Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cyclonebox
Old 04-14-2009, 12:21   #1 (permalink)
hasnain's Avatar
Member: 265626
Sonork: 100.1591486
Thanks Meter: 2,982
Failed to write CMT cert data (3)
getting this error on N70
using adoptor set to pin3
but error is there why ????
flashed with UFS mobile is working ok
again flashed with cyclone
give same error
Old 04-14-2009, 12:26   #2 (permalink)
karwos's Avatar
Member: 117496
Sonork: 100.83919
Thanks Meter: 22,689
If you really sure, about TX2, that adapter and cable is OK, contact me on PM i will try to solve it.
Also, some clue: Your UFS cable pin no. 2 (reserved, PIN 1: VBAT), is this pin wired ? or no ?
Old 04-14-2009, 13:17   #3 (permalink)
hasnain's Avatar
Member: 265626
Sonork: 100.1591486
Thanks Meter: 2,982
problem faced due to 5 pin cable
when i used 7pin cable with adopter
N70 flashed successfully
Backing up certificates...
Booting RAP...
APE_SYSTEM_ASIC_ID: 17100701
APE_ASIC_MODE_ID: 00
APE_PUBLIC_ID: F8B6F13A1BBAE6A57F7628E9AF8EA3790C6BDA8B
APE_ROOT_KEY_HASH: 2C05369F57CC3C4CF9E783E83D9B512B00000000
APE_ROM_ID: AB5E4ADB27A06946
CMT_SYSTEM_ASIC_ID: 000000010000022600010006000C192101002200
CMT_EM_ASIC_ID: 00000232
CMT_EM_ASIC_ID: 00000352
CMT_PUBLIC_ID: 07100211809E4951A320C906B353893505FFE9DF
CMT_ASIC_MODE_ID: 00
CMT_ROOT_KEY_HASH: E9EFF4BFAA5393217CA6B17755FC3E14
CMT_ROM_ID: F28A211FCEA7B19D
RAP3Gv2_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.21.0, Algo: BB5
Flashbus Write baud set to 1.0Mbits
Flashbus Read baud set to 98Kbits
FlashChip[0,CMT]: 0x0001000200000111, AMD, NOR
FlashContent[0,CMT]: 00000000000000000000000000000000, NOR
FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC
Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit
RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: BB5 ALGORITHM
Flashbus Write baud set to 4.0Mbits
Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit
Box TX2 Data Pin set to: Service Pin 3
Box VPP disabled
Internal CMT Phone VPP Enabled
PAPUBKEYS Hash for CMT: 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D
helen3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.35.0, Algo: BB5
FlashChip[0,APE]: 0x00EC003600A500C0, Samsung, NAND
Requested Algorithm: OMAP1610 GBBM-1.8.1 ALG (APE)
FlashContent[0,APE]: 00020000000600000000000000000000, NAND
h3_sam_nand_format.fg, Type: Algorithm, Rev: 0.1.16.255, Algo: OMAP1610 FORMAT ALG
Box VPP disabled
Internal APE Phone VPP Enabled
PAPUBKEYS Hash for APE: 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D
CMT NPC Ok
CMT HWC Not Found
CMT CCC Not Found
CMT R&D Ok
CMT VARIANT Ok
CMT PAPUBKEYS Ok
CMT KEYS Ok
APE NPC Not Found
APE HWC Not Found
APE CCC Not Found
APE R&D Ok
APE VARIANT Not Found
APE PAPUBKEYS Ok
APE KEYS Not Found
Restarting MCU...
Read all certificates finished
Certificates backup thread finished, continuing...
Backing up simlock...
Starting PM read in range 308-308...
[308] Reading 4 records
[308,0] Reading 1 bytes
[308,1] Reading 4096 bytes
[308,3] Reading 1 bytes
[308,4] Reading 1 bytes
PM Read OK, Time taken 1.0s
Simlock backup OK
Backup simlock thread finished, continuing...
Pre flash tasks finished, continuing...
Processing RM84_50737301.C0 (CMT)...
Booting RAP...
RM84_50737301.C0, Type: Flash Image, Algo: BB5, BB5 ALGORITHM, BB5, OMAP1610 GBBM-1.8.1 ALG
Flashbus Write baud set to 650Kbits
Box VPP disabled
Partitioning...
Partitioning OK
Started group flash erase
EraseArea[0,CMT]: 0x00000000-0x0052B515, NOR
EraseArea[0,CMT]: 0x006A0000-0x006BFFFF, NOR
EraseArea[0,CMT]: 0x006DF000-0x006EFFFF, NOR
EraseArea[0,CMT]: 0x00700000-0x007EFFFF, NOR
Waiting 320s for erasure finish...
