Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | ★ Wholesale Unlock ★ | Direct Unlock Source | Mark Forums Read |
![]() | #1 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Apr 2005 Location: france
Member: 135019 Status: Offline Thanks Meter: 1 | Failed to Write CMT NPC Certificate N81 fault was mine, forget to plug adaptor. But when i write cert, allways obtain Failed to Write CMT NPC Certificate I-ve tried with and without repower on boot, with and without use TX2, with and without external power, but same result. What can i do? Thanks |
![]() | #3 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2009 Location: England Age: 58
Member: 947561 Status: Offline Thanks Meter: 14,048 | Quote:
remember the file to restore starts with the CMT_PUBLIC_ID of the mobile... BR Alex | |
![]() | #4 (permalink) | |
Member: 135019 Status: Offline Thanks Meter: 1 | Quote:
All initialized - Ready to work MCU Version V 06wk41v47.2 MCU Date 23-11-07 Product RM-223 Manufacturer (c) Nokia IMEI 12345610654321? Failed to read info -> '?' is not a valid integer value | |
![]() | #5 (permalink) |
Member: 947561 Status: Offline Thanks Meter: 14,048 | it is a quite hard to get from there the cmt_public_id ![]() no problem.. just clik of read ask from fbus.. the file ask will start whit the same name of the cert file you must write on the phone once you get the right file .sx4bypass.NPC.CMT.crt just click on write crt and select it BR Alex |
![]() | #6 (permalink) | |
Nokia DCT4/WD2/BB5 Service Tool Initialization Started, Engine Revision: 1.0.0.7396 Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia Application v1.05, (Jun 22 2009 12:23:29, gcc-4.2.2, RTOS v5.2.0), Type: Signed Production Application, Flags: CONST-TX2-PIN ; VISTA-SUPPORT ; BB5-NCK-CALC Box Serial Number: C0001247 HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: Unknown Initializing security card... Card Serial Number: D000089E Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 4,97v PASSED MCU Voltage 3,29v PASSED Core Voltage 1,77v PASSED VBAT Voltage 1,42v PASSED VBAT Voltage 5,00v PASSED Box VPP disabled VPP Voltage 0,02v PASSED Internal Box VPP Enabled VPP Voltage 5,06v PASSED Box VPP disabled VPP Voltage 0,02v PASSED External Box VPP Enabled VPP Voltage 5,46v PASSED Box VPP disabled All box selftests passed! Initializing FBUS... All initialized - Ready to work 0960011648860058125C28794AD334C29B636E84_17072009_ 192359.ask Saved successfully! Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101021103 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 0960011648860058125C28794AD334C29B636E84 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 9A28E119033B91D14D22838C86D0D53C CMT_ROM_ID: A8C1D6713E691FF8 RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.37.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x00EC003000600121, Samsung, ONENAND FlashContent[0,CMT]: 00000000000000000000000000000000, ONENAND FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAPIDOv11_algo.fg, Type: Algorithm, Rev: 0.1.35.0, Algo: XSR 1.5 Flashbus Write baud set to 4.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: E70C21157D5AB5AF61AAD376910751FB06D6E9FD APE Subsystem Not Found Processing 0960011648860058125C28794AD334C29B636E84_17072009_ 192359.ask... Failed to Write C:\Archivos de programa\Cyclone Box\StoredFiles\0960011648860058125C28794AD334C29B 636E84_17072009_192359 Certificate -> Unknown SubSystem name (C:\Archivos de programa\Cyclone Box\StoredFiles\0960011648860058125C28794AD334C29B 636E84_17072009_192359) detected | |
![]() | #8 (permalink) | |
Nokia DCT4/WD2/BB5 Service Tool Initialization Started, Engine Revision: 1.0.0.7396 Handling device: [Cyclone Team], [Cyclone Bootloader] Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia Application v1.05, (Jun 22 2009 12:23:29, gcc-4.2.2, RTOS v5.2.0), Type: Signed Production Application, Flags: CONST-TX2-PIN ; VISTA-SUPPORT ; BB5-NCK-CALC Box Serial Number: C0001247 HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: Unknown Initializing security card... Card Serial Number: D000089E Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 5,02v PASSED MCU Voltage 3,29v PASSED Core Voltage 1,77v PASSED VBAT Voltage 0,67v PASSED VBAT Voltage 5,01v PASSED Box VPP disabled VPP Voltage 0,02v PASSED Internal Box VPP Enabled VPP Voltage 5,06v PASSED Box VPP disabled VPP Voltage 0,04v PASSED External Box VPP Enabled VPP Voltage 5,42v PASSED Box VPP disabled All box selftests passed! Initializing FBUS... All initialized - Ready to work Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101021103 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 0960011648860058125C28794AD334C29B636E84 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 9A28E119033B91D14D22838C86D0D53C CMT_ROM_ID: A8C1D6713E691FF8 RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.37.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x00EC003000600121, Samsung, ONENAND FlashContent[0,CMT]: 00000000000000000000000000000000, ONENAND FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAPIDOv11_algo.fg, Type: Algorithm, Rev: 0.1.35.0, Algo: XSR 1.5 Flashbus Write baud set to 4.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: E70C21157D5AB5AF61AAD376910751FB06D6E9FD APE Subsystem Not Found Processing 0960011648860058125C28794AD334C29B636E84.Sx4Bypass .NPC.CMT.crt... CMT NPC Erased CBUS Request Error -> CBUS Response wrong header Failed to Write CMT NPC Certificate -> Failed to write CMT NPC certificate | |
