Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cyclonebox
Old 08-10-2013, 06:35   #136 (permalink)
adnanali's Avatar
Member: 207308
Thanks Meter: 472
Originally Posted by karwos View Post
This is not true, classic was shipped with 100 credits where ur credits gone ?
I bet there is lot of classic boxes with more than 60 credits.
this is reall story why we spend our credits check and think about itFree Solutions Actually not Free
Old 08-10-2013, 07:10   #137 (permalink)
Member: 209842
Sonork: 100.93537
Thanks Meter: 3,386
Originally Posted by anyandwinov View Post
Started credits checking procedure at 11:58:36 AM
Handling device: [Cyclone Team], [Cyclone Bootloader], [Platform: Classic]
Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic]
Service Tag: 84AF253D79FC2970797DCBCAFD5C49B3
Failed to Check Credits -> Failed to connect to Cyclone Server
upgrade firmware cyclone box 2.20 failed...
help me sir
try connect now pls and let me know abt results
Old 08-10-2013, 07:14   #138 (permalink)
Member: 209842
Sonork: 100.93537
Thanks Meter: 3,386
so why we spend our credits? i dont understand your point, i f you have classi and you spent (sl3, lg, broadcom or iphone xperia) You paid credits and got something. In this solution doesnt eat any credits-even one! and u can activate it!
Old 08-10-2013, 07:26   #139 (permalink)
Member: 328688
Thanks Meter: 2,316
Establishing Connection with Box in Main Mode...
Initializing box...
Box Firmware: Cyclone Main Application v02.20, (Aug 6 2013 20:31:40, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012
Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs
Box Serial Number: C0006300
HW Revision: C, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2010, wk48
Initializing security card...
Card Serial Number: D0090790
Card Firmware Revision: 010A
Card is activated
Box is activated
Started box selftests procedure
USB Voltage 4.97v PASSED
MCU Voltage 3.28v PASSED
Core Voltage 1.79v PASSED
VBAT Voltage 0.01v PASSED
VBAT Voltage 4.91v PASSED
Box VPP disabled
VPP Voltage 0.04v PASSED
Internal Box VPP Enabled
VPP Voltage 4.92v PASSED
Box VPP disabled
VPP Voltage 0.02v PASSED
External Box VPP Enabled
VPP Voltage 0.04v FAILED - IGNORED - Probably power supply is not connected
Box VPP disabled
All box selftests passed!
Super DCT4 Activation: TRUE
XGold/Blackberry Service Running, Counter: 100
Lumia No TP is NOT ACTIVATED! (1)
Avaiable Physical Memory: 1.1023GB
Avaiable Virtual Memory: 1.825GB
Avaiable Pagefile: 3.1023GB
Initializing FBUS...
All initialized - Ready to work
i hve 49 credit still same after update
Old 08-10-2013, 08:12   #140 (permalink)
Member: 209842
Sonork: 100.93537
Thanks Meter: 3,386
Initializing box...
Card is activated
Box is activated
Box VPP disabled
Box VPP disabled
Box VPP disabled
you have 49 credits, to use service You need have charge box 11 credits to total 60 credits - then you will use service without any problems.
Old 08-10-2013, 08:15   #141 (permalink)
Member: 328688
Thanks Meter: 2,316
where i can buy more 11 credit
Old 08-10-2013, 10:21   #142 (permalink)
Member: 275543
Thanks Meter: 6
nevermind..........................
Old 08-10-2013, 10:56   #143 (permalink)
Member: 1998346
Hi,
There are four things I don't understand, could someone clarify them for me?
- Is it totally free?
- Do we need a cyclone box?
- Is it permanent?
- When will it be avalaible for lumia 900?
Thank you in advance.
Old 08-10-2013, 11:30   #144 (permalink)
Moderator
Member: 1139057
Sonork: 100.109924
Thanks Meter: 4,433
Originally Posted by Celteek View Post
Hi,
- Is it permanent?
answer:
1. No you need 60credits on cyclonebox account to get activation.
2. Yes you need CyloneBox
3. No is not permament after flash with other firmware need unlock phone again that got windows phone device , same is even with orginal code after flash need enter code again.
4. When will be ready and if noone copy lumia 800 solution that right now Karwos give for cyclonebox.
Old 08-10-2013, 13:00   #145 (permalink)
Member: 1998346
Originally Posted by wgmmmx1 View Post
answer:
1. What it is said that it is free?
2. Why does it says it's "no tp"?
3. Ok
4. Less than one week?
Old 08-10-2013, 13:48   #146 (permalink)
karwos's Avatar
Member: 117496
Sonork: 100.83919
Thanks Meter: 22,689
3. Ok
1. It is free if you buy brand new cyclone box classic or key. Botb have 100 credita as they are brand new. Search button dont bite.
2. Because to root or unlock you dont need disassemble and solder phone. Right now its one and only solution in the world. Just box or key and usb cable.
Old 08-10-2013, 13:59   #147 (permalink)
Member: 1998346
I did search but it is not clear and there are lot of lies...
Old 08-10-2013, 14:01   #148 (permalink)
karwos's Avatar
Member: 117496
Sonork: 100.83919
What lies you talking about ?
Old 08-10-2013, 17:22   #149 (permalink)
Member: 1092831
i can't update my cyclone box,it always critical failed to update, my internet conection it fast enough, can you help me how to solve...
Old 08-10-2013, 17:48   #150 (permalink)
Member: 1092831
my cyclone box it solved now... i just uninstal my old version, and instal with new version, thanks to cyclone team...
Initializing box...
Box Serial Number: C0004E38
HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2010, wk35
Card Serial Number: D0030231
Card is activated
Box is activated
USB Voltage 5.07v PASSED
MCU Voltage 3.29v PASSED
Core Voltage 1.80v PASSED
VBAT Voltage 5.02v PASSED
Box VPP disabled
VPP Voltage 5.10v PASSED
Box VPP disabled
Box VPP disabled
Lumia No TP is ACTIVATED!
Avaiable Physical Memory: 1.17GB
Avaiable Virtual Memory: 1.867GB
Avaiable Pagefile: 3.33GB
Page generated in 0.21495 seconds with 8 queries
