Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cyclonebox
Old 08-28-2013, 11:41   #196 (permalink)
XHouser's Avatar
Member: 151737
Sonork: 100.1595988
Thanks Meter: 91
Originally Posted by ask-unlock View Post
I have over 70 credits but in which button to active? where is the options?
Just press box wizard, after update lumia notp will be activated
Old 08-28-2013, 11:45   #197 (permalink)
XHouser's Avatar
Member: 151737
Sonork: 100.1595988
Thanks Meter: 91
Please ms karows add credit to my account, need lumia root fast, Web Accept Payment Sent (Unique Transaction ID #14R26375R84812134)
Old 08-28-2013, 11:47   #198 (permalink)
ask-unlock's Avatar
Member: 1254195
Sonork: 5454
Thanks Meter: 119
I think Cyclone Box server have problem,failed to connect to Cyclone Server.
Old 08-28-2013, 12:02   #199 (permalink)
Member: 1949494
Thanks Meter: 3
I have same problem. Server is down
Old 08-28-2013, 12:19   #200 (permalink)
Member: 209842
Sonork: 100.93537
Thanks Meter: 3,386
pls check connection now best regards
Old 08-28-2013, 13:06   #201 (permalink)
Member: 1949494
Thanks Meter: 3
SERVER IS BACK !!
stablishing Connection with Box in Main Mode...
Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic]
Initializing box...
Box Firmware: Cyclone Main Application v02.20, (Aug 6 2013 20:32:14, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012
Hardware Platform: Cyclone Reloaded Flasher Interface (c) 2012 KarwosLabs
Box Serial Number: B0000CBE
HW Revision: D, Suitable for: Production, Case: Reloaded Box Casing, MCU Manufacture Time: 2012, wk01 / 2011, wk27
Box is activated
Started box selftests procedure
USB Voltage 4.84v PASSED
MCU Voltage 3.27v PASSED
Core Voltage 1.77v PASSED
VBAT Voltage 0.04v PASSED
VBAT Voltage 4.81v PASSED
Box VPP disabled
VPP Voltage 0.02v PASSED
Internal Box VPP Enabled
VPP Voltage 4.83v PASSED
Box VPP disabled
All box selftests passed!
Super DCT4 Activation: TRUE
XGold/Blackberry Service Running, Counter: 100
Lumia No TP is ACTIVATED!
Avaiable Physical Memory: 1.1023GB
Avaiable Virtual Memory: 1.848GB
Avaiable Pagefile: 3.1008GB
Initializing FBUS...
All initialized - Ready to work
Dzieki i Pozdrawiam
Who will share solution after root to unlock plz?
All best
Old 08-28-2013, 13:11   #202 (permalink)
Member: 1885789
Thanks Meter: 2
thank you very much sir karwos for a very helpful update..
more power cyclone team...
Old 08-28-2013, 14:58   #203 (permalink)
Member: 209842
Sonork: 100.93537
Thanks Meter: 3,386
SERVER IS BACK !!
Initializing box...
Box is activated
Box VPP disabled
Box VPP disabled
Dzieki i Pozdrawiam
All best
check sticky posts please
Old 08-28-2013, 16:35   #204 (permalink)
Member: 1471765
Help please I got 100 credits and Lumia No TP is not activated yet and I already clicked on box wizard):
Establishing Connection with Box in Main Mode...
Handling device: [Cyclone Team], [Cyclone Bootloader], [Platform: Classic]
Initializing box...
Box Serial Number: B0000F1D
Box is activated
USB Voltage 4.99v PASSED
Core Voltage 1.76v PASSED
VBAT Voltage 0.03v PASSED
VBAT Voltage 4.96v PASSED
Box VPP disabled
VPP Voltage 4.97v PASSED
Box VPP disabled
Lumia No TP is NOT ACTIVATED! (1)
Avaiable Physical Memory: 2.8GB
Avaiable Virtual Memory: 1.787GB
Avaiable Pagefile: 3.1023GB
Old 08-29-2013, 10:51   #205 (permalink)
Member: 997544
Thanks Meter: 71
Originally Posted by karwos View Post
Hi everyone
- Added WORLD FIRST, USB ONLY, NO TP ROOTING FOR RM-801 LUMIA 800
- Added WORLD FIRST, USB ONLY, NO TP ROOTING FOR RM-802 LUMIA 800C
All NOKIA DLOAD OSBL loaders are supported (even latest one!)
