lumia 800 flashing problem im trying to flash a nokia lumia 800 stuck on the nokia logo. when i try to flash i get an error: Establishing Connection with Box in Main Mode... Handling device: [Cyclone Team], [Cyclone Bootloader], [Platform: Classic] Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic] Initializing box... Box Firmware: Cyclone Main Application v02.20, (Aug 6 2013 20:31:40, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012 Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs Box Serial Number: C0002B71 HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk32 Initializing security card... Card Serial Number: DA0000D1 Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 4.96v PASSED MCU Voltage 3.31v PASSED Core Voltage 1.79v PASSED VBAT Voltage 0.01v PASSED VBAT Voltage 4.88v PASSED Box VPP disabled VPP Voltage 0.02v PASSED Internal Box VPP Enabled VPP Voltage 4.79v PASSED Box VPP disabled VPP Voltage 0.04v PASSED External Box VPP Enabled VPP Voltage 0.02v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE XGold/Blackberry Service Running, Counter: 100 Lumia No TP is NOT ACTIVATED! (1) Avaiable Physical Memory: 2.716GB Avaiable Virtual Memory: 1.793GB Avaiable Pagefile: 3.1023GB Initializing FBUS... All initialized - Ready to work Scanning avaiable products... Processing C:\Program Files (x86)\Cyclone Box\StoredFiles\LandingZone\... Processing C:\ProgramData\Nokia\Packages\Products\... Processing E:\Nokia firmware files\RM-596-11.5-scandinavia\... Found 5 products, Filtering BB5 Products - wait... 3 Products left after filtering. Ready. Retrieving Variants for Product RM-801 - wait... 3 Variants Retrieved If phone is alive, It will be automatically swithced to OSBL mode. If software can't switch to OSBL mode, or phone is generally DEAD do folllowing: 1. Turn OFF device, wait 15 seconds afterwards 2. Eject USB cable, wait 10 seconds 3. Press and hold Volume-UP button 4. Insert USB Cable. OSBL should be booted. Booting CMT... [Nokia USB Connectivity]: WinUSB Port opened OK! OSBL Bootloader Kick Failed -> WinUSB Exchange Problem Failed to Boot CMT -> Failed to get First Boot Block Prepare phone failed with message -> Failed to Boot CMT Process ESCO Image Failed -> Failed to Boot OSBL Failed to Flash WP7 -> Failed to Flash All ESCO Images does anybody know how to get around this problem? |
ive managed to install the bootloader through nss and flash. then it gives another error: Establishing Connection with Box in Main Mode... Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic] Initializing box... Box Firmware: Cyclone Main Application v02.20, (Aug 6 2013 20:31:40, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012 Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs Box Serial Number: C0002B71 HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk32 Initializing security card... Card Serial Number: DA0000D1 Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 4.94v PASSED MCU Voltage 3.31v PASSED Core Voltage 1.79v PASSED VBAT Voltage 0.01v PASSED VBAT Voltage 4.87v PASSED Box VPP disabled VPP Voltage 0.00v PASSED Internal Box VPP Enabled VPP Voltage 4.79v PASSED Box VPP disabled VPP Voltage 0.04v PASSED External Box VPP Enabled VPP Voltage 0.02v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE XGold/Blackberry Service Running, Counter: 100 Lumia No TP is NOT ACTIVATED! (1) Avaiable Physical Memory: 2.125GB Avaiable Virtual Memory: 1.777GB Avaiable Pagefile: 3.1023GB Initializing FBUS... All initialized - Ready to work If phone is alive, It will be automatically swithced to OSBL mode. If software can't switch to OSBL mode, or phone is generally DEAD do folllowing: 1. Turn OFF device, wait 15 seconds afterwards 2. Eject USB cable, wait 10 seconds 3. Press and hold Volume-UP button 4. Insert USB Cable. OSBL should be booted. Booting CMT... [Nokia USB Connectivity]: WinUSB Port opened OK! OSBL Details Protocol: v1.1 Version: v257.6 Build: 12 Timestamp: 17/02/2012 13:40:05 OSBL Bootloader Ready USB&UART Tracing set [HA Auth] : Not elevating, will not flash unsigned images ESCO: Processing RM801_12w22_prod_generic_nokia_osbl.esco... OSBL Certificate Details Magic: WP70 Version: 0 Signer Server ID: 0x98031568 Signer Timestamp: 01/06/2012 11:39:47 Signer S/N: 1563 Signer User ID: 10315817 Auth Level: Care Data Encryption: 0 Image Index: 1 Asic Index: 0 Type: Image Write Hashtable Parsed OK Sending Certificate... Certificate Accepted... [ASIC 0, Storage 4,1] Writing 936.552kB @ 0x000000000007D200 Write taken 1.219s (Average speed: 6293.79kBits/s) ESCO: Processing RM801_12w22_prod_generic_amss.esco... OSBL Certificate Details Magic: WP70 Version: 0 Signer Server ID: 0x98031573 Signer Timestamp: 01/06/2012 11:39:46 Signer S/N: 1606 Signer User ID: 10315817 Auth Level: None Data Encryption: 1 Image Index: 4 Asic Index: 0 Type: File Write Hashtable Parsed OK Sending Certificate... Certificate Accepted... [ASIC 0, Storage 4,1] Writing File "amss.mbn" (15.961MB), Partition: 0 Flushing... Flushed OK Write taken 25.500s (Average speed: 5243.41kBits/s) ESCO: Processing RM801_12w22_prod_generic_adsp.esco... OSBL Certificate Details Magic: WP70 Version: 0 Signer Server ID: 0x98031568 Signer Timestamp: 01/06/2012 11:32:05 Signer S/N: 1562 Signer User ID: 10315817 Auth Level: None Data Encryption: 1 Image Index: 3 Asic Index: 0 Type: File Write Hashtable Parsed OK Sending Certificate... Certificate Accepted... [ASIC 0, Storage 4,1] Writing File "adsp.mbn" (5.368MB), Partition: 0 Flushing... Flushed OK Write taken 8.31s (Average speed: 5598.74kBits/s) ESCO: Processing RM801_12220_prod_797_01_boot.esco... OSBL Certificate Details Magic: WP70 Version: 0 Signer Server ID: 0x98030051 Signer Timestamp: 15/06/2012 10:33:16 Signer S/N: 73 Signer User ID: 4177304576 Auth Level: None Data Encryption: 0 Image Index: 2 Asic Index: 0 Type: Image Write Hashtable Parsed OK Sending Certificate... Certificate Accepted... [ASIC 0, Storage 4,1] Writing 375.312MB @ 0x0000000010000000 Write ESCO Image Failed -> WinUSB Exchange Problem Process ESCO Image Failed -> Image Write Failed Failed to Flash WP7 -> Failed to Flash All ESCO Images |
Booting CMT... [Nokia USB Connectivity]: WinUSB Port opened OK! OSBL Bootloader Kick Failed -> WinUSB Exchange Problem Failed to Boot CMT -> Failed to get First Boot Block Prepare phone failed with message -> Failed to Boot CMT Process ESCO Image Failed -> Failed to Boot OSBL Failed to Flash WP7 -> Failed to Flash All ESCO Images same error in nokia 510 |
