Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cyclonebox
Old 02-18-2010, 19:45   #151 (permalink)
Member: 839359
Thanks Meter: 13
Originally Posted by moulnisky View Post
It is really simple
Just unlock the mobile using the RPL method
Afterward click on SX4 auth/SD repair and write a good PM 1 and 309
Alex
the good PM can be of other fone working...??
Old 02-18-2010, 19:56   #152 (permalink)
ptt
ptt's Avatar
Member: 348680
Thanks Meter: 1,273
Yes you can use a PM of another "Working" phone ( same model ) only MAKE SURE you have REMOVED fields 120 & 308 ( better if you only leave the fields 1 & 309 )
Si, puedes utilizar la PM de otro telefono ( que sea del mismo modelo ) solo asegurate de que no contenga los campos 120 & 308 ( mejor si la editas y dejas solo los campos 1 & 309 ).
Saludos
The Following User Says Thank You to ptt For This Useful Post:
Old 02-19-2010, 08:00   #153 (permalink)
software zone's Avatar
Member: 494167
Thanks Meter: 292
what about dct4 free rpls.waiting for free standalon dct4 rpl calculater too
Old 02-19-2010, 10:57   #154 (permalink)
Temporary banned !!
Member: 1151970
Sonork: 100.1597000
Thanks Meter: 378
and again not supported 2700c to unlock..........................
Old 02-20-2010, 21:44   #155 (permalink)
Member: 578578
Thanks Meter: 7
Question failed to unlock nokia 6710s,can any boby help me?
Simlock [2,1] State: CLOSED Type: MCC-MNC Data: 21402F
Reading Security Block...
Security block OK and saved to "RM-491_354201032684785_20022010_214227.SecurityBlock. PM"
Determining PA Simlock...
Booting RAP...
CMT_SYSTEM_ASIC_ID: 000000030000022600010007600C192102011104
CMT_EM_ASIC_ID: 00001040
CMT_EM_ASIC_ID: 00001030
CMT_PUBLIC_ID: 0A40020ED360034435877F391199E63039B5ECA8
CMT_ASIC_MODE_ID: 00
CMT_ROOT_KEY_HASH: 25B977A055BE9B5DEC0C38A2A279C695
CMT_BOOT_ROM_CRC: 3E273BF6
CMT_SECURE_ROM_CRC: 37BE26FA
RAPUv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.37.1, Algo: BB5
Flashbus Write baud set to 1.0Mbits
Flashbus Read baud set to 98Kbits
Using OLD BB5 FLASHING PROTOCOL
FlashChip[0,CMT]: 0x00EC004000800121, Samsung, ONENAND
FlashContent[0,CMT]: 00000000000000000000000000000000, ONENAND
FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC
Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit
RAPUv11_algo_xsr16.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: XSR 1.6
Flashbus Write baud set to 2.0Mbits
Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit
Box TX2 Data Pin set to: Service Pin 3
Box VPP disabled
Internal CMT Phone VPP Enabled
PAPUBKEYS Hash for CMT: 2C8ECB6D779267566237E529A80C0802CB8D903E
Testing TX2 Line...
TX2 Line OK!
APE Boot skipped on user request
Flashbus Write baud set to 5.0Mbits
Restarting MCU...
Determined PA Simlock: PA_SL3
BB5 Unlock Failed -> Unsupported PA Simlock
Old 02-20-2010, 21:47   #156 (permalink)
moulnisky's Avatar
Member: 947561
Thanks Meter: 14,049
6710 is a SL3 mobile.. you can't unlock it
Alex
The Following 2 Users Say Thank You to moulnisky For This Useful Post:
Old 02-22-2010, 05:35   #157 (permalink)
Mehvishal's Avatar
Member: 7482
Thanks Meter: 24
trying to repair SD for n95 8gb
failed to repair SD
SX4 Authorization / SD Repair Procedure Started....
"17E001028BB901581B1131FA38DE356D8A92F970.C0000DDA " Exists, That is good...
MCU Version V 06wk41v64.1
MCU Date 26-09-08
Product RM-320
Manufacturer (c) Nokia
IMEI 12345610654321?
Security block OK and saved to "RM-320_12345610654321_2222010_83417 AM.SecurityBlock.PM"
Superdongle Key is probably CORRUPTED, Writing custom keys...
Received SD Keys from box, writing to phone...
Failed to Repair Superdongle Key (Superdongle Key NOT ACCEPTED !), Will use Server and Original Card
SX4 Status: Authorized
Disconnected from Cyclone Server
Old 02-22-2010, 05:43   #158 (permalink)
Mehvishal's Avatar
Member: 7482
Thanks Meter: 24
WARNING: Failed to read RAP Public ID
Reading CYC file from phone...
Booting RAP...
APE_SYSTEM_ASIC_ID: 24200705
APE_ASIC_MODE_ID: 00
APE_PUBLIC_ID: D8C1C270C25BC9F04B5692A5DC46558B3E4D55EF
APE_ROOT_KEY_HASH: BA8710A7E1CD5A2909B9A875DB27AA2400000000
CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103
CMT_EM_ASIC_ID: 00000296
CMT_EM_ASIC_ID: 00000B22
CMT_PUBLIC_ID: 17E001028BB901581B1131FA38DE356D8A92F970
CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE
CMT_BOOT_ROM_CRC: 4B9B7510
CMT_SECURE_ROM_CRC: 3E691FF8
RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5
Exploiting - running preloader...
