02-10-2015, 15:42 | #1 (permalink) |
No Life Poster Join Date: Mar 2011 Location: PAKISTAN
Member: 1537135 Status: Offline Thanks Meter: 1,021 | nokia 302 after flash dead Failed to read info -> Failed to read SP info plz help me Product Manager Establishing Connection with Box in Main Mode... Handling device: [Cyclone Team], [Cyclone Bootloader], [Platform: Classic] Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic] Initializing box... Box Firmware: Cyclone Main Application v02.20, (Aug 6 2013 20:31:40, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012 Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs Box Serial Number: C0007939 HW Revision: C, Suitable for: Production, Case: 2011 - New Casing, MCU Manufacture Time: 2011, wk01 Initializing security card... Card Serial Number: D00B0341 Card Firmware Revision: 010A Card is activated Box is activated Started box selftests procedure USB Voltage 5.12v PASSED MCU Voltage 3.28v PASSED Core Voltage 1.76v PASSED VBAT Voltage 0.01v PASSED VBAT Voltage 5.06v PASSED Box VPP disabled VPP Voltage 0.04v PASSED Internal Box VPP Enabled VPP Voltage 5.01v PASSED Box VPP disabled VPP Voltage 0.04v PASSED External Box VPP Enabled VPP Voltage 0.02v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE XGold/Blackberry Service Running, Counter: 100 Lumia No TP is ACTIVATED! Avaiable Physical Memory: 309.456MB Avaiable Virtual Memory: 1.875GB Avaiable Pagefile: 557.1000MB Initializing FBUS... All initialized - Ready to work Processing pre flash tasks... Pre flash tasks finished, continuing... Processing rm813__14.26.mcusw (CMT)... Booting CMT... [Nokia USB Flashing Generic]: Port opened OK! [Nokia USB Flashing Generic]: Port opened OK! Old ROM Detected CMT_SYSTEM_ASIC_ID: 000000030000022600010007400C192103032108 CMT_EM_ASIC_ID: 00001051 CMT_EM_ASIC_ID: 00001060 CMT_PUBLIC_ID: 4C160000FFFB7C402D9D8D3EB3B0B6DF911FC290 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 3AB5DB70B45D23F1ADEEBB5734160706 CMT_BOOT_ROM_CRC: 2CAC45E2 CMT_SECURE_ROM_CRC: 3BC33C8B CMT Ready! rm813__14.26.mcusw, Type: Flash Image, Algo: BB5, XSR 1.6 Searching for BootCode: DualLine 32Bit RAPUv21_2nd.fg, Type: 2nd Boot Loader, Rev: 768.12.14.0, Algo: BB5 Using NEW BB5 FLASHING PROTOCOL Waiting for USB Boot ROM Answer... ROM Ret: 0xFFFD125D ROM CMT dwAddr: 0x10004FF0 ROM CMT dwLength: 0x00627837 Seems ROM Initialized OK! Transmission Mode Requested: Control USB, Accepted: Control USB FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0020004000000131, ST, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x0020004000000131, ST, ONENAND Requested Algorithm: XSR 1.6 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00200040 (ST), Size: 256MBytes, VPP: Not Supported FlashChip 0x00200040 (ST), Size: 256MBytes, VPP: Not Supported RAPUv21_XSR17_alg.fg, Type: Algorithm, Rev: 768.12.14.0, Algo: XSR 1.6 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Transmission Mode Requested: Bulk USB, Accepted: Bulk USB Box TX2 Data Pin set to: Service Pin 3 Waiting for FUR Client become avaiable... [Nokia USB Flashing Generic]: Port opened OK! FUR Avaiable! Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Overriding VPP Setting, USB can't use VPP Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 05BDE0ECC36CDEAA016A0565CB6BAE0B1585232E Sending Certificates... Certificates OK Partitioning... Partitioning OK Started group flash erase EraseArea[0,CMT]: 0x00040000-0x000403FF, ONENAND EraseArea[0,CMT]: 0x000C0000-0x0013FFFF, ONENAND EraseArea[0,CMT]: 0x00140000-0x004BFFFF, ONENAND EraseArea[0,CMT]: 0x004C0000-0x0073FFFF, ONENAND EraseArea[0,CMT]: 0x00740000-0x0147FFFF, ONENAND EraseArea[0,CMT]: 0x00160000-0x0017FFFF, ONENAND EraseArea[0,CMT]: 0x03200000-0x0387FFFF, ONENAND EraseArea[0,CMT]: 0x0F080000-0x0F67FFFF, ONENAND EraseArea[0,CMT]: 0x01480000-0x0243FFFF, ONENAND EraseArea[0,CMT]: 0x02440000-0x025BFFFF, ONENAND Erase Partition (CMT) Erase Partition (CMT) Erase Partition (CMT) Waiting 320s for erasure finish... Erase taken 0.610s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT