Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cyclonebox
Old 07-29-2010, 12:22   #1 (permalink)
Member: 193781
Thanks Meter: 22
N93i Flash Problem
Dear mates,
I tried to flash an N93i rm-156, after erase it does not write. And mobile is dead now.
First i flashed with TX2 line selected and it gave error
Log:
Handling device: [Cyclone Team], [Cyclone Bootloader]
Handling device: [Cyclone Team], [Cyclone Box]
Initializing box...
Box Firmware: Cyclone Nokia Application v01.46, (Jul 24 2010 23:54:36, gcc v4.3.2, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2010 wk27
Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs
Box Serial Number: C0000127
HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2008, wk32
Initializing security card...
Card Serial Number: D000004A
Card Firmware Revision: 0109
Card is activated
Box is activated
Started box selftests procedure
USB Voltage 5.16v PASSED
MCU Voltage 3.28v PASSED
Core Voltage 1.83v PASSED
VBAT Voltage 0.86v PASSED
VBAT Voltage 4.71v PASSED
Box VPP disabled
VPP Voltage 0.09v PASSED
Internal Box VPP Enabled
VPP Voltage 4.95v PASSED
Box VPP disabled
VPP Voltage 0.02v PASSED
External Box VPP Enabled
VPP Voltage 0.02v FAILED - IGNORED - Probably power supply is not connected
Box VPP disabled
All box selftests passed!
Super DCT4 Activation: TRUE
Initializing FBUS...
All initialized - Ready to work
Scanning avaiable products...
Processing C:\Program Files\Nokia\Phoenix\Products\...
Found 1 products, Filtering BB5 Products - wait...
1 Products left after filtering. Ready.
Retrieving Variants for Product RM-156 - wait...
54 Variants Retrieved
Processing pre flash tasks...
Pre flash tasks finished, continuing...
Processing RM156PE300013.C0 (CMT)...
Booting CMT...
APE_SYSTEM_ASIC_ID: 24200705
APE_ASIC_MODE_ID: 00
APE_PUBLIC_ID: 3304D93D23E575E0F2B16CFF23106161A7BD3709
APE_ROOT_KEY_HASH: BA8710A7E1CD5A2909B9A875DB27AA2400000000
CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000
CMT_EM_ASIC_ID: 00000295
CMT_EM_ASIC_ID: 00000B21
CMT_PUBLIC_ID: 16900013269001547B474C6193C68651410ED062
CMT_ASIC_MODE_ID: 00
CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
CMT_BOOT_ROM_CRC: 273F6D55
CMT_SECURE_ROM_CRC: DFAAF68F
CMT Ready!
RM156PE300013.C0, Type: Flash Image, Algo: BB5, BB5 ALGORITHM, BB5, OMAP2420 UNISTORE-II-1.2.1 ALG
Searching for BootCode: DualLine 32Bit
RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.6.0, Algo: BB5
Flashbus Write baud set to 51Kbits
Flashbus Read baud set to 98Kbits
Using OLD BB5 FLASHING PROTOCOL
FlashChip[0,CMT]: 0x00EC22E800006921, Samsung, NOR
FlashContent[0,CMT]: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF, NOR
FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC
Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit
FlashChip 0x00EC22E8 (Samsung), Size: 16MBytes, VPP: 9V
RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.6.0, Algo: BB5 ALGORITHM
Flashbus Write baud set to 2.0Mbits
Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit
Box TX2 Data Pin set to: Service Pin 3
Box VPP disabled
Internal CMT Phone VPP Enabled
Warning: PAPUBKEYS Hash Missing!
Flashbus Write baud set to 5.0Mbits
Sending Certificates...
Certificates OK
Partitioning...
Partitioning OK
Started group flash erase
EraseArea[0,CMT]: 0x00080000-0x0075118D, NOR
EraseArea[0,CMT]: 0x00000000-0x0005FFFF, NOR
EraseArea[0,CMT]: 0x00880000-0x00FEFFFF, NOR
Waiting 320s for erasure finish...
Erase taken 3.375s
Writing all blocks...
Block Write Failed -> Failed to write CMT data header at 0x245
Processing Flash Image Failed -> Failed to write all blocks
Failed to Process all Image files -> Failed to process RM156PE300013.C0
AND with TX2 line unselected
log:
Booting CMT...
CMT Ready!
Searching for BootCode: Single Line 8Bit
RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5
RAP3Gv3_algo_fps8.fg, Type: Algorithm, Rev: 0, Algo: BB5 ALGORITHM
Box VPP disabled
Certificates OK
Partitioning...
Partitioning OK
Erase taken 3.391s
What should i do now? Suggestions will be really appreciated.
Best regards
Old 07-29-2010, 16:42   #2 (permalink)
Mr.3.'s Avatar
Member: 962029
Sonork: OEM Lock : ON
Thanks Meter: 4,139
use goood cable to recover this phone
The Following User Says Thank You to Mr.3. For This Useful Post:
Old 08-15-2012, 15:19   #3 (permalink)
Member: 781000
Totally same problem with Cyclone Box! At the same adress. Bug maybe?
The Following User Says Thank You to kingbigjohn1 For This Useful Post:
Old 08-15-2012, 15:22   #4 (permalink)
Member: 1594589
Thanks Meter: 3
Exclamation
I can confirm that i have the same problem with RM-156. Stuck with writing new firmware on address 0x245.
Any solution or ideas?
need to flash 6110 paulomt1 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 08-16-2019 19:37
5110 flash new software , need help steve Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 01-03-2015 05:41
HELP: Problem with 5110 Xabi Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 07-16-1999 00:44
Page generated in 0.16050 seconds with 9 queries
