08-23-2013, 08:20 | #181 (permalink) | |
No Life Poster Join Date: Dec 2005 Location: Poland
Member: 209842 Status: Offline Sonork: 100.93537 Thanks Meter: 3,386 | Quote:
08-23-2013, 08:21 | #182 (permalink) | |
The Following User Says Thank You to kaisak For This Useful Post: |
08-23-2013, 10:10 | #183 (permalink) |
Cheater -Don't Deal with him- Join Date: Feb 2003 Location: gsmcity Age: 44
Member: 21296 Status: Offline Thanks Meter: 328 | Now box activated but still unable to rot my Lumia 800 Booting CMT... [USB Composite Device]: WinUSB Port opened OK! [USB Composite Device]: WinUSB Port opened OK! [Nokia USB Connectivity]: WinUSB Port opened OK! Switching to RAW Mode... [Nokia USB Connectivity]: WinUSB Port opened OK! [Nokia USB Connectivity]: WinUSB Port opened OK! OSBL Details Protocol: v1.1 Version: v257.6 Build: 12 Failed to Get OSBL Revision -> Failed to Boot CMT -> Failed to get First Boot Block Prepare phone failed with message -> Failed to Boot CMT Write Root Data Failed -> Failed to Boot OSBL Failed to Root Phone -> Rooting Failed |
08-23-2013, 10:23 | #184 (permalink) |
Member: 21296 Status: Offline Thanks Meter: 328 | I have no idea whats going on now after TP activation the same error message Establishing Connection with Box in Main Mode... Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic] Initializing box... Box Firmware: Cyclone Main Application v02.20, (Aug 6 2013 20:32:14, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012 Hardware Platform: Cyclone Reloaded Flasher Interface (c) 2012 KarwosLabs Box Serial Number: B00018EC HW Revision: D, Suitable for: Production, Case: Reloaded Box Casing, MCU Manufacture Time: 2012, wk01 / 2011, wk27 Box is activated Started box selftests procedure USB Voltage 4.86v PASSED MCU Voltage 3.28v PASSED Core Voltage 1.79v PASSED VBAT Voltage 0.03v PASSED VBAT Voltage 4.83v PASSED Box VPP disabled VPP Voltage 0.04v PASSED Internal Box VPP Enabled VPP Voltage 4.83v PASSED Box VPP disabled VPP Voltage 0.02v PASSED All box selftests passed! Super DCT4 Activation: TRUE XGold/Blackberry Service Running, Counter: 100 Lumia No TP is ACTIVATED! Avaiable Physical Memory: 3.1023GB Avaiable Virtual Memory: 1.801GB Avaiable Pagefile: 3.1023GB Initializing FBUS... All initialized - Ready to work Cyclone forthermore is unable to even flash the phone, while BEST does thing easily. Check logs below If phone is alive, It will be automatically swithced to OSBL mode. If software can't switch to OSBL mode, or phone is generally DEAD do folllowing: 1. Turn OFF device, wait 15 seconds afterwards 2. Eject USB cable, wait 10 seconds 3. Press and hold Volume-UP button 4. Insert USB Cable. OSBL should be booted. Booting CMT... [USB Composite Device]: WinUSB Port opened OK! [USB Composite Device]: WinUSB Port opened OK! [Nokia USB Connectivity]: WinUSB Port opened OK! Switching to RAW Mode... [Nokia USB Connectivity]: WinUSB Port opened OK! [Nokia USB Connectivity]: WinUSB Port opened OK! OSBL Details Protocol: v1.1 Version: v257.6 Build: 12 Failed to Get OSBL Revision -> Failed to Boot CMT -> Failed to get First Boot Block Prepare phone failed with message -> Failed to Boot CMT Process ESCO Image Failed -> Failed to Boot OSBL Failed to Flash WP7 -> Failed to Flash All ESCO Images Last edited by byteforce; 08-23-2013 at 10:30. |
08-23-2013, 10:34 | #185 (permalink) |
