06-11-2014, 14:29 | #4 (permalink) |
Freak Poster Join Date: May 2011 Location: ettumanoor
Member: 1587303 Status: Offline Thanks Meter: 42 | Number of Image Files: 3 Processing Image File : rm872__04.52.mcusw Processing Image File : rm872__04.52.ppm_mh2 Processing Image File : rm872__04.52.image_mh2_059Q316_059R9M3_232_01 []: Found 1 active devices. [Nokia X2-02 USB Phonet]: Opening Connection [Nokia X2-02 USB Phonet]: Port opened OK! SW: V 03.59 24-12-12 RM-872 (c) Nokia IMEI: 355902053524425 START FULL PM BACKUP Please Wait... Reading : PM 0~400... OK! FULL PM Backup Saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\355902053524425\USB_FULL_BACK UP_V 03.59 24-12-12 RM-872 (c) Nokia_355902053524425__64907.pm Reading Battery Value : 4961 mV Rebooting Phone... AUTO SELECTED DEAD USB FLASHING... If Phone Booting does not Start in 5 Seconds, Then Perform Steps 1, 2, 3 and 4... 1. Remove USB and Battery... 2. Insert USB. 3. Insert Battery. (Some phones boot automatically) 4. Please Power on phone shortly... Infineon USB Boot: F00A1FB300020303010100FF Sending PBL... PBL Successfully Sent... Sending SBL... SBL Successfully Sent... Setting Transmission Speed Done... Flash Chip Manufacturer: Intel Electronics Corp. Flash Boot Successful... Unique Data: 12001817A3022808 Original Product Code: 059R9M3 Reading : CCC... OK! Reading : HWC... OK! Reading : NPC... OK! RPL Backup was Successful... Plain RPL saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\355902053524425\3559020535244 25_64915.rpl Certificate Block Saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\355902053524425\3559020535244 25_CERTIFICATE_1A36E939.bin PM Block Saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\355902053524425\3559020535244 25_PMM_PROT_E5B21BED.bin Security Code: 12345 Data Sections : 04 Current File : rm872__04.52.mcusw Compile Name: rm872__04.52.mcusw_ebl_psi.fls Image Type : Main Firmware Data Size : 26480008 Bytes Sending Certificate Block FIRMWARE Certificate Block Sent Successfully... Processing Section 01 FIRMWARE Erase Block: 0x40000000~0x4001FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 131072 bytes Data Checksum: AFC6 Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 02 FIRMWARE Erase Block: 0x40040000~0x4005FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 131072 bytes Data Checksum: 7A66 Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 03 FIRMWARE Erase Block: 0x40060000~0x4015FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 1048576 bytes Data Checksum: 94C5 Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 04 FIRMWARE Erase Block: 0x40280000~0x41A7FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 25165824 bytes Data Checksum: 0C9F Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 05 FIRMWARE Erase Block: 0x43E20000~0x43E5FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Data Verification Successful... Data Sections : 01 Current File : rm872__04.52.ppm_mh2 Compile Name: package_mh2.ppm_ebl_psi.fls Image Type : PPM Image Data Size : 5354056 Bytes Sending Certificate Block PPM Certificate Block Sent Successfully... Processing Section 01 PPM Erase Block: 0x41A80000~0x420FFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 5350712 bytes Data Checksum: 6B95 Uploading Data Blocks to phone... Block Write Successful... PPM Data Blocks uploaded to phone... Data Verification Successful... Data Sections : 01 Current File : rm872__04.52.image_mh2_059Q316_059R9M3_232_01 Compile Name: rm872__04.52.image_mh2_059Q316_059R9M3_232_01.fls Image Type : CONTENT Package Data Size : 18877712 Bytes Sending Certificate Block CONTENT Certificate Block Sent Successfully... Processing Section 01 CONTENT Erase Block: 0x42100000~0x43E1FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 18874368 bytes Data Checksum: 7E3F Uploading Data Blocks to phone... Block Write Successful... CONTENT Data Blocks uploaded to phone... Processing Section 02 CONTENT Erase Block: 0x43E60000~0x43F3FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Data Verification Successful... Total Flashing Time (Erase + Flashing) : 00:07:59 (Booting time is NOT Included) Waiting for Phone to Start-Up..(Max 150 seconds) Scanning USB Ports... ================================================ Basic Phone Information ================================================ MCU Version: V 04.52 30-06-13 RM-872 (c) Nokia IMEI Plain : 355902053524425 IMEI Spare : A355902053524420 IMEI SV : 33559020535244211F IMEI (2nd) : 355902053524433 IMEI Spare : A355902053524430 IMEI SV : 33559020535244311F Phone Model: K 206 Category : Entry Phone Type : RM-872 ================================================ Extended Phone Information ================================================ Product Serial Number: 8B254B8BI Product Code : 059R9M3 Module Code : 0205283 Basic Production Code: 059P6H2 Long Production SN : 0 PPM SW Version : V 04.52 30-06-13 RM-872 (c) Nokia MH2 BT MCM Version : 19b5-22012 MCU SW Version : V 04.52 30-06-13 RM-872 (c) Nokia HW Version : 2300 RFIC Version : 68 LCD Version : TPO Content Pack Version : Content: mh2_059Q316 V 04.52 30-06-13 RM-872 (c) Nokia Bluetooth ID : A8:44:81:8A:4D:55 CS Type : GSM900, GSM1800 ********** SIMLOCK INFO ********** CONFIG_DATA : 0010100000000000 PROFILE_BITS : 800000000004000B ASIC : 11 PROVIDER : Default Test Operator LOCK COUNTERS: KEYPRESS 0/3, FBUS 0/10 Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SIMLOCK_TYPE : PA_SIMLOC30 (20-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SECURITY_CODE : 12345 PHONE_MODE : TEST ================================================ Dynamic Camera Configuration ================================================ DCC ID : 01029704 DCC Ver: 008013 Status : OK ================================================== ==== Selected VPL File: RM872_059R9M3_04.52_020.vpl ================================================== ==== Variant Details : RM-872 VAR INDIA-MH2 IN CV BLACK Software Version : 04.52 Product Type : RM-872 Product Code : 059R9M3 Variant Version : 020 FACTORY SET TO : Full Factory Set OK FACTORY SET TO : User Data OK FACTORY SET TO : Leave Factory OK FACTORY SET TO : Service Center OK FACTORY SET TO : Software Upgrade OK FACTORY SET TO : Production Tune OK RESET LIFE TIMER TO : 0000:00 OK |
06-13-2014, 15:35 | #5 (permalink) |
No Life Poster Join Date: Aug 2013 Location: CHENNAI, TAMILNADU,INDIA
Member: 2001848 Status: Offline Sonork: 100.1658212 Thanks Meter: 581 | cyclone supports nokia 206......... i have flashed 3 sets successfully with cyclone..... buy usb fbus cable for nokia 206, then download latest flash file from google eg:mcu,ppm,image and flash...... its easy with cyclone...... |
