclHashcat-lite64 --pw-skip=60000000000 170EC9542B716B72A3FA195C1F320B53A126A95F:003533820 451534800 -1 00010203040506070809 -m 1900 ?1?1?1?1?1?1?1?1?1?1?1?1?1?1?1 -n 160 --outfile-format=1 --outfile=353382045153488.txt
ex.
http://i83.photobucket.com/albums/j3...tcowboy1/7.jpg
good luck!
Mr.3. 06-02-2011 10:29
How To read HASH , BruteForce , Unlock Via cyclone
With Simple screenshot
http://www.moulnisky.com/infos1.jpg
Read HASH Via Cyclone And save it
http://www.moulnisky.com/readlbf1.jpg
Pick the cmd file related to your card and version of operative system and copy it in the oclhashcat-lite folder
http://www.moulnisky.com/files1.jpg
Click BAT File
http://www.moulnisky.com/brutefor1.jpg
After Bruteforce success , Send to server to calculate the code
http://www.moulnisky.com/send1.jpg
After calculate code successfully, Send via FBUS
http://www.moulnisky.com/unlock1.jpg
ALL DONE
http://www.moulnisky.com/newinfos1.jpg
Always Thanks to my dearest friend ALEX
delchoni 06-06-2011 20:29
nice info aout sl3 bruteforce
Chevka 06-07-2011 05:11
Please give us sample command for start at 60%-100% then go back to 60%-00% or
40%-70% then 100%-70% then 40%-00%
is it posibble to make in one command?
benguetcowboy1 06-07-2011 05:37
60%-100% then back to 0%-50%
oclHashcat-lite64 D510319CA27F8207003ED34B13169838F8B8AE16:003593700 373538900 -1 00010203040506070809 -2 06070809000102030405 -m 1900 ?1?1?1?1?1?1?1?1?1?1?1?1?1?1?2 -n 160 --outfile-format=1 --outfile=359370037353897_COD.txt
edit with your data and no space between imei
jam_mobile 06-08-2011 10:04
plz tell me ,how to use in xp ????
Gathering 06-08-2011 10:31
It's the same, but on XP only work with one card!
tornillo 06-25-2011 23:39
someone could help me .. I need to comand to various imeis . once you finish one, continue on the other. would be like to create the file. bat?
is this is possible .. anybody can helpme . tnks
SPUnlock_SK 07-06-2011 17:08
yes you can create one bat file with several IMEIs (command lines)
just put/paste each command line in one 1line
so 1st line 1st phone cmd line
2nd line - 2nd phone cmd line
azo_ja 07-07-2011 14:48
After oclhashchat LBF cyclone wrong sp codes given. Why?
This Calculating NCK Codes for IMEI 351536045639976 from cyclone
#pw+322079842368638+1#
#pw+070827550722020+2#
#pw+078949343172405+3#
#pw+499665119829929+4#
#pw+982542100848011+5#
#pw+753886540701682+6#
#pw+877329874175644+7#
Finished
this good
#pw+673223145651861+1#
#pw+904878766857834+2#
#pw+233538467742495+3#
#pw+601868682878995+4#
#pw+553395685475267+5#
#pw+292279526916251+6#
#pw+679179191642446+7#
this cyclone codes
Calculating NCK Codes for IMEI 354321043819608
#pw+866911653892792+1#
#pw+377547194153119+2#
#pw+099254818834043+3#
#pw+437814030044015+4#
#pw+284127616698652+5#
#pw+737723789530961+6#
#pw+955988979029638+7#
Finished
this good#pw+705353231388219+1#
#pw+550515998495220+2#
#pw+887196533199683+3#
#pw+205101739469235+4#
#pw+817310009961475+5#
#pw+200042688790437+6#
#pw+065336109548402+7#
moulnisky 07-08-2011 06:49
Finished
this good
this cyclone codes
Finished
Cyclone server calculates only the level 7 code so where are coming all the other codes?
use the cyclone server to receive the level 7 code.
Some mobiles don't accept the code level 7 then, only for these mobiles, you can use any other software to generate the code level 1 and input via keyboard.
Alex
Pufi164 07-08-2011 07:23
Both are good NCK:
a6cbc994e04dd22f4e435f73d4314ee754bb1cf6:003569180 369940100:040508040401040109020308010702
Fenix:
#pw+551426331521238+7#
Cyclone:
#pw+648375248714479+7#
100% with both
Back locked
Then again unlock.
Dany 07-08-2011 08:48
1 Attachment(s)
Alex,
Can you help me please with this dubt ?
Which .exe need to run for work with ATI 5970 with oclhashcat 0.06 ?
And the file .bat as I read with Cyclone is this ?
3579850323xxxxx_ATI_32bit_oclHashCat
I use (for the moment) 1x5970 Black Edition 4Gb
Win7 32
Thanks and Regards,
BENY99 07-08-2011 09:45
I already use 'command line' as above for the bruteforce process, but never succeeded, always appear 'error window':
oclHashcat-lite32.exe - Application Error
The application failed to initialize properly (0xc0000005 )......
what have I done wrong?
or from my computer that are less supportive?
viral123 07-08-2011 10:18
Alex
Plz upload all Level Code in cyclone softwere
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.14801 seconds with 6 queries