Member: 21296 Status: Offline Thanks Meter: 328 | BEST flash log below: Code: Phone found! WP7x Nokia Phone detected Read info... Ok === Main Info === Phone : RM-801|NOKIA Lumia 800 Phone SwVer : 1750.0823.8858.12460 Phone IMEI : 351682058802729 ProductCode : 059N3C5 HW Version : 112.1402.2.4 === Other === Life Timer : 0 Battery Life : 94 SerialNum : 0212C24AB Base Code : 059J2N6 ModuleCode : 0205051 NCSD Ver : 1.9 BTID Ver : A0F41928C1DF0000FFFFFF Wlan MAC : A0F419295E4500 Public ID: 06433669C6FB3A38EF6E271245B5B3 Done! Core : v1.67.5 , WP7x FlashEngine : v3.9 Flash Files selected : OSBL : RM801_12w46_prod_generic_nokia_osbl.esco AMSS : RM801_12w46_prod_generic_amss.esco ADSP : RM801_12w46_prod_generic_adsp.esco WP : RM801_12460_prod_229_06_boot.esco UDA : RM801_12w46_prod_generic_user_area_erase.esco Check files done, All files are Ok Setting device to OSBL mode... Waiting for USB device... Connection opened successfully Establish connection with device... Init Ok Boot : 165.74.62.79 ==== OSBL ==== Processing : RM801_12w46_prod_generic_nokia_osbl.esco nokia_osbl.mbn.cert , Hash : 0C203F23776466E755E9955A9F8F9A39A0888B8E nokia_osbl.mbn , len : 0x000EA228 , Type : Data Will flash 1 regions OSBL flashing done ==== AMSS ==== Processing : RM801_12w46_prod_generic_amss.esco amss.mbn.cert , Hash : 0C203F23776466E755E9955A9F8F9A39A0888B8E amss.mbn.enc , len : 0x00FF0690 , Type : Data Will flash 1 regions AMSS flashing done ==== ADSP ==== Processing : RM801_12w46_prod_generic_adsp.esco adsp.mbn.cert , Hash : 0C203F23776466E755E9955A9F8F9A39A0888B8E adsp.mbn.enc , len : 0x0055C2D0 , Type : Data Will flash 1 regions ADSP flashing done ==== WINDOWS PHONE ==== Processing : RM801_12460_prod_229_06_boot.esco boot.img.cert , Hash : 0C203F23776466E755E9955A9F8F9A39A0888B8E boot.img , len : 0x17BA0A00 , Type : Data Will flash 25 regions Windows Phone flashing done ==== USER DEFINED AREA ==== Processing : RM801_12w46_prod_generic_user_area_erase.esco user_area_erase.cert , Hash : 0C203F23776466E755E9955A9F8F9A39A0888B8E UDA file detected, will erase defined region UDA erase done UDA flashing done Flashing done! Flashing time : 00:03:02 Reboot device Ok |
08-23-2013, 13:28 | #186 (permalink) |
Member: 21296 Status: Offline Thanks Meter: 328 | Its driving me nuts , and I don't know where is the problem just with Cyclone that doesn't read or flash Lumia 800. Any advice what can I do else Thanks |
08-23-2013, 14:35 | #187 (permalink) |
Member: 21296 Status: Offline Thanks Meter: 328 | Finally unlocked and rooted the Lumia 800 Finally unlocked and rooted the Lumia 800 on a fresh installation of Windows XP and Cyclone and Zune altogether: Logs below Code: Establishing Connection with Box in Main Mode... Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic] Initializing box... Box Firmware: Cyclone Main Application v02.20, (Aug 6 2013 20:32:14, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012 Hardware Platform: Cyclone Reloaded Flasher Interface (c) 2012 KarwosLabs Box Serial Number: B00018EC HW Revision: D, Suitable for: Production, Case: Reloaded Box Casing, MCU Manufacture Time: 2012, wk01 / 2011, wk27 Box is activated Started box selftests procedure USB Voltage 4,90v PASSED MCU Voltage 3,28v PASSED Core Voltage 1,78v PASSED VBAT Voltage 0,03v PASSED VBAT Voltage 4,88v PASSED Box VPP disabled VPP Voltage 0,04v PASSED Internal Box VPP Enabled VPP Voltage 4,86v PASSED Box VPP disabled VPP Voltage 0,02v PASSED All box selftests passed! Super DCT4 Activation: TRUE XGold/Blackberry Service Running, Counter: 100 Lumia No TP is ACTIVATED! Avaiable Physical Memory: 708.200MB Avaiable Virtual Memory: 1.903GB Avaiable Pagefile: 2.180GB Initializing FBUS... All initialized - Ready to work Lumia No TP Root Procedure Started... If phone is alive, It will be automatically swithced to OSBL mode. If software can't switch to OSBL mode, or phone is generally DEAD do folllowing: 1. Turn OFF device, wait 15 seconds