Preloader running OK, Running Custom Loader...
Custom loader running OK! Working...
Readed OK, Saving to "17E001028BB901581B1131FA38DE356D8A92F970.C0000DDA "
MCU Date 26-09-08
Product RM-320
Read Security Block Problem -> Failed to read PM 308, this is critical
Failed to Repair Superdongle Key (Failed to read Security Block), Will use Server and Original Card
SX4 Status: Not authorized (49)
Started mutual authenthication with card...
Cyclone Server (1.0.0.591), Cyclone Box Team 2008, 2009, 2010 - Ready.
Receiving Phone Seed 1...
Failed to Authorize SX4 -> Failed to receive SX4 Seed Data
Old 02-22-2010, 07:38   #159 (permalink)
m_amien's Avatar
Member: 238204
Thanks Meter: 56
Card is activated
Box is activated
Started box selftests procedure
USB Voltage 5,14v PASSED
MCU Voltage 3,27v PASSED
Core Voltage 1,79v PASSED
VBAT Voltage 0,43v PASSED
VBAT Voltage 4,90v PASSED
Box VPP disabled
VPP Voltage 0,00v PASSED
Internal Box VPP Enabled
VPP Voltage 4,97v PASSED
Box VPP disabled
VPP Voltage 0,04v PASSED
External Box VPP Enabled
VPP Voltage 0,04v FAILED - IGNORED - Probably power supply is not connected
Box VPP disabled
All box selftests passed!
Super DCT4 Activation: TRUE
Initializing FBUS...
All initialized - Ready to work
Booting RAP...
CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101001101
CMT_EM_ASIC_ID: 00000232
CMT_EM_ASIC_ID: 00000353
CMT_PUBLIC_ID: 0C20010517A47A5625CCCE6BB703BF419614093C
CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
CMT_BOOT_ROM_CRC: 191EC665
CMT_SECURE_ROM_CRC: DFAAF68F
RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.9.11.1, Algo: BB5
FlashChip[0,CMT]: 0x0020881C00006A21, ST, NOR
FlashContent[0,CMT]: 00000000000000000000000000000000, NOR
RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.9.17.0, Algo: BB5 ALGORITHM
Box VPP disabled
Warning: PAPUBKEYS Hash Missing!
Testing TX2 Line...
Prepare phone failed with message -> Access violation at address 005901A1 in module 'Cyclone.exe'. Write of address 00000000
Failed to Check BB5 Flashing Bus -> Failed to Boot / Prepare Phone
Old 02-22-2010, 07:50   #160 (permalink)
moulnisky's Avatar
Member: 947561
@Mehvishal,
reinstall again the packaga using the last installer and afterward copying the last exe in the cyclonebox main folder
@m_amien
clean the mobile's pinouts and retry; check you cable as well
Alex
Old 02-22-2010, 08:20   #161 (permalink)
FullFLASHgSMPH's Avatar
Member: 161739
Sonork: 100.1584054
Thanks Meter: 3,338
@Mehvishal,
need backup restore if you have if non wait for updates
@m_amien
need phone local mode 100% cable problem
The Following 2 Users Say Thank You to FullFLASHgSMPH For This Useful Post:
Old 02-22-2010, 10:01   #162 (permalink)
moulnisky's Avatar
Member: 947561
[QUOTE=FullFLASHgSMPH;5464019]@Mehvishal,
You are right didn't check the imei
Thanks
Alex
Old 02-22-2010, 12:24   #163 (permalink)
Mehvishal's Avatar
Member: 7482
Thanks Meter: 24
i got the phone like that
but i already paid to get a calculated rpl for the phone
but phone NOT accepting SD data.
i have rpl for phone
how can i restore the imei and repair SD for this phone?
Old 02-22-2010, 13:51   #164 (permalink)
Crazy Poster
Member: 339490
Thanks Meter: 3
Hello please how to repair rpl
Old 02-22-2010, 14:18   #165 (permalink)
m_amien's Avatar
Member: 238204
Thanks Meter: 56
@FullFLASHgSMPH, @moulnisky
Thx... problem resolve.
Prepare phone failed with message -> Access violation at address 005901A1 in module 'Cyclone.exe'. Write of address 00000000 << but this messages make me worries
CycloneBox !! Standalone : SX4 Emulation, SD Repair, RPL Calc, BB5 NCK Calc, more!!! SiRoYa Main Sales Section 0 03-04-2010 14:52
Cyclone BOMB ! Standalone : SX4 Emulation, SD Repair, RPL Calc, BB5 NCK Calc, Halas HalaGSM WebShop 0 02-12-2010 18:31
Cyclone Update Standalone: SX4 Emulation, SD Repair, RPL Calc, BB5 NCK Calc, more!!! SiRoYa Service Products News & Updates 0 02-12-2010 18:16
Page generated in 0.23163 seconds with 10 queries
