Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cyclonebox
Old 04-30-2013, 17:49   #1 (permalink)
leonirvana's Avatar
Member: 290434
Sonork: -
Thanks Meter: 39
Question cyclone reloaded + UFC DITS 4 , not posible to Local/Test Mode
hi, i have this problem with CYCLONE RELOADED + UFC4 (DITS)
I tried nokia 1208 with fbus cable and works fine.
But trying to connect with ufc and I can not make it work. Im using DCT4-H adaptor in the right way on PCB.
I tried many ways of connection but not possible.
I use this cable to connect cyclone reaload with ufc4
http://gsmserver.es/nfs/product/8356...odo-en-uno.jpg
I set cable in Cyclone mode or Jaf mode but not work.
also I set ufc in Jaf Mode(switch 6) or none(all switches down - to numbers side) but not work. (also trying 5.1k or 7.5k)
* Sometimes i get to put in LOCAL/TEST mode, but when try to read info, always
Failed to read info -> Phone not detected
Old 05-03-2013, 01:11   #2 (permalink)
leonirvana's Avatar
Member: 290434
Sonork: -
Thanks Meter: 39
no body has problem with this combo???
Old 05-03-2013, 02:17   #3 (permalink)
Member: 1877063
Thanks Meter: 18
I have too, cable of UFC4 by dits, somtime getting error on bb5 but on dct4 work fine
You need extra power supply for bb5 in order to work, use the provided usb power supply cable for dits
hope it work for you
Old 05-03-2013, 03:50   #4 (permalink)
leonirvana's Avatar
Member: 290434
Sonork: -
Thanks Meter: 39
can tell me how u set up your UFC ?l i mean.. wich switches are activated... etc..
what cables do u user? all in 1? how u switch it? cyclone / mt / jaf ?
thanks
Old 05-03-2013, 08:49   #5 (permalink)
Member: 1134507
Sonork: 100.1607956
Thanks Meter: 201
Smile Dear both
thanks
i have also use ufc pro and i can u properly and no error with cyclone reloaded
but i have change one thing in this cable
im not use on jaf or ufs cable
im using thins cable as mode try with mt mode don't use jaf mode us mt mode or other work properly
after to check must report here
if u problem same then i will try to use and other method
jawad munir
Old 05-07-2013, 03:46   #6 (permalink)
Member: 835563
Thanks Meter: 22
i have a gpg ufc pro v2 and cyclone key and i can not unlock the nokia E71 always is asking for the tx2 cable even when said the cyclone key don not need it. some one have a solution?
Old 05-07-2013, 04:00   #7 (permalink)
Member: 835563
Thanks Meter: 22
here is my log
Box is activated
Started box selftests procedure
All box selftests passed!
Super DCT4 Activation: TRUE
XGold/Blackberry Service Running, Counter: 100
Avaiable Physical Memory: 1.264GB
Avaiable Virtual Memory: 1.891GB
Avaiable Pagefile: 3.153GB
Initializing FBUS...
All initialized - Ready to work
MCU Version V ICPR71_09w47.10
MCU Date 20-01-11
Product RM-357 (Nokia E71)
Manufacturer (c) Nokia
IMEI 352925024442404
Mastercode 7275347740
IMEI Spare 3A25290542444200
IMEI SV 3325290542444260F4000000
PPM 510.21.009j 510.21.009510.21.009_v32kRM346ENO74110842.a36n256o 256
PSN SIL741364
Product Code 0553094
Basic Product Code 0553093
PSD 0000000000000000
LPSN 0
WLAN MAC 0021FE3C17BE
APE SW 510.21.009
APE Variant 510.21.009510.21.009_v32
APE Test RM346ENO74110842.a36
APE HW 256
APE ADSP 256
RETU 15
TAHVO 22
AHNE 11
HW 0941i510.21.009j 510.21.009510.21.009_v32kRM346ENO74110842.a36n256o 256
PCI i510.21.009j 510.21.009510.21.009_v32kRM346ENO74110842.a36n256o 256¥0)510.21.009, 19-03-2011, RM-346, (c)Nokia ,
UEM 510.21.009j 510.21.009510.21.009_v32kRM346ENO74110842.a36n256o 256¥0)510.21.009, 19-03-2011, RM-346, (c)Nokia ,
UPP 510.21.009j 510.21.009510.21.009_v32kRM346ENO74110842.a36n256o 256¥0)510.21.009, 19-03-2011, RM-346, (c)Nokia ,