![]() | #9 (permalink) | |
download the update from this url http://rapidshare.com/files/24744090...one7828NCK.rar Unzip all the file in the folder where Cyclone software is installed (Normally c:\program files\Cyclone box) answerin yes when asked to overwrite for all the files.. After this retry the job. BR Alex | |
![]() | #10 (permalink) | |
Nokia DCT4/WD2/BB5 Service Tool Initialization Started, Engine Revision: 1.0.0.7828 Handling device: [Cyclone Team], [Cyclone Bootloader] Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia Application v1.05, (Jun 22 2009 12:23:29, gcc-4.2.2, RTOS v5.2.0), Type: Signed Production Application, Flags: CONST-TX2-PIN ; VISTA-SUPPORT ; BB5-NCK-CALC Box Serial Number: C0001247 HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk14 Initializing security card... Card Serial Number: D000089E Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 5,02v PASSED MCU Voltage 3,29v PASSED Core Voltage 1,77v PASSED VBAT Voltage 0,55v PASSED VBAT Voltage 5,01v PASSED Box VPP disabled VPP Voltage 0,04v PASSED Internal Box VPP Enabled VPP Voltage 5,06v PASSED Box VPP disabled VPP Voltage 0,04v PASSED External Box VPP Enabled VPP Voltage 5,42v PASSED Box VPP disabled All box selftests passed! Initializing FBUS... All initialized - Ready to work Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101021103 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 0960011648860058125C28794AD334C29B636E84 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 9A28E119033B91D14D22838C86D0D53C CMT_ROM_ID: A8C1D6713E691FF8 RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.37.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x00EC003000600121, Samsung, ONENAND FlashContent[0,CMT]: 00000000000000000000000000000000, ONENAND FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAPIDOv11_algo.fg, Type: Algorithm, Rev: 0.1.35.0, Algo: XSR 1.5 Flashbus Write baud set to 4.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: E70C21157D5AB5AF61AAD376910751FB06D6E9FD APE Subsystem Not Found Processing 0960011648860058125C28794AD334C29B636E84.Sx4Bypass .NPC.CMT.crt... CMT NPC Erased CBUS Request Error -> CBUS Response wrong header Failed to Write CMT NPC Certificate -> Failed to write CMT NPC certificate | |
![]() | #14 (permalink) |
Member: 135019 Status: Offline Thanks Meter: 1 | Here is the log Nokia DCT4/WD2/BB5 Service Tool Initialization Started, Engine Revision: 1.0.0.7828 Handling device: [Cyclone Team], [Cyclone Bootloader] Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia Application v1.05, (Jun 22 2009 12:23:29, gcc-4.2.2, RTOS v5.2.0), Type: Signed Production Application, Flags: CONST-TX2-PIN ; VISTA-SUPPORT ; BB5-NCK-CALC Box Serial Number: C0001247 HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk14 Initializing security card... Card Serial Number: D000089E Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 5,02v PASSED MCU Voltage 3,29v PASSED Core Voltage 1,77v PASSED VBAT Voltage 0,63v PASSED VBAT Voltage 5,01v PASSED Box VPP disabled VPP Voltage 0,04v PASSED Internal Box VPP Enabled VPP Voltage 5,06v PASSED Box VPP disabled VPP Voltage 0,04v PASSED External Box VPP Enabled VPP Voltage 5,42v PASSED Box VPP disabled All box selftests passed! Initializing FBUS... All initialized - Ready to work Skipping RPL decryption... Parsing decrypted RPL... Processing FBUS Part... Writing Simlock... Simlock ACCEPTED OK ! Processing FLASHBUS Part... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101021103 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 0960011648860058125C28794AD334C29B636E84 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 9A28E119033B91D14D22838C86D0D53C CMT_ROM_ID: A8C1D6713E691FF8 RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.37.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x00EC003000600121, Samsung, ONENAND FlashContent[0,CMT]: 00000000000000000000000000000000, ONENAND FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAPIDOv11_algo.fg, Type: Algorithm, Rev: 0.1.35.0, Algo: XSR 1.5 Flashbus Write baud set to 4.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: E70C21157D5AB5AF61AAD376910751FB06D6E9FD APE Subsystem Not Found Restarting MCU... Write RPL Finished! |
*** Failed to write CMT cert data (3), Programming Status Error *** | karwos | Cyclonebox | 62 | 05-23-2013 20:20 |
Failed to write imei..????? | sky_finder | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 03-30-2010 15:45 |
5800 KILLED Block Write Failed -> Failed to write CMT cert data (3) [SOLVED] | x_gsm | Cyclonebox | 22 | 02-14-2010 15:17 |
BB5 Unlock Failed -> Failed to write Security Block | sege | Cyclonebox | 1 | 10-26-2009 18:17 |
Failed to write CMT cert data (3) | hasnain | Cyclonebox | 3 | 04-15-2009 12:10 |
