Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cyclonebox
Old 04-14-2010, 16:48   #1 (permalink)
Member: 1151878
Thanks Meter: 14
nokia firmware RM-356 EMEA 7 must be installed first
hi all
i don't way but i still not able to use the flash option with cyclone....
after i download the firmware i need from the support i can't install it due to this message "nokia firmware RM-356 EMEA 7 must be installed first" that i don't how to solve!!!
can some one instruct me how to do it?
Old 04-14-2010, 22:43   #2 (permalink)
Member: 266853
Thanks Meter: 31
first you need download/install a firmware 7, then you can download 7.01 then 7.02 then 7.03. first you need the major firmware.
i think i can help you with this message
Old 04-15-2010, 10:05   #3 (permalink)
Member: 1151878
Thanks Meter: 14
i will be glad to get some help/support in how to download and install firmware.
Old 04-15-2010, 10:25   #4 (permalink)
Member: 146369
Thanks Meter: 119
Major firmwares is always x.0 after installing major firmwares, then you can go on to minors, x.1 and so on...
eg
Major Data Package
RM-356 dp v 12.0 (MCU SW 40.0.005) for Europe
Published 2010/01/14 Size 162.4 MB
Minor Data Package
RM-356 dp v 12.1 (MCU SW 40.0.005) for Europe
Published 2010/02/01 Size 84.0 MB
And always use latest firmware... DP.7 isn't the latest for RM-356
If you need help, then just add me on to MSN, I will be glad to help you out using teamviewer...
Old 04-15-2010, 12:32   #5 (permalink)
Member: 1151878
Thanks Meter: 14
eg
Major Data Package
Minor Data Package
thank you very much friend, now i understand how to install the firmware but i still have a problem that after the firmware installtion completed the cyclon cann't detect it , in contrast with JAF that can do
"Processing C:\Program Files\Nokia\Phoenix\Products\...
Found 1 products, Filtering BB5 Products - wait...
0 Products left after filtering. Ready."
solution?
Old 04-15-2010, 15:31   #6 (permalink)
Member: 1151878
Thanks Meter: 14
why cyclone cann't detect the firmware?
Old 04-15-2010, 16:16   #7 (permalink)
moulnisky's Avatar
Member: 947561
Thanks Meter: 14,053
cos load of chances some files are missing...
try downloading all the files needed related to your product code using navfirm or check if the path where is installed the firmware is the folder you selected in the path configuration
Alex
Old 04-16-2010, 10:09   #8 (permalink)
Member: 1151878
Thanks Meter: 14
Alex
if i download the files needed do i need to install firmware or just to upload the file to cyclone? and what better method?
the firmware of RH-19 installed in the folder
C:\Program Files\Nokia\Phoenix\products
and the RM-356 in folder C:\Program Files\Common Files\Nokia\DataPackage\Products
and cyclone trying to get the files from the C:\Program Files\Nokia\Phoenix\products and also cann't detect the RH-19 .....
why it's happing and there is any way to solve it?
Old 04-16-2010, 10:44   #9 (permalink)
moulnisky's Avatar
Member: 947561
add C:\Program Files\Common Files\Nokia\DataPackage\Products\ in the cyclone path list and will be ok
Alex
Old 04-16-2010, 11:13   #10 (permalink)
Member: 1151878
Thanks Meter: 14
Alex
first i got the message while select the variant "Failed to Extract BB5 Variant -> Product Directory not found at all!"
and why RM-356 detected as DCT4?!!!
"Found 2 products, Filtering DCT4 Products - wait...
1 Products left after filtering. Ready.
Retrieving Variants for Product RM-356 - wait...
Failed to retrieve DCT4 Variants -> Product not found at all! Some critical, unexpected error occured!
the RH-19 installed and not detected as DCT4/WD2 !!!!!!!way?
Old 04-16-2010, 12:21   #11 (permalink)
moulnisky's Avatar
Member: 947561
Go in the cyclonebox main folder and edit the file settings.ini
modify the line
in
Save the file and restart the aplication
Alex
Old 04-18-2010, 09:47   #12 (permalink)
Member: 1151878
Thanks Meter: 14
modify the line
in
Alex
here how it appears in the settings.ini file
FlashPath1=C:\Program Files\Nokia\Phoenix\Products\
FlashPath2=C:\Program Files\Common Files\Nokia\DataPackage\Products
Old 04-18-2010, 10:15   #13 (permalink)
Member: 146369
Thanks Meter: 119
Just edit FlashPath2 to
FlashPath2=C:\Program Files\Common Files\Nokia\DataPackage\Products\
As simple as that
Old 03-27-2013, 23:24   #14 (permalink)
shmuel522's Avatar
Member: 1798073
Thanks Meter: 7
hi sir
i dont have the path of C:\Program Files\Common Files\Nokia\DataPackage\Products\
i dont have the data Package path why is that ?
i have only the fuse directory in nokia dir
do i need to create it? the folder ?
Old 03-30-2013, 19:43   #15 (permalink)
shmuel522's Avatar
Member: 1798073
Thanks Meter: 7
I do have now after i have insatll phoenix but still can not see the variants
help pls
Page generated in 0.27656 seconds with 10 queries