KEYS Certificate... Writing CMT PAPUBKEYS Certificate... Writing CMT DSP0 Certificate... Writing CMT MCUSW Certificate... Writing CMT MCUSW1 Certificate... Writing CMT GENIO_INIT Certificate... Writing CMT ISA+DYNSW Certificate... Writing CMT ADA Certificate... Writing CMT PRIMAPP Certificate... Writing CMT PASUBTOC Certificate... Writing CMT RAP3NAND Certificate... Writing CMT UPDAPP Certificate... Writing CMT ISA+EXTDRV Certificate... Programming Status OK! All blocks written OK! Time taken 4.875s Flashing Speed: 54803.21 kBit/S Processing rm813__14.26.mcusw (APE)... Processing rm813__14.26.ppm_ma3 (CMT)... rm813__14.26.ppm_ma3, Type: Flash Image, Algo: BB5, XSR 1.6 PAPUBKEYS Hash for CMT: 05BDE0ECC36CDEAA016A0565CB6BAE0B1585232E Partitioning... Partitioning OK Started group flash erase EraseArea[0,CMT]: 0x025C0000-0x031FFFFF, ONENAND Waiting 320s for erasure finish... Erase taken 0.78s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Programming Status OK! All blocks written OK! Time taken 0.672s Flashing Speed: 68597.58 kBit/S Processing rm813__14.26.ppm_ma3 (APE)... Processing rm813__14.26.image_ma3_059K7R0_059N7S7_529_01 (CMT)... rm813__14.26.image_ma3_059K7R0_059N7S7_529_01, Type: Flash Image, Algo: BB5, XSR 1.6 PAPUBKEYS Hash for CMT: 05BDE0ECC36CDEAA016A0565CB6BAE0B1585232E Partitioning... Partitioning OK Started group flash erase EraseArea[0,CMT]: 0x03880000-0x0F07FFFF, ONENAND Erase Partition (CMT) Waiting 320s for erasure finish... Erase taken 2.234s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Programming Status OK! All blocks written OK! Time taken 3.890s Flashing Speed: 59934.35 kBit/S Processing rm813__14.26.image_ma3_059K7R0_059N7S7_529_01 (APE)... Restarting MCU... All images processed OK! Processing post flash tasks... Setting Factory Defaults... [Generic Phone]: Port opened OK! [Nokia Asha 302 USB Phonet]: Port opened OK! [Nokia Asha 302 USB Phonet]: Port opened OK! [Nokia Asha 302 USB Phonet]: Port opened OK! [Nokia Asha 302 USB Phonet]: Port opened OK! Factory defaults OK Reading info... [Nokia Asha 302 USB Phonet]: Port opened OK! MCU Version V 14.26 MCU Date 23-01-12 Product RM-813 (Nokia RM-813) Manufacturer (c) Nokia IMEI 356335059318592 Mastercode 6046226222 IMEI Spare 3A65330595135809 IMEI SV 3365330595135809F4000000 PPM V 14.26, 23-01-12, RM-813, (c) Nokia , MA3 CNT Content: ma3_059K7R0, V 14.26, 23-01-12, RM-813, (c) Nokia PSN 0 PSD 0000000000000000 LPSN 0 WLAN MAC ECF35B49DA9B RETU 51 TAHVO 00 AHNE 21 RFIC |Alli_4.3.4 DSP 104_MP5.2_14.26 LCD TPO BT 4217-v924 Failed to read info -> Failed to read SP info Read info thread finished, continuing... Post flash tasks finished! Flashing successfully finished! Setting factory defaults of: Factory set full [Nokia Asha 302 USB Phonet]: Port opened OK! [Nokia Asha 302 USB Phonet]: Port opened OK! Factory defaults set OK Processing pre flash tasks... Pre flash tasks finished, continuing... Processing 5901B58F_rm813__15.15.mcusw (CMT)... Booting CMT... [Nokia USB Flashing Generic]: Port opened OK! Old ROM Detected CMT_SYSTEM_ASIC_ID: 000000030000022600010007400C192103032108 CMT_EM_ASIC_ID: 00001051 CMT_EM_ASIC_ID: 00001060 CMT_PUBLIC_ID: 4C160000FFFB7C402D9D8D3EB3B0B6DF911FC290 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 3AB5DB70B45D23F1ADEEBB5734160706 CMT_BOOT_ROM_CRC: 2CAC45E2 CMT_SECURE_ROM_CRC: 3BC33C8B CMT Ready! 5901B58F_rm813__15.15.mcusw, Type: Flash Image, Algo: BB5, XSR 1.6 Searching for BootCode: DualLine 32Bit RAPUv21_2nd.fg, Type: 2nd Boot Loader, Rev: 768.12.14.0, Algo: BB5 Using NEW BB5 FLASHING PROTOCOL Waiting for USB Boot ROM Answer... ROM Ret: 0xFFFD125D ROM CMT dwAddr: 0x10004FF0 ROM CMT dwLength: 0x00627837 Seems ROM Initialized OK! Transmission Mode Requested: Control USB, Accepted: Control USB FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0020004000000131, ST, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x0020004000000131, ST, ONENAND Requested Algorithm: XSR 1.6 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00200040 (ST), Size: 256MBytes, VPP: Not Supported FlashChip 0x00200040 (ST), Size: 256MBytes, VPP: Not Supported RAPUv21_XSR17_alg.fg, Type: Algorithm, Rev: 768.12.14.0, Algo: XSR 1.6 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Transmission Mode Requested: Bulk USB, Accepted: Bulk USB Box TX2 Data Pin set to: Service Pin 3 Waiting for FUR Client become avaiable... [Nokia USB Flashing Generic]: Port opened OK! FUR Avaiable! Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Overriding VPP Setting, USB can't use VPP Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 05BDE0ECC36CDEAA016A0565CB6BAE0B1585232E Sending Certificates... Certificates OK Partitioning... Partitioning OK Started group flash erase EraseArea[0,CMT]: 0x00040000-0x000403FF, ONENAND EraseArea[0,CMT]: 0x000C0000-0x0013FFFF, ONENAND EraseArea[0,CMT]: 0x00140000-0x004BFFFF, ONENAND EraseArea[0,CMT]: 0x004C0000-0x0073FFFF, ONENAND EraseArea[0,CMT]: 0x00740000-0x0147FFFF, ONENAND EraseArea[0,CMT]: 0x00160000-0x0017FFFF, ONENAND EraseArea[0,CMT]: 0x03200000-0x0387FFFF, ONENAND EraseArea[0,CMT]: 0x0F080000-0x0F67FFFF, ONENAND EraseArea[0,CMT]: 0x01480000-0x0243FFFF, ONENAND EraseArea[0,CMT]: 0x02440000-0x025BFFFF, ONENAND Erase Partition (CMT) Erase Partition (CMT) Erase Partition (CMT) Waiting 320s for erasure finish... Erase taken 0.594s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT KEYS Certificate... Writing CMT PAPUBKEYS Certificate... Writing CMT DSP0 Certificate... Writing CMT MCUSW Certificate... Writing CMT MCUSW1 Certificate... Writing CMT GENIO_INIT Certificate... Writing CMT ISA+DYNSW Certificate... Writing CMT ADA Certificate... Writing CMT PRIMAPP Certificate... Writing CMT PASUBTOC Certificate... Writing CMT RAP3NAND Certificate... Writing CMT UPDAPP Certificate... Writing CMT ISA+EXTDRV Certificate... Programming Status OK! All blocks written OK! Time taken 4.860s Flashing Speed: 55005.22 kBit/S Processing 5901B58F_rm813__15.15.mcusw (APE)... Processing D0318CD3_rm813__15.15.ppm_c5 (CMT)... D0318CD3_rm813__15.15.ppm_c5, Type: Flash Image, Algo: BB5, XSR 1.6 PAPUBKEYS Hash for CMT: 05BDE0ECC36CDEAA016A0565CB6BAE0B1585232E Partitioning... Partitioning OK Started group flash erase EraseArea[0,CMT]: 0x025C0000-0x031FFFFF, ONENAND Waiting 320s for erasure finish... Erase taken 0.78s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Programming Status OK! All blocks written OK! Time taken 0.703s Flashing Speed: 68871.08 kBit/S Processing D0318CD3_rm813__15.15.ppm_c5 (APE)... Processing 42EDF42D_rm813__15.15.image_c5_059K7T6 (CMT)... 42EDF42D_rm813__15.15.image_c5_059K7T6, Type: Flash Image, Algo: BB5, XSR 1.6 PAPUBKEYS Hash for CMT: 05BDE0ECC36CDEAA016A0565CB6BAE0B1585232E Partitioning... Partitioning OK Started group flash erase EraseArea[0,CMT]: 0x03880000-0x0F07FFFF, ONENAND Erase Partition (CMT) Waiting 320s for erasure finish... Erase taken 1.484s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Programming Status OK! All blocks written OK! Time taken 3.594s Flashing Speed: 60299.50 kBit/S Processing 42EDF42D_rm813__15.15.image_c5_059K7T6 (APE)... Restarting MCU... All images processed OK! Processing post flash tasks... Setting Factory Defaults... [Nokia Asha 302 USB Phonet]: Port opened OK! [Nokia Asha 302 USB Phonet]: Port opened OK! [Nokia Asha 302 USB Phonet]: Port opened OK! [Nokia Asha 302 USB Phonet]: Port opened OK! [Nokia Asha 302 USB Phonet]: Port opened OK! Factory defaults OK Reading info... [Nokia Asha 302 USB Phonet]: Port opened OK! MCU Version V 15.15 MCU Date 05-06-13 Product RM-813 (Nokia RM-813) Manufacturer (c) Nokia IMEI 356335059318592 Mastercode 6046226222 IMEI Spare 3A65330595135809 IMEI SV 3365330595135819F5000000 PPM V 15.15, 05-06-13, RM-813, (c) Nokia , C5 CNT Content: c5_059K7T6, V 15.15, 05-06-13, RM-813, (c) Nokia PSN 0 PSD 0000000000000000 LPSN 0 WLAN MAC ECF35B49DA9B RETU 51 TAHVO 00 AHNE 21 RFIC |Alli_4.3.4 DSP 104_PM5_15.15 LCD TPO BT 4217-v924 Failed to read info -> Failed to read SP info Read info thread finished, continuing... Post flash tasks finished! Flashing successfully finished! |
