12-30-2009, 03:08 | #1 (permalink) |
Freak Poster Join Date: May 2004
Member: 67367 Status: Offline Thanks Meter: 47 | Failed to Unlock 2323c Using Super DCT4 Activation [Solved Thanks to Alex] Code: Nokia DCT4/WD2/BB5 Service Tool Initialization Started, Engine Revision: 1.0.0.7918 Handling device: [Cyclone Team], [Cyclone Bootloader] Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia Application v01.0C, (Nov 25 2009 03:18:28, gcc v4.3.2, RTOS V6.0.0), Type: Signed Production Application Box Serial Number: C0000668 HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2008, wk27 Initializing security card... Card Serial Number: D100010F Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 4.75v PASSED MCU Voltage 3.27v PASSED Core Voltage 1.78v PASSED VBAT Voltage 0.40v PASSED VBAT Voltage 4.63v PASSED Box VPP disabled VPP Voltage 0.02v PASSED Internal Box VPP Enabled Box Selftests Failed -> VPP Supply Voltage test failed, 0.22v is out of valid range Super DCT4 Activation: TRUE Initializing FBUS... All initialized - Ready to work MCU Version V 08.20 MCU Date 30-06-09 Product RM-543 Manufacturer (c) Nokia IMEI 35XXXXXXXXXX Mastercode 1431752536 Selecting unlock method... Using Super DCT4 Activation Search in: C:\Program Files\Cyclone Box\UnlockData\ Searching for: RM-543_V 08.20.sunlock_img Writing patch file... Booting UPP... UPP ID: 3168 [HW_UNKNOWN] shadow, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 Box VPP disabled Internal Phone VPP Selected PLL Factor: 3 FlashChip[0]: 0x00898981 @ 0x01000000, Intel, SectorSize: 128kB, Ext: 00009221 FlashChip[1]: 0x00898981 @ 0x02000000, Intel, SectorSize: 128kB, Ext: 00009221 Signature: AD7EB61B23100340C605E40120A20000 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 51Kbits u3_intel.fia, Type: Algorithm, Target: FlashChip[0] 0x00898981 (256Mbits), Rev: 7.4.80.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0.04V MSID-Crypted: 8481A30EA6F70A79CDC59EF38B Using MSID-FAID Cache, Not wasting card FAID-Crypted: Flash Loading Failed -> Failed to send FAID Box VPP disabled Processing Flash Image Failed -> Problem with sending Flash Loader Failed to Unlock DCT4 -> Failed to write patch file Last edited by ptt; 07-31-2010 at 11:47. Reason: problem solved |
12-30-2009, 08:12 | #3 (permalink) |
Member: 67367 Status: Offline Thanks Meter: 47 | Code: MCU Version V 08.20 MCU Date 30-06-09 Product RM-543 Manufacturer (c) Nokia IMEI 35XXXXXXXXX Mastercode 1431752536 IMEI Spare 3A75890003722901 IMEI SV 3375890003722931F9000000 PPM V 08.20, 30-06-09, RM-543, (c) Nokia , T CNT Content: opv_optus_black_sim, V 08.20, 30-06-09, RM-543, (c) Nokia , , PSN DSF749679 Product Code 0591959 Module Code 0204276 Basic Product Code 0574686 PSD 0000000D00000000 LPSN 0 HW 1000 UEM 4386 UPP 12648 RFIC 0500 DSP ICPR72_09w24_U LCD SUEZ BT 2222-143C Asic 11 HW Signature 5FE76B15659E261B Simlock Server SIMLOCK SERVER Simlock Key 5050200000000000 Simlock Profile 800000000003000B Simlock Aux 000B5555 Simlock IMEI 00553579800302792100 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 50502F Scanning avaiable products... Processing C:\Program Files\Nokia\Phoenix\Products\... Found 32 products, Filtering DCT4 Products - wait... 4 Products left after filtering. Ready. Retrieving Variants for Product RM-543 - wait... 222 Variants Retrieved Processing pre-flash tasks... Pre-flash tasks finished Booting UPP... UPP ID: 3168 [HW_UNKNOWN] rm543__08.20.mcusw, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 Box VPP disabled Internal Phone VPP Selected PLL Factor: 3 FlashChip[0]: 0x00898981 @ 0x01000000, Intel, SectorSize: 128kB, Ext: 00009221 FlashChip[1]: 0x00898981 @ 0x02000000, Intel, SectorSize: 128kB, Ext: 00009221 Signature: AD7EB61B23100340C605E40120A20000 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 51Kbits u3_intel.fia, Type: Algorithm, Target: FlashChip[0] 0x00898981 (256Mbits), Rev: 7.4.80.