Erase taken 46.656s
Writing all blocks...
Writing CMT NOLO Certificate...
Writing CMT KEYS Certificate...
Writing CMT PRIMAPP Certificate...
Writing CMT DSP0 Certificate...
Writing CMT MCUSW Certificate...
Writing CMT PASUBTOC Certificate...
Writing CMT PAPUBKEYS Certificate...
Skipping CMT PAPUBKEYS Certificate (already sent)...
Programming Status OK!
All blocks written OK! Time taken 34.531s
Restarting MCU...
Processing RM84_50737301.C0 (APE)...
Booting RAP...
Box VPP disabled
h3_sam_nand_gbbm.fg, Type: Algorithm, Rev: 0.1.33.0, Algo: OMAP1610 GBBM-1.8.1 ALG
Box VPP disabled
Partitioning...
Partitioning OK
EraseArea[0,APE]: 0x00000000-0x0000FFFF, NAND
EraseArea[0,APE]: 0x00010000-0x0001FFFF, NAND
EraseArea[0,APE]: 0x00020000-0x000203FF, NAND
EraseArea[0,APE]: 0x00050000-0x03ECFFFF, NAND
Erase taken 6.844s
Writing APE KEYS Certificate...
Writing APE X-LOADER Certificate...
Writing APE PRIMAPP Certificate...
Writing APE SOS+LOADER Certificate...
Writing APE SOS+XZIP Certificate...
Writing APE PASUBTOC Certificate...
Writing APE PAPUBKEYS Certificate...
Skipping APE PAPUBKEYS Certificate (already sent)...
Writing APE SOS*CORE Certificate...
All blocks written OK! Time taken 48.703s
Restarting MCU...
Processing RM84_50737301.V03 (CMT)...
Processing RM84_50737301.V03 (APE)...
Booting RAP...
RM84_50737301.V03, Type: Flash Image, Algo: BB5, OMAP1610 GBBM-1.8.1 ALG, BB5, BB5 ALGORITHM
Flashbus Read baud set to 100Kbits
Box VPP disabled
Box VPP disabled
Partitioning...
Partitioning OK
EraseArea[0,APE]: 0x01AE0000-0x02AFFFFF, NAND
EraseArea[0,APE]: 0x02B00000-0x03ECFFFF, NAND
Erase taken 3.937s
All blocks written OK! Time taken 33.718s
Restarting MCU...
Processing RM84_50737301.UDA (CMT)...
Processing RM84_50737301.UDA (APE)...
Booting RAP...
RM84_50737301.UDA, Type: Flash Image, Algo: BB5, OMAP1610 GBBM-1.8.1 ALG, BB5, BB5 ALGORITHM
Box VPP disabled
Box VPP disabled
All blocks written OK! Time taken 15.47s
Restarting MCU...
All images processed OK! Processing post flash tasks...
Setting Factory Defaults...
Factory defaults OK
Reading info...
MCU Version V 05wk07v48.1
MCU Date 28-08-07
Product RM-84
Manufacturer (c) Nokia.
IMEI *****************
IMEI Spare *****************
IMEI SV *****************2000000
PSN CIH650920
Product Code 0524086
Basic Product Code 0522156
PSD 0000001700000000
RETU 32
TAHVO 52
AHNE 22
HW 6001
DSP rolf_05wk07v29p1
The Following 2 Users Say Thank You to hasnain For This Useful Post:
Old 04-15-2009, 12:10   #4 (permalink)
Amir-SkillZ's Avatar
Member: 91045
Thanks Meter: 8,695
nice u get ur Problem solved quickly
always use 7pin cable for a proper stable flashing for BB5 phones
*** Failed to write CMT cert data (3), Programming Status Error *** karwos Cyclonebox 62 05-23-2013 20:20
Failed to write imei..????? sky_finder MXKEY Nokia Flasher and Unlocker (by Alim Hape) 1 03-30-2010 15:45
5800 KILLED Block Write Failed -> Failed to write CMT cert data (3) [SOLVED] x_gsm Cyclonebox 22 02-14-2010 15:17
BB5 Unlock Failed -> Failed to write Security Block sege Cyclonebox 1 10-26-2009 18:17
Failed to Write CMT NPC Certificate N81 bleck Cyclonebox 18 07-26-2009 04:33
Page generated in 0.22775 seconds with 9 queries
