Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cyclonebox
Old 06-11-2009, 11:15   #1 (permalink)
Member: 389669
Sonork: 100.1583354
Thanks Meter: 226
Cool cyclone bug coz n70 read info
i tray to unlock n70 using cyclone but it has a bug
this is log:
Nokia DCT4/WD2/BB5 Service Tool Initialization Started, Engine Revision: 1.0.0.7396
Handling device: [Cyclone Team], [Cyclone Bootloader]
Handling device: [Cyclone Team], [Cyclone Box]
Initializing box...
Box Firmware: Cyclone Nokia Application v1.04, (May 12 2009 00:28:13, gcc-4.2.2, RTOS v5.2.0), Type: Signed Production Application, Flags: CONST-TX2-PIN ; VISTA-SUPPORT
Box Serial Number: C0000000
HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2008, wk27
Initializing security card...
Card Serial Number: D0000000
Card Firmware Revision: 0109
Card is activated
Box is activated
Started box selftests procedure
USB Voltage 5.05v PASSED
MCU Voltage 3.29v PASSED
Core Voltage 1.78v PASSED
VBAT Voltage 0.35v PASSED
VBAT Voltage 4.93v PASSED
Box VPP disabled
VPP Voltage 0.02v PASSED
Internal Box VPP Enabled
VPP Voltage 4.88v PASSED
Box VPP disabled
External Box VPP Enabled
VPP Voltage 0.00v FAILED - IGNORED - Probably power supply is not connected
Box VPP disabled
All box selftests passed!
Initializing FBUS...
All initialized - Ready to work
MCU Version V 05wk07v48
MCU Date 27-03-07
Product RM-84
Manufacturer (c) Nokia.
IMEI 358637014969288
Mastercode 322117470
IMEI Spare 3A85360741692908
IMEI SV 3385360741692918F1000000
PSN CEJ110970
Product Code 0552574
Basic Product Code 0522156
PSD 0000001700000000
RETU 32
TAHVO 53
AHNE 22
HW 7005
RFIC 150a160f
DSP rolf_05wk07v29p1
Failed to read info -> Failed to read SP info
MCU Date 27-03-07
Product RM-84
PPM V 5.0717.3.0.1, 27-04-07, RM-84, (C)Nokiaj0R3n256o16054
PSN CEJ110970
APE SW V 5.0717.3.0.1, 27-04-07, RM-84, (C)Nokia
APE Variant 0R3
APE HW 256
APE ADSP 16054
RETU 32
TAHVO 53
AHNE 22
HW 7005i,'V 5.0717.3.0.1, 27-04-07, RM-84, (C)Nokiaj0R3n256o16054
PCI i,'V 5.0717.3.0.1, 27-04-07, RM-84, (C)Nokiaj0R3n256o16054
UEM V 5.0717.3.0.1, 27-04-07, RM-84, (C)Nokiaj0R3n256o16054
UPP V 5.0717.3.0.1, 27-04-07, RM-84, (C)Nokiaj0R3n256o16054
RFIC 150a160fi,'V 5.0717.3.0.1, 27-04-07, RM-84, (C)Nokiaj0R3n256o16054
DSP rolf_05wk07v29p1i,'V 5.0717.3.0.1, 27-04-07, RM-84, (C)Nokiaj0R3n256o16054
Failed to read info -> Failed to read extended info
MCU Date 27-03-07
Product RM-84
PSN CEJ110970
APE Variant 0R3
APE HW 256
APE ADSP 16054
RETU 32
TAHVO 53
AHNE 22
RFIC 150a160f
LCD V 5.0717.3.0.1, 27-04-07, RM-84, (C)Nokiaj0R3n256o16054
BT V 5.0717.3.0.1, 27-04-07, RM-84, (C)Nokiaj0R3n256o16054
MCU Date 27-03-07
Product RM-84
PSN CEJ110970
RETU 32
TAHVO 53
AHNE 22
HW 7005
RFIC 150a160f
BB5 Unlock Started...
MCU Date 27-03-07
Product RM-84
Warning: Failed to read SP Info, Assuming defaults
BB5 Unlock Failed -> Initial SP corrupted or not a Baseband5 phone detected
Mr KhaliD
Old 06-11-2009, 12:11   #2 (permalink)
Member: 247347
Thanks Meter: 58
I had same problem yesterday with 1pcs of 6300 and today with 1 N95- Rm159.
Old 06-11-2009, 15:32   #3 (permalink)
Member: 1018648
Thanks Meter: 60
I had same problem but phone unlocked.
Please check your N70 it should be unlocked already.
Old 06-11-2009, 16:44   #4 (permalink)
Member: 725226
Thanks Meter: 73
@Mr KhaliD
1 post info of the phone
2 post the self tests on phone
(i think you have SP area damaged and u must repair it)
WBR
Old 06-11-2009, 19:49   #5 (permalink)
moulnisky's Avatar
Member: 947561
Thanks Meter: 14,052
No, is only one little bug with the SL1 phones the new update will solve it.. In the while just click on skip SP info, do back-up PM and unlock...
It will be unlocked and happy ;-)
Alex
Old 06-11-2009, 20:03   #6 (permalink)
Member: 247347
Thanks Meter: 58
Alex
Cyclone have alot of bugs: 6300 not unlocked, N95 not unlocked and more.. I will try your solution.
Anyway a big new update i hope solve it!