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0.04V MSID-Crypted: 8481A30EA6F70A79CDC59EF38B Using MSID-FAID Cache, Not wasting card FAID-Crypted: CA269A43386BB3B603B214D2 Flashbus Write baud set to 6.50Mbits 2 Region(s) to erase Erasing NOR Region [0x01000000-0x0101FFFF] Erasing NOR Region [0x01020000-0x01CFFFFF] Erase taken 75.765s Writing 186 blocks... All blocks written OK! Time taken 855.109s Terminating flash session Box VPP disabled Booting UPP... UPP ID: 3168 [HW_UNKNOWN] rm543__08.20.image_ed_si_bla, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 Box VPP disabled Internal Phone VPP Selected PLL Factor: 3 FlashChip[0]: 0x00898981 @ 0x01000000, Intel, SectorSize: 128kB, Ext: 00009221 FlashChip[1]: 0x00898981 @ 0x02000000, Intel, SectorSize: 128kB, Ext: 00009221 Signature: AD7EB61B23100340C605E40120A20000 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 51Kbits u3_intel.fia, Type: Algorithm, Target: FlashChip[0] 0x00898981 (256Mbits), Rev: 7.4.80.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0.00V MSID-Crypted: 84F0489ED62A18FDFAB6534013 Using MSID-FAID Cache, Not wasting card FAID-Crypted: Flash Loading Failed -> Failed to send FAID Box VPP disabled Processing Flash Image Failed -> Problem with sending Flash Loader Failed to Flash -> Problem with processing PPM Image file Last edited by ptt; 07-31-2010 at 11:47. Reason: add code tag |
12-31-2009, 02:21 | #7 (permalink) |
Member: 67367 Status: Offline Thanks Meter: 47 | Problem Solved just repeat and repeat and repeat this Flash it same version unbranded product code and redo the unlock. Thanks to alex.. Code: All initialized - Ready to work MCU Version V 08.20 MCU Date 30-06-09 Product RM-543 Manufacturer (c) Nokia IMEI 35XXXXXXXXXX Mastercode 1431752536 IMEI Spare 3A75890003722901 IMEI SV 3375890003722931F9000000 PPM V 08.20, 30-06-09, RM-543, (c) Nokia , T CNT Content: opv_optus_black_sim, V 08.20, 30-06-09, RM-543, (c) Nokia , , PSN DSF749679 Product Code 0591959 Module Code 0204276 Basic Product Code 0574686 PSD 0000000D00000000 LPSN 0 HW 1000 UEM 4386 UPP 12648 RFIC 0500 DSP ICPR72_09w24_U LCD SUEZ BT 2222-143C Asic 11 HW Signature 5FE76B15659E261B Simlock Server SIMLOCK SERVER Simlock Key 5050200000000000 Simlock Profile 800000000003000B Simlock Aux 000B5555 Simlock IMEI 00553579800302792100 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 50502F MCU Version V 08.20 MCU Date 30-06-09 Product RM-543 Manufacturer (c) Nokia IMEI 35XXXXXXXXXXXXXX Mastercode 1431752536 Selecting unlock method... Using Super DCT4 Activation Search in: C:\Program Files\Cyclone Box\UnlockData\ Searching for: RM-543_V 08.20.sunlock_img Writing patch file... Booting UPP... UPP ID: 3168 [HW_UNKNOWN] shadow, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 Box VPP disabled Internal Phone VPP Selected PLL Factor: 3 FlashChip[0]: 0x00898981 @ 0x01000000, Intel, SectorSize: 128kB, Ext: 00009221 FlashChip[1]: 0x00898981 @ 0x02000000, Intel, SectorSize: 128kB, Ext: 00009221 Signature: AD7EB61B23100340C605E40120A20000 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 51Kbits u3_intel.fia, Type: Algorithm, Target: FlashChip[0] 0x00898981 (256Mbits), Rev: 7.4.80.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0.02V MSID-Crypted: 8481A30EA6F70A79CDC59EF38B MSID-Plain: 2C40BAE90015AFC7AA000000 FAID-Crypted: CA269A43386BB3B603B214D2 Flashbus Write baud set to 6.50Mbits 4 Region(s) to erase Erasing NOR Region [0x01200000-0x0121FFFF] Erasing NOR Region [0x01440000-0x0145FFFF] Erasing NOR Region [0x014C0000-0x014DFFFF] Erasing NOR Region [0x01CE0000-0x01CFFFFF] Erase taken 2.531s Writing 32 blocks... Sending Super DCT4 Emulator... Emulator sent OK! All blocks written OK! Time taken 37.140s Terminating flash session Box VPP disabled Asic 11 HW Signature 5FE76B15659E261B Simlock Server SIMLOCK SERVER Simlock Key 5050200000000000 Simlock Profile 800000000003000B Simlock Aux 000B5555 Simlock IMEI 00553579800302792100 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 50502F Asking card to sign HW Signature... Signed OK (4BE2218392525B29C15E912EAC427E710C16EBB8) Simlock Security - UNKNOWN Writing SP... New SP Accepted OK! Phone unlocked OK! Last edited by ptt; 07-31-2010 at 11:48. Reason: add code tag |
Super DCT4 activation [SOLVED - Thanks PTT] | zeemar | Cyclonebox | 4 | 12-27-2009 17:58 |
how to unlock nokia 2330c-2 RM-512? [SOLVED - Thanks PTT] | husainm | Cyclonebox | 8 | 12-18-2009 16:01 |
super DCT4 activation status [SOLVED] | steca | Cyclonebox | 6 | 11-06-2009 12:24 |
help Super DCT4 Activation still FALSE [SOLVED] | hendra taufik | Cyclonebox | 4 | 10-07-2009 15:52 |
How can activate super dct4 activation ... | hajji1 | Cyclonebox | 3 | 09-17-2009 10:46 |
