09-15-2012, 15:35 | #1 (permalink) |
Freak Poster Join Date: May 2012 Location: under the philippine deep
Member: 1766158 Status: Offline Sonork: 1618330 Thanks Meter: 24 | cyclone self test error Code: Establishing Connection with Box in Main Mode... Handling device: [Cyclone Team], [Cyclone Bootloader], [Platform: Classic] Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic] Initializing box... Box Firmware: Cyclone Main Application v02.05, (Aug 22 2012 23:27:20, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012 Hardware Platform: Cyclone Reloaded Flasher Interface (c) 2012 KarwosLabs Box Serial Number: B0001DB7 HW Revision: D, Suitable for: Production, Case: Reloaded Box Casing, MCU Manufacture Time: 2012, wk01 / 2011, wk27 Box is activated Started box selftests procedure Box Selftests Failed -> USB Supply Voltage test failed, 4.29v is out of valid range Super DCT4 Activation: TRUE XGold/Blackberry Service Running, Counter: 100 Avaiable Physical Memory: 1.948GB Avaiable Virtual Memory: 1.915GB Avaiable Pagefile: 3.778GB Initializing FBUS... All initialized - Ready to work |
09-15-2012, 18:36 | #2 (permalink) | |
No Life Poster Join Date: May 2011 Location: Z3X ^ CM2 ^ MRT ^ OCTOPUS
Member: 1587480 Status: Offline Sonork: 100.1618317 Thanks Meter: 2,165 | Quote:
use gpghub still use back usb port on your pc still same replace your box on your resaler | |
09-18-2012, 18:00 | #3 (permalink) |
Moderator Join Date: Jul 2006 Location: Midnapore,West-Bengal,India
Member: 322206 Status: Offline Sonork: 100.1594813/.:SARCAR:. Thanks Meter: 1,350 | @chunkiebone , first try to change main usb a to b cable if not solve use another usb port of ur pc. if still same check these threads...... http://forum.gsmhosting.com/vbb/f528...hat-do-812599/ http://forum.gsmhosting.com/vbb/f528...ml#post6481067 |
The Following User Says Thank You to .:SARCAR:. For This Useful Post: |
