Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cyclonebox
Old 08-15-2013, 13:20   #166 (permalink)
Member: 17351
Thanks Meter: 41
Originally Posted by cvxcvx View Post
This working to lumia 800 RM-819?
Yes it says so in the title!
Old 08-16-2013, 04:59   #167 (permalink)
Member: 1883225
Sonork: joseline
Thanks Meter: 3
help need unlock lumia 800 rm-819 iusacell
Old 08-16-2013, 18:49   #168 (permalink)
Member: 779470
Sonork: Waseem mobile
Thanks Meter: 101
Red face plz ACTIVATED Lumia No TP
Establishing Connection with Box in Main Mode...
Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic]
Initializing box...
Box Firmware: Cyclone Main Application v02.20, (Aug 6 2013 20:31:40, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012
Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs
Box Serial Number: C0005B5B
HW Revision: B, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk23
Initializing security card...
Card Serial Number: D009064D
Card Firmware Revision: 010A
Card is activated
Box is activated
Started box selftests procedure
USB Voltage 5.08v PASSED
MCU Voltage 3.30v PASSED
Core Voltage 1.78v PASSED
VBAT Voltage 0.01v PASSED
VBAT Voltage 5.05v PASSED
Box VPP disabled
VPP Voltage 0.04v PASSED
Internal Box VPP Enabled
VPP Voltage 5.01v PASSED
Box VPP disabled
External Box VPP Enabled
VPP Voltage 0.02v FAILED - IGNORED - Probably power supply is not connected
Box VPP disabled
All box selftests passed!
Super DCT4 Activation: TRUE
XGold/Blackberry Service Running, Counter: 100
Lumia No TP is NOT ACTIVATED! (1)
Avaiable Physical Memory: 1014.108MB
Avaiable Virtual Memory: 1.884GB
Avaiable Pagefile: 2.819GB
Initializing FBUS...
All initialized - Ready to work
Old 08-16-2013, 19:56   #169 (permalink)
Member: 1843320
same problem
Initializing box...
Box Firmware: Cyclone Main Application v02.20, (Aug 6 2013 20:32:14, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012
Hardware Platform: Cyclone Reloaded Flasher Interface (c) 2012 KarwosLabs
Box Serial Number: B0000719
HW Revision: D, Suitable for: Production, Case: Reloaded Box Casing, MCU Manufacture Time: 2012, wk01 / 2011, wk27
Box is activated
USB Voltage 4,91v PASSED
MCU Voltage 3,28v PASSED
Core Voltage 1,77v PASSED
VBAT Voltage 0,03v PASSED
VBAT Voltage 4,88v PASSED
Box VPP disabled
VPP Voltage 0,02v PASSED
VPP Voltage 4,88v PASSED
Box VPP disabled
VPP Voltage 0,04v PASSED
Avaiable Physical Memory: 264.684MB
Avaiable Virtual Memory: 1.827GB
Avaiable Pagefile: 1.413GB
Old 08-16-2013, 20:16   #170 (permalink)
Member: 209842
Sonork: 100.93537
Thanks Meter: 3,386
Initializing box...
Card is activated
Box is activated
Box VPP disabled
Box VPP disabled
Box VPP disabled
For activation Nokia Lumia 800 without TP you need have on account 60 credits. Your account is 0.
Old 08-16-2013, 20:17   #171 (permalink)
Member: 209842
Sonork: 100.93537
Thanks Meter: 3,386
Originally Posted by michal123 View Post
same problem
Initializing box...
Box is activated
Box VPP disabled
Box VPP disabled
Old 08-16-2013, 20:23   #172 (permalink)
Member: 1843320
pay 60 credits and same problem.
Started credits checking procedure at 21:23:33
Service Tag: 8E1E50E3233E7A0F9102BF5090485856
Cyclone Server (2.0.0.117), Cyclone Box Team 2008-2013 - Ready.
Credits: 60
Old 08-16-2013, 20:25   #173 (permalink)
Member: 209842
Sonork: 100.93537
Thanks Meter: 3,386
Credits: 60
Pls use box wizard now.
Old 08-16-2013, 20:29   #174 (permalink)
Member: 1843320
Lumia No TP is ACTIVATED! ready for me.. thanks
Old 08-20-2013, 10:43   #175 (permalink)
Member: 498414
Thanks Meter: 46
sir karwos please check my credits of my box for activate lumia no tp unlocking....thanks in advance....
my box is cyclone box....
Initializing box...
