02-22-2010, 05:29 | #1 (permalink) |
Insane Poster Join Date: Feb 2009
Member: 970686 Status: Offline Sonork: none Thanks Meter: 38 | need help 3110c phone restricted after flashing [SOLVED - Thanks Everybody] the phone problem is no power i don't have any back up here logs: Code: Scanning avaiable products... Processing C:\Program Files\Nokia\Phoenix\Products\... Found 36 products, Filtering BB5 Products - wait... 2 Products left after filtering. Ready. Retrieving Variants for Product RM-237 - wait... 284 Variants Retrieved Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101001101 CMT_EM_ASIC_ID: 00000232 CMT_EM_ASIC_ID: 00000353 CMT_PUBLIC_ID: 2DD00016FF2A7E56DB905780188578B8F4FE25F5 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_ROM_ID: 191EC665DFAAF68F RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.9.11.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x0089898100006A21, Intel, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.9.17.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: C0E691EA16A7593A9BB28832D7312A39F7ED668D APE Subsystem Not Found Flashbus Write baud set to 5.0Mbits Restarting MCU... Failed to read info -> Phone not detected Processing pre flash tasks... Backing up RPL... RPL Creation started... Processing CMT Part... Failed to Create RPL from phone -> Phone not detected RPL backup thread finished, continuing... Backing up simlock... Simlock backup problem -> Phone not detected Backup simlock thread finished, continuing... Pre flash tasks finished, continuing... Processing rm237__07.21.mcusw (CMT)... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101001101 CMT_EM_ASIC_ID: 00000232 CMT_EM_ASIC_ID: 00000353 CMT_PUBLIC_ID: 2DD00016FF2A7E56DB905780188578B8F4FE25F5 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_ROM_ID: 191EC665DFAAF68F rm237__07.21.mcusw, Type: Flash Image, Algo: BB5, BB5 ALGORITHM RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.9.11.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x0089898100006A21, Intel, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.9.17.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: C0E691EA16A7593A9BB28832D7312A39F7ED668D Flashbus Write baud set to 5.0Mbits Sending Certificates... Certificates OK Started group flash erase EraseArea[0,CMT]: 0x00000000-0x000006BF, NOR EraseArea[0,CMT]: 0x000006C0-0x0001FFFF, NOR EraseArea[0,CMT]: 0x00020000-0x0007FFFF, NOR EraseArea[0,CMT]: 0x00080000-0x000DFFFF, NOR EraseArea[0,CMT]: 0x00100000-0x001FFFFF, NOR EraseArea[0,CMT]: 0x00200000-0x0031FFFF, NOR EraseArea[0,CMT]: 0x00320000-0x0105FFFF, NOR EraseArea[0,CMT]: 0x01060000-0x01067FFF, NOR EraseArea[0,CMT]: 0x01068000-0x0107FFFF, NOR Waiting 320s for erasure finish... Erase taken 75.687s Writing all blocks... Writing CMT NOLO Certificate... Writing CMT KEYS Certificate... Writing CMT PRIMAPP Certificate... Writing CMT PASUBTOC Certificate... Writing CMT PAPUBKEYS Certificate... Skipping CMT PAPUBKEYS Certificate (already sent)... Writing CMT UPDAPP Certificate... Writing CMT DSP0 Certificate... Writing CMT MCUSW Certificate... Writing CMT PMM_CONF Certificate... Writing CMT SBIF_CONF Certificate... Programming Status OK! All blocks written OK! Time taken 69.641s Restarting MCU... Processing rm237__07.21.mcusw (APE)... Processing rm237__07.21.ppm_v (CMT)... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101001101 CMT_EM_ASIC_ID: 00000232 CMT_EM_ASIC_ID: 00000353 CMT_PUBLIC_ID: 2DD00016FF2A7E56DB905780188578B8F4FE25F5 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_ROM_ID: 191EC665DFAAF68F rm237__07.21.ppm_v, Type: Flash Image, Algo: BB5, BB5 ALGORITHM RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.9.11.