Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cyclonebox
Old 08-07-2013, 13:58   #1 (permalink)
NADEEM GONDAL's Avatar
Member: 575900
Thanks Meter: 3,177
Easy tutorial to Unlock Lumia 800 ;)
Instructions:
1. Go to WP7 -> Simlocks Tab
2. Select Product and click ROOT!
3. Press and hold vol+ ke plug USB cable install driver
It should go this way:
4. Download and install NSS from this link
http://forum.gsmhosting.com/vbb/f528...4/#post9632072
5. Open NSS go in simlock tab
Turn off phone Press and holp Vol+ key and plug cable after install driver .
In Simlocks -----WP7
Click Unlock and If there is Error
Go in Advance setting tab and tick the option Lumia unlock-Alternative ..
then back WP7 tab and click unlock again
Unlocked
REGARDS
The Following 26 Users Say Thank You to NADEEM GONDAL For This Useful Post:
Old 08-07-2013, 14:01   #2 (permalink)
silhouette's Avatar
Member: 52597
Thanks Meter: 275
Nicely explained, thanks
Old 08-07-2013, 14:20   #3 (permalink)
CONCORDIA GSM's Avatar
Member: 209722
Thanks Meter: 818
And what about nokia deloader version of lumia ????
Old 08-07-2013, 14:52   #4 (permalink)
karwos's Avatar
Member: 117496
Sonork: 100.83919
Thanks Meter: 22,689
You mean Lumia 800 with Nokia DLOAD ?
Yes, you can unlock now Without TP by rooting...
The Following 4 Users Say Thank You to karwos For This Useful Post:
Old 08-08-2013, 05:29   #5 (permalink)
ihsan.khan.gsm's Avatar
Member: 1489021
Sonork: 100.1620946
Thanks Meter: 831
its free or use any credit like sl3
Old 08-08-2013, 07:44   #6 (permalink)
Moderator
Member: 1139057
Sonork: 100.109924
Thanks Meter: 4,428
You need got 60 credits on cyclonebox account and update box after all is free and unlimited
Old 08-08-2013, 14:08   #7 (permalink)
Member: 1489021
Sonork: 100.1620946
Thanks Meter: 831
just lumia is free or also sl3
Old 08-08-2013, 14:48   #8 (permalink)
Member: 1216263
Thanks Meter: 130
Hi there, got 2 questions.
1. Is it valid for ANY Nokia Lumia 800 from any network?
2. The unlock is permanent? Or if I update the software you lose it?
Old 08-08-2013, 14:53   #9 (permalink)
Moderator
Member: 1139057
Sonork: 100.109924
Thanks Meter: 4,428
Just lumia 800 is free.
ans:
1. Yes all models Lumia 800 are supported all network.
2. No is not permament after flash phone need do root and unlock again but this is not a problem becosue activation is unlimited and always after flash can unlock phone again.
The Following 3 Users Say Thank You to wgmmmx1 For This Useful Post:
Old 08-08-2013, 15:21   #10 (permalink)
Member: 1489021
Sonork: 100.1620946
Thanks Meter: 831
ans:
its mean not possible any lumia set b 4 then flash ,we should be flash after that unlock right
Old 08-08-2013, 15:30   #11 (permalink)
Moderator
Member: 1139057
Sonork: 100.109924
Thanks Meter: 4,428
Yes correct first flash after root and unlock
Old 08-12-2013, 22:22   #12 (permalink)
dragosgsm's Avatar
Member: 148032
Thanks Meter: 415
WORKING !!!!!!!!!!
Establishing Connection with Box in Main Mode...
Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic]
Initializing box...
Box Firmware: Cyclone Main Application v02.20, (Aug 6 2013 20:34:19, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012
Hardware Platform: Cyclone Key Flasher Interface (c) 2012 KarwosLabs
Box Serial Number: A000013A
HW Revision: E, Suitable for: Production, Case: Orange Key Casing, MCU Manufacture Time: Green PCB Rev. 4 2012 wk33, MCU 2011 wk09
Box is activated
Started box selftests procedure
All box selftests passed!
Super DCT4 Activation: TRUE
XGold/Blackberry Service Running, Counter: 100
Lumia No TP is ACTIVATED!
Avaiable Physical Memory: 3.1023GB
Avaiable Virtual Memory: 1.795GB
Avaiable Pagefile: 3.1023GB
Initializing FBUS...
All initialized - Ready to work
Lumia No TP Root Procedure Started...
If phone is alive, It will be automatically swithced to OSBL mode.
If software can't switch to OSBL mode, or phone is generally DEAD do folllowing:
1. Turn OFF device, wait 15 seconds afterwards
2. Eject USB cable, wait 10 seconds
3. Press and hold Volume-UP button
4. Insert USB Cable. OSBL should be booted.
Booting CMT...
[USB Composite Device]: WinUSB Port opened OK!
[Nokia USB Connectivity]: WinUSB Port opened OK!
Switching to RAW Mode...
OSBL Details
Protocol: v1.0
Version: v256.4
Build: 10
Timestamp: 9/29/2011 4:38:56 PM
OSBL Bootloader Ready
USB&UART Tracing set
RSA Signature Calculated for QCB Boot, Writing...
OSBL Certificate Details
Magic: WP70
Version: 0
Signer Server ID: 0x98031573
Signer Timestamp: 9/28/2011 4:52:12 PM
Signer S/N: 23
Signer User ID: 10046114
Auth Level: Care
Data Encryption: 0
Image Index: 0
Asic Index: 0
Type: Image Write
Hashtable Parsed OK
Certificate Accepted
[ASIC 0, Storage 4,1] Writing 850.552kB @ 0x000000000007D200
Write taken 0.437s (Average speed: 15944.20kBits/s)
Restoring Modem from BACKUP_RAMFS_IMAGE...
Restore OK
Restarting MCU...
Rooting Finished!
Looking for NAND disk...Done.
Trying to parse partition tables...Done.
FAT16 absolute address: 0x001F4200
FAT16 partition size: 0x0927C000
Reading FAT16 raw...Done.
Searching locations...Done.
Found 2 locations to modify, processing:
Reading sector 0...Done.
Modify sector...Done.
Updating sector...Done.
Reading sector 1...Done.
Modification written. Please follow those steps:
1. Disconnect USB cable and remove the battery
2. Insert not supported simcard and power on the phone
3. If asked for PIN code, enter 00000000
4. If asked for PUK code, enter 0000000000
5. After unlock success, connect to USB, enter OSBL mode
6. Press Unlock again to restore the phone to original
PHONE UNLOCKED !!!!!!!!!!!!!
The Following User Says Thank You to dragosgsm For This Useful Post:
Old 08-14-2013, 23:38   #13 (permalink)
Member: 31028
Thanks Meter: 56
after rooting 2 lumia 800 i plug while vol + pressed install drivers but softwares cannot see phone anymore, any ideia why?
regards
Old 08-15-2013, 05:24   #14 (permalink)
Member: 4627
Sonork: 57528:debeliamark
Thanks Meter: 1,034
regards
You must see it like damaged MMC in Windows - DO NOT FORMAT IT!
Old 08-15-2013, 12:21   #15 (permalink)
Member: 31028
Thanks Meter: 56
i' using windows 7 64 bits, and i see it like u say. even software detect nand. but when i press unlock phone always not found
Page generated in 0.30391 seconds with 10 queries
