Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cyclonebox
Old 04-30-2013, 23:13   #1 (permalink)
pititi1974's Avatar
Member: 43253
Thanks Meter: 157
Need some help with Asha 201.2 camera problem
Hi. IŽd try to change band to this phone Asha 201.2 RM-800, but after wrote PM the camera has the message "Operation Failed", iŽd wrote the PM backup but there is some problem with the field 355
[355,0] Written, Length: 28635 bytes, Status: Not accepted, Code: 20
The phone have the version 11.81, I need some working PM for fix the camera please. I made the band change with other 201.2 and not problem, I wrote a working field 355 PM and all ok, but I donŽt know whatŽs wrong with this phone. Coud be a new version? I have an old PM?
This is the test:
Selftests to proceed: 23
Passed		ST_SIM_LOCK_TEST
Passed		ST_SECURITY_TEST
Passed		ST_PWR_KEY_TEST
Passed		ST_CURRENT_CONS_TEST
Passed		ST_SIM_CLK_LOOP_TEST
Passed		ST_LCD_TEST
Passed		ST_LPRF_AUDIO_LINES_TEST
Passed		ST_LPRF_IF_TEST
Passed		ST_KEYBOARD_STUCK_TEST
Failed		ST_CAMERA_IF_TEST
Passed		ST_BT_WAKEUP_TEST
Passed		ST_HOOKINT_TEST
Passed		ST_BTEMP_TEST
Passed		ST_RF_ANTENNA_TEST
Passed		ST_CDSP_PA_TX_POWER_TEST
Passed		ST_SLEEP_CLOCK_FREQ_TEST
Passed		ST_KEYB_LINE_TEST
Passed		ST_ADC_IF_TEST
Passed		ST_MEMORY_CARD_IF_TEST
Passed		ST_RF_PLL_TEST
Failed		ST_FEM_CURRENT_TEST
Passed		ST_SECURITY_FUSE_TEST
Passed		ST_IO_EXPANDER_IF_TEST
Selftests done, Tests total: 23, Tests passed: 21, Tests not passed: 2
The message Failed ST_CAMERA_IF_TEST is hardware or could be problem with PM?
When IŽd try to repair with cyclone I get this message
Analyzing Dynamic Camera Configuration...
[Nokia USB Phonet]: Port opened OK!
--> Primary Camera Not Exists
Secondary Camera: 0F5B6002XXXXXX
Secondary Camera Configuration is destroyed, writing factory one...
Configuration file not exists, Contact Support to obtain one!
Dynamic Camera Configuration Analyze/Repair Finished!
Some help please
Old 05-03-2013, 03:07   #2 (permalink)
pititi1974's Avatar
Member: 43253
Thanks Meter: 157
I think there was a mistake reading backup with cyclone, see log
Starting PM read in range 0-361...
[4] Reading 10 records
[4,1] Reading 800 bytes
[354] Reading 1 records
[354,0] Reading 15 bytes
[355] Reading 1 records
[355,0] Reading 28635 bytes
PM Read OK, Time taken 3.125s
Cyclone read 28635 bytes in field [355]
When I try to write that PM backup made with cyclone I have this error:
Write PM Finished, Record written OK: 302, Record written NOT OK: 1
Old 05-03-2013, 03:26   #3 (permalink)
Member: 1877063
Thanks Meter: 18
Just up your thread Sir
Old 05-03-2013, 08:53   #4 (permalink)
Member: 1134507
Sonork: 100.1607956
Thanks Meter: 201
Smile Dear pititi1974
its infenoin chip set now this time no one tool have any solution for camera just wait few time and after that check again
but mostly this problem become in hardware
try to check in hardware first
jawad munir
Old 05-03-2013, 16:11   #5 (permalink)
pititi1974's Avatar
Member: 43253
Thanks Meter: 157
Is not hadware, the camera was working until I wrote the PM, I know that is a problem with PM, but I donŽt know why I canŽt write the backup that I made with cyclone, please any aswer from cyclone Team.
Old 05-04-2013, 05:53   #6 (permalink)
Member: 1134507
Sonork: 100.1607956
Thanks Meter: 201
Smile
Dear if u sure that u read perfect FUll back up
then u dont worry and write your Rpl backup on fone
becuse i have done many fone
i have downgrade many sl,sl1,sl2 fone
and many time write backup again in sl3 fone
volcano perfect tool if u sure that u have take full back then u write in your fone
JAwad Mnir
Old 05-04-2013, 16:45   #7 (permalink)
pititi1974's Avatar
Member: 43253
Thanks Meter: 157
IŽd read full PM perfect with cyclone, see the log, but when I try to write the backup I get this:
Old 05-04-2013, 16:45   #8 (permalink)
pititi1974's Avatar
Member: 43253
Thanks Meter: 157
Page generated in 0.17923 seconds with 8 queries
