Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cyclonebox
Old 08-07-2013, 17:17   #106 (permalink)
NADEEM GONDAL's Avatar
Member: 575900
Thanks Meter: 3,177
Originally Posted by SM4RTBOY View Post
what i need to do ?
If you have 60 credits you just need to box wizard .
and if you want to want to buy 60 credits you can buy from here
Cyclone box - credit & box order system
Old 08-07-2013, 17:26   #107 (permalink)
Member: 1945782
Thanks Meter: 7
cannot connect to server sir,upgrade firmware 2.20...
whats is this...
Sent from my YAMAHA using Tapatalk 2
Old 08-07-2013, 17:36   #108 (permalink)
Member: 1488173
Thanks Meter: 194
I´m still waiting my credits move:
http://forum.gsmhosting.com/vbb/9630853-post47.html
Thanks !!
Old 08-07-2013, 17:41   #109 (permalink)
Member: 575900
Thanks Meter: 3,177
Thanks !!
Just do box wizard ,and run it again.
Old 08-07-2013, 17:43   #110 (permalink)
karwos's Avatar
Member: 117496
Sonork: 100.83919
Thanks Meter: 22,689
Originally Posted by adnanali View Post
pay agaian for use and pay every time when new update added its Truth
Nobody force u to buy anythinf
U can still mess with TP
The Following 2 Users Say Thank You to karwos For This Useful Post:
Old 08-07-2013, 21:36   #111 (permalink)
karwos's Avatar
Member: 117496
Sonork: 100.83919
Truth is out there
Old 08-07-2013, 22:16   #112 (permalink)
Member: 527534
Sonork: 100.1606510
Thanks Meter: 193
@karwos.... urgent matter. Contact me on sonork. I sent request still you didn't accept. Now time to sleep. Therefore pls hurry. Don't ask why here...
Old 08-07-2013, 22:42   #113 (permalink)
Member: 527534
Sonork: 100.1606510
Thanks Meter: 193
Establishing Connection with Box in Main Mode...
Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic]
Initializing box...
Box Firmware: Cyclone Main Application v02.20, (Aug 6 2013 20:31:40, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012
Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs
Box Serial Number: xxxxxxxx
HW Revision: C, Suitable for: Production, Case: 2011 - New Casing, MCU
Initializing security card...
Card Serial Number: xxxxxxxx
Card Firmware Revision: 010A
Card is activated
Box is activated
Started box selftests procedure
USB Voltage 5.02v PASSED
MCU Voltage 3.27v PASSED
Core Voltage 1.79v PASSED
VBAT Voltage 0.01v PASSED
VBAT Voltage 5.04v PASSED
Box VPP disabled
VPP Voltage 0.04v PASSED
Internal Box VPP Enabled
VPP Voltage 5.01v PASSED
Box VPP disabled
External Box VPP Enabled
VPP Voltage 0.00v FAILED - IGNORED - Probably power supply is not connected
Box VPP disabled
All box selftests passed!
Super DCT4 Activation: TRUE
XGold/Blackberry Service Running, Counter: 100
Lumia No TP is ACTIVATED!
Avaiable Physical Memory: 598.864MB
Avaiable Virtual Memory: 1.806GB
Avaiable Pagefile: 1.586GB
Initializing FBUS...
All initialized - Ready to work
Everythings ok? Is it activated successfully?
Old 08-08-2013, 00:32   #114 (permalink)
Member: 435806
Thanks Meter: 10
Originally Posted by kaisak View Post
Pls paste your sn I will check Your credits history, This service not "eat" credits event on activation. 60 credits You need have on account, but we will not use this credits, so Your balance shouldnt change.
We gave free, without credits rooting-its first step for unlock without TP.
Why I need rooting my phone, its this same how unlock?
Rooting make that phone is fully opened to unlock simlock and write modified firmware.
No tp means no need soldering or disassembling phone and using JTAG for that.... total time needed is about 5 secs
Just root your phone and patch it by NSS for example ...
if you don't like patching, wait and we will present permanent unlock.
thanks for the quick responce this is my Box Serial Number: C0002108 hope my box is include in this free big update of cyclone team....
Old 08-08-2013, 02:45   #115 (permalink)
Member: 1242505
Box is activated
Avaiable Physical Memory: 1.311GB
Avaiable Virtual Memory: 1.896GB
Avaiable Pagefile: 2.889GB
Lumia No TP Root Procedure Started...
If phone is alive, It will be automatically swithced to OSBL mode.
If software can't switch to OSBL mode, or phone is generally DEAD do folllowing:
1. Turn OFF device, wait 15 seconds afterwards
2. Eject USB cable, wait 10 seconds
3. Press and hold Volume-UP button
4. Insert USB Cable. OSBL should be booted.
Booting CMT...
[USB Composite Device]: WinUSB Port opened OK!
[Nokia USB Connectivity]: WinUSB Port opened OK!
BB5 USB Boot Rom not Detected -> Timeout, no any compatible USB device detected.
Failed to Boot CMT -> No compatible USB devices detected
Prepare phone failed with message -> Failed to Boot CMT
Write Root Data Failed -> Failed to Boot OSBL
Failed to Root Phone -> Rooting Failed
Old 08-08-2013, 04:12   #116 (permalink)
Member: 209842
Sonork: 100.93537
Thanks Meter: 3,386
you have on account 40 credits
Old 08-08-2013, 07:40   #117 (permalink)
karwos's Avatar
Member: 117496
Sonork: 100.83919
Initializing box...
Card is activated
Box is activated
USB Voltage5.02vPASSED
MCU Voltage3.27vPASSED
Core Voltage1.79vPASSED
VBAT Voltage0.01vPASSED
VBAT Voltage5.04vPASSED
Box VPP disabled
VPP Voltage0.04vPASSED
VPP Voltage5.01vPASSED
Box VPP disabled
VPP Voltage0.00vFAILED - IGNORED - Probably power supply is not connected
Box VPP disabled
Seems so
Br karwos
Hgyhgybg
Old 08-08-2013, 07:42   #118 (permalink)
karwos's Avatar
Member: 117496
Sonork: 100.83919
Need buy 20 credits. Price 15 usd.
Ask your reseller, or check at www.**********
Old 08-08-2013, 07:43   #119 (permalink)
karwos's Avatar
Member: 117496
Sonork: 100.83919
Originally Posted by lihai View Post
Box is activated
Booting CMT...
Maybe your phone is already rooted, and OSBL is not detected.... or drivers problem... or baterry....
Old 08-08-2013, 10:09   #120 (permalink)
swechacnu's Avatar
Member: 115144
Sonork: 100.1590698
Thanks Meter: 498
Hi,
if i rooted unlocked with this update, then again i can update latest version firmware with cyclone or care suite is it possible? and one more thing again is it locked device?
BR,
Srinivas Reddy.
Page generated in 0.26010 seconds with 8 queries