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x0089898100006A21, Intel, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.9.17.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: C0E691EA16A7593A9BB28832D7312A39F7ED668D Flashbus Write baud set to 5.0Mbits Started group flash erase EraseArea[0,CMT]: 0x01080000-0x0151FFFF, NOR Waiting 320s for erasure finish... Erase taken 22.47s Writing all blocks... Programming Status OK! All blocks written OK! Time taken 16.172s Restarting MCU... Processing rm237__07.21.ppm_v (APE)... Processing rm237__07.21.image_v (CMT)... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101001101 CMT_EM_ASIC_ID: 00000232 CMT_EM_ASIC_ID: 00000353 CMT_PUBLIC_ID: 2DD00016FF2A7E56DB905780188578B8F4FE25F5 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_ROM_ID: 191EC665DFAAF68F rm237__07.21.image_v, Type: Flash Image, Algo: BB5, BB5 ALGORITHM RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.9.11.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x0089898100006A21, Intel, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.9.17.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: C0E691EA16A7593A9BB28832D7312A39F7ED668D Flashbus Write baud set to 5.0Mbits Started group flash erase EraseArea[0,CMT]: 0x01520000-0x01FDFFFF, NOR Waiting 320s for erasure finish... Erase taken 88.140s Writing all blocks... Programming Status OK! All blocks written OK! Time taken 19.719s Restarting MCU... Processing rm237__07.21.image_v (APE)... All images processed OK! Processing post flash tasks... Reading info... MCU Version V 07.21 MCU Date 05-11-08 Product RM-237 Manufacturer (c) Nokia. IMEI 359343025215071 Mastercode 604355636 IMEI Spare 3A95430352120507 IMEI SV 3395430352120527F5000000 PPM V 07.21, 05-11-08, RM-237, (c) Nokia. , V PSN MKN141702 Product Code 0554210 Module Code 0203291 Basic Product Code 0553909 PSD 0000000000000000 RETU 32 TAHVO 53 AHNE 11 HW 5008 RFIC 17211721 DSP ICPR61_08w10 BT 06cc-P9.1 Failed to read info -> Failed to read SP info Read info thread finished, continuing... Post flash tasks finished! Flashing successfully finished! phone info: selftest is ok help please........thank's |
02-22-2010, 07:00 | #4 (permalink) |
Banned Join Date: Jul 2005 Location: Philippines Age: 53
Member: 161739 Status: Offline Sonork: 100.1584054 Thanks Meter: 3,338 | please please unlock your phone not help?? go here:http://forum.gsmhosting.com/vbb/showthread.php?t=933178 |
The Following User Says Thank You to FullFLASHgSMPH For This Useful Post: |
02-22-2010, 08:02 | #6 (permalink) |
No Life Poster Join Date: Jul 2008 Location: BHARAT Age: 42
Member: 823633 Status: Offline Thanks Meter: 1,705 | 3110c phone restricted solu 3110c phone restricted solu 20100222122734.png |
The Following 2 Users Say Thank You to vaghubha_sodha For This Useful Post: |
02-22-2010, 08:27 | #7 (permalink) | |
Member: 970686 Status: Offline Sonork: none Thanks Meter: 38 | Quote:
thank you sir ...my problem solved i try to unlock done.. HERE UNLOCK LOGS: Code: Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101001101 CMT_EM_ASIC_ID: 00000232 CMT_EM_ASIC_ID: 00000353 CMT_PUBLIC_ID: 2DD00016FF2A7E56DB905780188578B8F4FE25F5 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_ROM_ID: 191EC665DFAAF68F RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.9.11.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x0089898100006A21, Intel, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.9.17.