RFIC 17141715
DSP ICPR71_09w40i510.21.009j 510.21.009510.21.009_v32kRM346ENO74110842.a36n256o 256¥0)510.21.009, 19-03-2011, RM-346, (c)Nokia ,
LCD 510.21.009j 510.21.009510.21.009_v32kRM346ENO74110842.a36n256o 256
BT 510.21.009j 510.21.009510.21.009_v32kRM346ENO74110842.a36n256o 256
ADSP Sw 510.21.009j 510.21.009510.21.009_v32kRM346ENO74110842.a36n256o 256
ADSP DevID 510.21.009j 510.21.009510.21.009_v32kRM346ENO74110842.a36n256o 256¥0)510.21.009, 19-03-2011, RM-346, (c)Nokia ,
ADSP RevID 510.21.009j 510.21.009510.21.009_v32kRM346ENO74110842.a36n256o 256¥0)510.21.009, 19-03-2011, RM-346, (c)Nokia ,
AEM 510.21.009j 510.21.009510.21.009_v32kRM346ENO74110842.a36n256o 256¥0)510.21.009, 19-03-2011, RM-346, (c)Nokia ,
Flip MCUSW 510.21.009j 510.21.009510.21.009_v32kRM346ENO74110842.a36n256o 256¥0)510.21.009, 19-03-2011, RM-346, (c)Nokia ,
Simlock Server SIMLOCK SERVER
Simlock Key 3340201549764300
Simlock Profile 8000000000000000
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Simlock [1,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 334020
Auto Selecting Flash Files on User Request...
Product Code: 0553094
No Flash Datapackage installed for this Phone!
Booting CMT...
CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103
CMT_EM_ASIC_ID: 00000295
CMT_EM_ASIC_ID: 00000B22
CMT_PUBLIC_ID: 1E1001010B7B0052B4C0140A4E67355C6A53E6DD
CMT_ASIC_MODE_ID: 00
CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE
CMT_BOOT_ROM_CRC: 4B9B7510
CMT_SECURE_ROM_CRC: 3E691FF8
CMT Ready!
Searching for BootCode: DualLine 32Bit
RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.12.8.0, Algo: BB5
Flashbus Write baud set to 1.0Mbits
Flashbus Read baud set to 98Kbits
Using NEW BB5 FLASHING PROTOCOL
Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding
Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit
Box TX2 Data Pin set to: Service Pin 3
If software STUCK HERE with box TX LED lit, that means:
1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!)
2. Your cable is not TX2 Enabled!
3. Transmission error occured, try again
In either cases, you need to reconnect your box from USB.
Old 05-07-2013, 04:42   #8 (permalink)
Member: 1877063
Thanks Meter: 18
Originally Posted by DonMike View Post
here is my log
Box is activated
MCU Date 20-01-11
PSN SIL741364
LPSN 0
APE SW 510.21.009
APE HW 256
APE ADSP 256
RETU 15
TAHVO 22
AHNE 11
RFIC 17141715
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Booting CMT...
CMT Ready!
Try to check "skip CMT ID check" Sir
Old 05-07-2013, 16:30   #9 (permalink)
Member: 1134507
Sonork: 100.1607956
Thanks Meter: 201
Wink Dear all
me also use cyclone with gpg usfc pro but no one time have to face any problem
Old 05-07-2013, 20:26   #10 (permalink)
Moderator
.:SARCAR:.'s Avatar
Member: 322206
Sonork: : offline :
Thanks Meter: 1,354
@ leonirvana , DonMike
contact ur ufc cable vendor , this is not cyclone problem .
Old 05-09-2013, 02:34   #11 (permalink)
Member: 835563
Thanks Meter: 22
@Sarcar i tried the option that give me suberber checking "skip CMT ID check" but does not work, also i have a other cable with tx rx and rx2 does someone now if i have to use it? i post a photo
Old 05-10-2013, 19:30   #12 (permalink)
Moderator
.:SARCAR:.'s Avatar
Member: 322206
Sonork: : offline :
Thanks Meter: 1,354
@DonMike ,
that's a tp unlock cable .
Old 05-11-2013, 19:28   #13 (permalink)
Member: 835563
Thanks Meter: 22
Thank you SARCAR
So you said the ufc cable or the ufc clamps does not work? They have something wrong inside?
Page generated in 0.21177 seconds with 9 queries
