Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cyclonebox
Old 12-26-2012, 08:36   #1 (permalink)
Member: 1562038
Thanks Meter: 35
Cyclone Box reloaded Up Grade Firmware problem. Please help me.
Failed to launch box in Main Mode. Main Firmware wasn't flashed during this session
Hello brothers,
I've updated my cyclone software last week, and since then my box has stopped working.
when i click nokia tool I get this:
Establishing Connection with Box in Main Mode...
Handling device: [Cyclone Team], [Cyclone Bootloader], [Platform: Classic]
Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic]
Initializing box...
CBUS Request Error -> CBUS Problem, Lost handle (Write Pipe)
Box Firmware Version Read Failed -> No answer from CBUS
Initialization has failed -> No connection was established, or box is not in needed mode
when I click box wizard I get this:
Failed to launch box in Main Mode. Main Firmware wasn't flashed during this session. Possible cause: empty firmware, demaged hardware (crystals), damaged security area, drivers problem, OS problem, etc. Service Tag was copied to clipboard.
how can I solve this problem
Thank
Old 12-26-2012, 08:43   #2 (permalink)
Mr.3.'s Avatar
Member: 962029
Sonork: OEM Lock : ON
Thanks Meter: 3,979
post box service tag here....
Old 01-16-2013, 11:31   #3 (permalink)
Member: 654829
Thanks Meter: 44
Cyclone Box Service Tag: D14978185B01B6DD7E194F7396D99874
please i have the same problem,can you please deal with it.
thank you .
Old 01-16-2013, 12:11   #4 (permalink)
Member: 209842
Sonork: 100.93537
Thanks Meter: 3,386
thank you .
please use box wizard
Old 01-16-2013, 12:18   #5 (permalink)
Member: 654829
Thanks Meter: 44
failed to flash security area
team id :
909 587 697
pass:
9yn4i6
can you please check it for me ?
thank you
Old 01-16-2013, 12:19   #6 (permalink)
Member: 654829
Thanks Meter: 44
team id :
909 587 697
pass:
9yn4i6
thank you
Old 01-16-2013, 13:13   #7 (permalink)
Member: 209842
Sonork: 100.93537
Thanks Meter: 3,386
team id :
909 587 697
pass:
9yn4i6
thank you
Password is not valid
Old 01-16-2013, 14:37   #8 (permalink)
Member: 654829
Thanks Meter: 44
726jsg niew pass
thanks
Old 01-16-2013, 15:25   #9 (permalink)
Member: 209842
Sonork: 100.93537
Thanks Meter: 3,386
726jsg niew pass
thanks
contact with me on sonork
Old 01-16-2013, 15:59   #10 (permalink)
Member: 654829
Thanks Meter: 44
done , 100.1625845
thank you again ............
Old 11-20-2013, 02:58   #11 (permalink)
Member: 1119025
Failed to read service tag... please i need your help!
Cyclone Box Service Tag: 6A66CD6C95DD9C784FCD267B4E081630
Old 02-24-2014, 16:23   #12 (permalink)
Member: 2126237
Sonork: 100.1604864
Thanks Meter: 4
Did u uninstall libusb drivers from add/remove program?
In case just use again box wizard
Old 02-26-2014, 06:30   #13 (permalink)
Member: 1381411
Sonork: 10410
Thanks Meter: 4
sir where is the location ..i can'r see libusb in to the control panel addremove
can any one who can guide me.
Old 01-05-2015, 16:26   #14 (permalink)
Member: 236667
Thanks Meter: 6
I got same problem with cyclone :
Cyclone Box Service Tag: DCC253A3F782ECB5E94548905D50D66E.
Can anyone help?
Old 01-19-2015, 13:30   #15 (permalink)
Member: 209842
Sonork: 100.93537
Thanks Meter: 3,386
Can anyone help?
Please try make Box wizard.
If this is not solve Your problem It means reason is on drivers or crystals
The Following User Says Thank You to kaisak For This Useful Post:
Page generated in 0.37847 seconds with 7 queries