Instructions:
1. Run Cyclone, it will be auto-updated
2. Update your Box Firmware to v2.20
3. Go to WP7 -> Simlocks Tab
4. Select Product and click ROOT!
It should go this way:
After rooting, Qualcomm Bootloader is installed. That means phone will be detected as Mass Storage Device, and you will have full access to eMMC.
Because patching is not good solution, we will add some good news aswell in next days
However, if you need simlock patching badly you can use some free tools around to patch AMSS (i.e. NSS).
Release Notes:
1. Supported products: Cyclone Box Classic, Cyclone Box Reloaded, Cyclone Key
2. Firmware Required v2.20
3. Need No TP Activation, is COMPLETLY FREE for all Cyclone Key users, for rest you need have 60 credits on your account and your box will be automatically activated (credits will not be withdrawn from box anyway, this is just threshold).
4. We also have solution to completly root rest of lumias, including 610, 610nfc, 900, etc... however it will be released ONLY if this solution WILL NOT BE COPIED. If somebody copy solution - it will be kept private.
5. No need new installer, however if you need one, always latest one is here: http://www.**********/CycloneBoxInstaller.exe
Best Regards,
Cyclone Team
Hi mate
I have cyclone box i try to unlock my Lumia 800 but its not unlocking its say need to active for notp.
please help me to active my notp.
Card Serial Number : D0000428
Box Serial Number : C0000B0E
Thanks
Old 08-29-2013, 11:18   #206 (permalink)
Member: 209842
Sonork: 100.93537
Thanks Meter: 3,386
Originally Posted by SYRYA TEL View Post
Hi mate
Thanks
On this moment Your credits amount is 0, To use this service You need have 60 credits.
Old 08-29-2013, 12:54   #207 (permalink)
Member: 1471765
Kaisak or Karwos can you activate my Lumia NO TP please I got 100 credit on my box and I updated my box wizard and still appears "Lumia NO TP not activated"
Please help me, I have a Lumia 800 to unlock, thanks.
Old 08-29-2013, 15:48   #208 (permalink)
Member: 209842
Sonork: 100.93537
Thanks Meter: 3,386
I checked on server, You need make only Box wizard, and Nokia Lumia without TP should works.
Old 09-04-2013, 10:00   #209 (permalink)
yasermalik's Avatar
Member: 488632
Thanks Meter: 391
Box Firmware: Cyclone Main Application v02.20, (Aug 6 2013 20:31:40, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012
Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs
Box Serial Number: C00000DE
HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2008, wk32
Initializing security card...
Card Serial Number: D0000277
Card Firmware Revision: 0109
Card is activated
Box is activated
i got 42 credit
i need no tp activation thanks in advance
Old 09-04-2013, 16:40   #210 (permalink)
Member: 1552795
Card Serial Number: D70002A4
Card is activated
Box is activated
USB Voltage 4,83v PASSED
MCU Voltage 3,29v PASSED
Core Voltage 1,79v PASSED
VBAT Voltage 0,01v PASSED
VBAT Voltage 4,73v PASSED
Box VPP disabled
VPP Voltage 0,04v PASSED
VPP Voltage 4,68v PASSED
Box VPP disabled
VPP Voltage 0,02v PASSED
External Box VPP Enabled
VPP Voltage 0,02v FAILED - IGNORED - Probably power supply is not connected
Box VPP disabled
Avaiable Physical Memory: 1.369GB
Avaiable Virtual Memory: 1.781GB
I ve got 49 credits, can you do something for me?
Page generated in 0.24948 seconds with 9 queries