Box Firmware: Cyclone Main Application v02.11, (Nov 10 2012 00:51:46, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012
Box Serial Number: C00009A9
HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2008, wk27
Card Serial Number: D00005AB
Card Firmware Revision: 0109
Card is activated
Box is activated
USB Voltage 5.12v PASSED
MCU Voltage 3.29v PASSED
Core Voltage 1.79v PASSED
VBAT Voltage 5.01v PASSED
Box VPP disabled
VPP Voltage 0.00v PASSED
Box VPP disabled
VPP Voltage 0.09v PASSED
VPP Voltage 0.04v FAILED - IGNORED - Probably power supply is not connected
Box VPP disabled
Avaiable Physical Memory: 1.546GB
Avaiable Virtual Memory: 1.802GB
Avaiable Pagefile: 3.1023GB
Old 08-22-2013, 09:10   #176 (permalink)
Member: 2007886
Sonork: jingling56
Thanks Meter: 12
Why Nokia LUMIA 800C Telecom Edition NO TP points to unlock ROOT unsuccessful, hoping to resolve this error earlier technical mission!
BB6 Check Message Failed OSBL Reported an error 0x00000000,000300
Write Root Data Failed Certificate not accepted
Failed to root Phone Rooting Failed
Old 08-22-2013, 09:36   #177 (permalink)
Member: 209842
Sonork: 100.93537
Thanks Meter: 3,386
Initializing box...
Card is activated
Box is activated
Box VPP disabled
Box VPP disabled
Box VPP disabled
On this moment on Your account is 50 credits. So for activation no tp You need order 10 credits. I added You update credits, so after charge box You can use box wizard and enjoy lumia 800 no tp
The Following User Says Thank You to kaisak For This Useful Post:
Old 08-22-2013, 16:23   #178 (permalink)
Cheater -Don't Deal with him-
Member: 21296
Thanks Meter: 328
I am unable to root Nokia Lumia 800.
Should I have credits or what?
I updated the box like recommended but it is not asking me to have credits nor it is rooting the Lumia 800 displaying the error like below coded
Cyclone is unable to even flash the phone, while I flashed with Best that phone successfully
Initializing box...
Box Serial Number: B00018EC
Box is activated
USB Voltage	4.88v	PASSED
MCU Voltage	3.28v	PASSED
VBAT Voltage	0.03v	PASSED
VBAT Voltage	4.86v	PASSED
Box VPP disabled
VPP Voltage	4.83v	PASSED
Box VPP disabled
VPP Voltage	0.02v	PASSED
Avaiable Physical Memory: 3.1023GB
Avaiable Virtual Memory: 1.814GB
Lumia No TP Root Procedure Started...
If phone is alive, It will be automatically swithced to OSBL mode.
If software can't switch to OSBL mode, or phone is generally DEAD do folllowing:
1. Turn OFF device, wait 15 seconds afterwards
2. Eject USB cable, wait 10 seconds
3. Press and hold Volume-UP button
4. Insert USB Cable. OSBL should be booted.
Booting CMT...
[Nokia USB Connectivity]: WinUSB Port opened OK!
OSBL Details
Protocol: v1.1
Version: v257.6
Build: 12
Failed to Get OSBL Revision ->
Failed to Boot CMT -> Failed to get First Boot Block
Prepare phone failed with message -> Failed to Boot CMT
Write Root Data Failed -> Failed to Boot OSBL
Failed to Root Phone -> Rooting Failed
Old 08-22-2013, 17:59   #179 (permalink)
Member: 21296
Thanks Meter: 328
Hi Karwos
why you write bombastic title free rooting while it is paid?
Activate now my box to root "free" Nokia Lumias please
Web Accept Payment Sent (Unique Transaction ID #1S115391UB790174R)
I am waiting for you to assign my credits to box now
Old 08-22-2013, 18:58   #180 (permalink)
Member: 252682
Thanks Meter: 8
please mr karwos activate my box
Initializing box...
Box Serial Number: C00040E4
HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk32 / 2010, wk01
Card Serial Number: D001009B
Card is activated
Box is activated
USB Voltage 4.96v PASSED
Core Voltage 1.76v PASSED
VBAT Voltage 4.99v PASSED
Box VPP disabled
VPP Voltage 4.92v PASSED
Box VPP disabled
Box VPP disabled
Avaiable Physical Memory: 1.217GB
Avaiable Virtual Memory: 1.926GB
Avaiable Pagefile: 3.294GB
my account Credits: 237
please activate
Page generated in 0.33066 seconds with 8 queries