afterwards 2. Eject USB cable, wait 10 seconds 3. Press and hold Volume-UP button 4. Insert USB Cable. OSBL should be booted. Booting CMT... [USB-Verbundgerät]: WinUSB Port opened OK! [USB-Verbundgerät]: WinUSB Port opened OK! [Nokia USB Connectivity]: WinUSB Port opened OK! Switching to RAW Mode... [Nokia USB Connectivity]: WinUSB Port opened OK! [Nokia USB Connectivity]: WinUSB Port opened OK! OSBL Details Protocol: v1.1 Version: v257.6 Build: 12 Timestamp: 17.02.2012 14:40:05 OSBL Bootloader Ready USB&UART Tracing set RSA Signature Calculated for QCB Boot, Writing... OSBL Certificate Details Magic: WP70 Version: 0 Signer Server ID: 0x98031573 Signer Timestamp: 28.09.2011 15:52:12 Signer S/N: 23 Signer User ID: 10046114 Auth Level: Care Data Encryption: 0 Image Index: 0 Asic Index: 0 Type: Image Write Hashtable Parsed OK Certificate Accepted [ASIC 0, Storage 4,1] Writing 850.552kB @ 0x000000000007D200 Write taken 0.359s (Average speed: 19408,40kBits/s) Restoring Modem from BACKUP_RAMFS_IMAGE... Restore OK Restarting MCU... Rooting Finished! Code: ---------------------------------------------------------------------------- Looking for NAND disk...Done. Trying to parse partition tables...Done. ---------------------------------------------------- FAT16 absolute address: 0x001F4200 FAT16 partition size: 0x0927C000 ---------------------------------------------------- Reading FAT16 raw...Done. Searching locations...Done. Found 1 locations to modify, processing: Reading sector 0...Done. Modify sector...Done. Updating sector...Done. Modification written. Please follow those steps: 1. Disconnect USB cable and remove the battery 2. Insert not supported simcard and power on the phone 3. If asked for PIN code, enter 00000000 4. If asked for PUK code, enter 0000000000 5. After unlock success, connect to USB, enter OSBL mode 6. Press Unlock again to restore the phone to original |
08-28-2013, 11:07 | #192 (permalink) |
No Life Poster Join Date: Mar 2009
Member: 997544 Status: Offline Thanks Meter: 71 | Hi mate I have cyclone box i try to unlock my Lumia 800 but its not unlocking its say need to active the box. please help me to active my box. Card Serial Number : D0000428 Box Serial Number : C0000B0E Thanks |
08-28-2013, 11:09 | #193 (permalink) |
No Life Poster Join Date: Mar 2010 Location: tirana
Member: 1254195 Status: Offline Sonork: 5454 Thanks Meter: 119 | Now after buy credits,how to active for lumia? Establishing Connection with Box in Main Mode... Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic] Initializing box... Box Firmware: Cyclone Main Application v02.20, (Aug 6 2013 20:31:40, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012 Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs Box Serial Number: C0004C30 HW Revision: B, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk40 / wk36 Initializing security card... Card Serial Number: D00E00E9 Card Firmware Revision: 010A Card is activated Box is activated Started box selftests procedure USB Voltage 5.13v PASSED MCU Voltage 3.28v PASSED Core Voltage 1.81v PASSED VBAT Voltage 0.01v PASSED VBAT Voltage 5.04v PASSED Box VPP disabled VPP Voltage 0.02v PASSED Internal Box VPP Enabled VPP Voltage 5.06v PASSED Box VPP disabled VPP Voltage 0.04v PASSED External Box VPP Enabled VPP Voltage 0.04v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE XGold/Blackberry Service Running, Counter: 100 Lumia No TP is NOT ACTIVATED! (1) <----------------------------------------------- not active yet? Avaiable Physical Memory: 1.95GB Avaiable Virtual Memory: 1.815GB Avaiable Pagefile: 3.681GB Initializing FBUS... All initialized - Ready to work |