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: C0E691EA16A7593A9BB28832D7312A39F7ED668D APE Subsystem Not Found Flashbus Write baud set to 5.0Mbits Restarting MCU... BB5 Unlock Started... MCU Version V 07.21 MCU Date 05-11-08 Product RM-237 Manufacturer (c) Nokia. IMEI 359343025215071 Mastercode 604355636 Simlock Server SIMLOCK SERVER VERSION 63 Simlock Key FFFFFFFFFFFFFFFF Simlock Profile FFFFFFFFFFFFFFFF Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 00101F Simlock NCK #pw+@Uÿÿÿÿÿÿÿÿÿÿ+17# Simlock NCK #pw+ÿÿÿÿÿ8ÿÿÿÿÿÿÿÿ+255# Simlock NCK #pw+ÿÿÿÿÿÿÿÿÿÿ+255# Simlock NCK #pw+ÿÿø4ÿ+111# Reading Security Block... Security block OK! Determining PA Simlock... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101001101 CMT_EM_ASIC_ID: 00000232 CMT_EM_ASIC_ID: 00000353 CMT_PUBLIC_ID: 2DD00016FF2A7E56DB905780188578B8F4FE25F5 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_ROM_ID: 191EC665DFAAF68F RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.9.11.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x0089898100006A21, Intel, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.9.17.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: C0E691EA16A7593A9BB28832D7312A39F7ED668D APE Boot skipped on user request Flashbus Write baud set to 5.0Mbits Restarting MCU... Determined PA Simlock: PA_SL Checking for Rootkey Hash support and selecting Unlock Method... Selected Unlock Method: PM Security Block Calculation Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101001101 CMT_EM_ASIC_ID: 00000232 CMT_EM_ASIC_ID: 00000353 CMT_PUBLIC_ID: 2DD00016FF2A7E56DB905780188578B8F4FE25F5 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_ROM_ID: 191EC665DFAAF68F RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Exploiting - running preloader... Preloader running OK, Running Custom Loader... Custom loader running OK! Working... Received Security Block OK ! Writing Security Block... SP Accepted, doing reset to update block... MCU Version V 07.21 MCU Date 05-11-08 Product RM-237 Manufacturer (c) Nokia. IMEI 359343025215071 Mastercode 604355636 Simlock Server SIMLOCK SERVER VERSION 63 Simlock Key 2440700000000000 Simlock Profile 8000000000000006 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [1,2] State: OPENED Type: GID Data: FFFF Simlock [1,3] State: OPENED Type: GID Data: FFFF Simlock [1,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [1,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [2,2] State: OPENED Type: GID Data: FFFF Simlock [2,3] State: OPENED Type: GID Data: FFFF Simlock [2,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [3,2] State: OPENED Type: GID Data: FFFF Simlock [3,3] State: OPENED Type: GID Data: FFFF Simlock [3,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [4,2] State: OPENED Type: GID Data: FFFF Simlock [4,3] State: OPENED Type: GID Data: FFFF Simlock [4,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [5,2] State: OPENED Type: GID Data: FFFF Simlock [5,3] State: OPENED Type: GID Data: FFFF Simlock [5,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [6,2] State: OPENED Type: GID Data: FFFF Simlock [6,3] State: OPENED Type: GID Data: FFFF Simlock [6,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [7,2] State: OPENED Type: GID Data: FFFF Simlock [7,3] State: OPENED Type: GID Data: FFFF Simlock [7,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Unlock finished! | |
N95 vibrate then cutoff after flash [SOLVED - Thanks Crazy Ratata] | jus_chillin | Cyclonebox | 19 | 03-29-2010 11:57 |
please help for Nokia 6280 phone restricted after flashing | chronic | Nokia Base Band 5 ( BB-5 ) | 1 | 12-04-2007 18:06 |
Nokia 6280 phone restricted after flash | Unicom | Nokia Base Band 5 ( BB-5 ) | 2 | 05-19-2007 15:36 |
6270 Phone restricted after flash | ethiomobile | Nokia Base Band 5 ( BB-5 ) | 0 | 12-13-2006 17:41 |