Old 06-11-2009, 20:30   #7 (permalink)
Member: 389669
Sonork: 100.1583354
Thanks Meter: 226
@sirbigman
my fone are locked, and i have no problem in sp area, and i unlock it using jaf box,
and this is other N70 had same problem
Initializing box...
Card is activated
Box is activated
MCU Voltage 3.28v PASSED
VBAT Voltage 0.06v PASSED
Box VPP disabled
VPP Voltage 0.04v PASSED
Box VPP disabled
Box VPP disabled
MCU Version V 05wk07v45
MCU Date 29-08-06
Product RM-84
IMEI 356992010000000
Mastercode 50337111
IMEI Spare 3A65990201288609
IMEI SV 3365990201288609F8000000
PSN PPA500177
Product Code 0531876
RETU 32
TAHVO 53
AHNE 22
HW 7003
RFIC 150a160f
DSP rolf_05wk07v29
MCU Date 29-08-06
Product RM-84
Mastercode 50337111
Simlock Server SIMLOCK SERVER VERSION 63
Simlock Key 2440700000000000
Simlock Profile 8000000000000006
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Reading Security Block...
Security block OK!
Determining PA Simlock...
Booting RAP...
APE_SYSTEM_ASIC_ID: 17100701
APE_ASIC_MODE_ID: 00
APE_PUBLIC_ID: FBC2E5E1B88534ACB735A0232C9086BD3ABEE073
APE_ROOT_KEY_HASH: 2C05369F57CC3C4CF9E783E83D9B512B00000000
APE_ROM_ID: AB5E4ADB27A06946
CMT_SYSTEM_ASIC_ID: 000000010000022600010006000C192101002200
CMT_EM_ASIC_ID: 00000232
CMT_EM_ASIC_ID: 00000353
CMT_PUBLIC_ID: 0B40020F26B35A519315985F454476BEF3C03FBE
CMT_ASIC_MODE_ID: 00
CMT_ROOT_KEY_HASH: E9EFF4BFAA5393217CA6B17755FC3E14
CMT_ROM_ID: F28A211FCEA7B19D
RAP3Gv2_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.21.0, Algo: BB5
Flashbus Write baud set to 1.0Mbits
Flashbus Read baud set to 98Kbits
FlashChip[0,CMT]: 0x00EC225000000121, Samsung, NOR
FlashContent[0,CMT]: 00000000000000000000000000000000, NOR
FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC
Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit
RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: BB5 ALGORITHM
Flashbus Write baud set to 4.0Mbits
Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit
Box TX2 Data Pin set to: Service Pin 3
Box VPP disabled
Internal CMT Phone VPP Enabled
PAPUBKEYS Hash for CMT: 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D
APE Boot skipped on user request
Restarting MCU...
Determined PA Simlock: PA_SL
Checking for Rootkey Hash support...
Restarting MCU...
Booting RAP...
Exploiting - running preloader...
Preloader running OK, Running Custom Loader...
BB5 Unlock Failed -> Failed to Boot / Prepare Phone
Old 06-11-2009, 20:41   #8 (permalink)
Member: 247347
Thanks Meter: 58
Mr KhaliD,
For me starts to be funny. we have same problem always.
The solution: we unlock with jaf until cyclone next update or we schoud buy another dongle?
Old 06-11-2009, 20:49   #9 (permalink)
moulnisky's Avatar
Member: 947561
But are you using the tx2 adaptor?
I made lots of 6300 and never had this problem... idem n95.. nut i use a similar of the TMA adapter to solve the power problem
May be more chances you have a cable or power problem.
Alex
Old 06-11-2009, 20:55   #10 (permalink)
Member: 247347
Thanks Meter: 58
Alex
New Phone, New gbpro cable 100% ok, tx2 adaptor, everithing.
like i said i will try to skip SP info.
BR ovidiucosti
Old 06-12-2009, 09:15   #11 (permalink)
Member: 725226
Thanks Meter: 73
@mr khalid
Initializing box...
Box Serial Number:
Card Serial Number:
Card is activated
Box is activated
USB Voltage    5.04v    PASSED
Core Voltage    1.79v    PASSED
VBAT Voltage    0.13v    PASSED
VBAT Voltage    4.66v    PASSED
Box VPP disabled
VPP Voltage    0.00v    PASSED
Box VPP disabled
VPP Voltage    7.88v    PASSED
Box VPP disabled
MCU Date    27-03-07
Product        RM-84
IMEI        356963015253999
Mastercode    622165643
IMEI Spare    3A65690351529309
IMEI SV        3365690351529319F1000000
PSN        CTD936535
RETU        32
TAHVO        53
AHNE        22
HW        7003
RFIC        150a160f
I confirm this is a problem in the loaders i think for this model.
Maybe in next update cyclone team solve this.
WBR
cyclone box after updata firmware, failed to read info dessertcell Cyclonebox 2 11-13-2009 17:40
cannot read info N70, cannot unlock, help hugmax Cyclonebox 18 08-26-2009 19:58
Cyclone Read info problem poonsak Cyclonebox 2 05-04-2009 22:29
kf600 read info bug!! ZIYAAD STRYKER Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) 4 12-11-2008 16:54
N70 unlock ZIZOUT schema + DKU-2 Read info ok,Make log KO! alecuba16 Nokia Base Band 5 ( BB-5 ) 3 05-27-2008 19:59
Page generated in 0.27099 seconds with 9 queries
