09-23-2009, 15:56 | #1 (permalink) |
Junior Member Join Date: Sep 2009
Member: 1120123 Status: Offline Thanks Meter: 0 | Nokia N95 RM-159 Phone Startup Failed. [SOLVED] I need some help with this N95. I have backups (pm, rpl, cert) from when the phone was working but i cant make the phone pass the st_security_test. The tests give me this: Code: Selftests to proceed: 43 Passed ST_UEM_CBUS_IF_TEST Passed ST_EAR_DATA_LOOP_TEST Passed ST_SIM_CLK_LOOP_TEST Passed ST_SIM_IO_CTRL_LOOP_TEST Passed ST_SIM_LOCK_TEST Failed ST_SECURITY_TEST Passed ST_PWR_KEY_TEST Passed ST_CURRENT_CONS_TEST Passed ST_BACKUP_BATT_TEST Failed ST_CMT_APE_WAKEUP_TEST Passed ST_SLEEPCLK_FREQ_TEST Passed ST_RADIO_TEST Passed ST_HOOKINT_TEST Passed ST_BTEMP_TEST Passed ST_MBUS_RX_TX_LOOP_TEST Passed ST_EXT_DEVICE_TEST Passed ST_CDSP_RF_BB_IF_TEST Passed ST_CDSP_RF_SUPPLY_TEST Passed ST_CDSP_TX_IQ_TEST Passed ST_CDSP_TXC_DATA_TEST Passed ST_CDSP_PWR_DETECTOR_BIAS_TEST Passed ST_CDSP_RX_PLL_PHASE_LOCK_TEST Failed ST_CDSP_TX_PLL_PHASE_LOCK_TEST Passed ST_CDSP_WCDMA_TX_POWER_TEST Passed ST_CDSP_RX_IQ_LOOP_BACK_TEST Passed ST_CDSP_GSM_TX_POWER_TEST Passed ST_IR_LOOP_TEST Passed ST_KEYBOARD_STUCK_TEST Failed ST_LPRF_IF_TEST Passed ST_CAMERA_IF_TEST Passed ST_CAMERA_ACCELERATOR_TEST Passed ST_SEC_CAMERA_IF_TEST Passed ST_CAMERA_AUTOFOCUS_TEST Passed ST_LPRF_AUDIO_LINES_TEST Passed ST_MAIN_LCD_IF_TEST Passed ST_BT_WAKEUP_TEST Passed ST_WLAN_TEST Passed ST_BT_WLAN_COEXISTENCE_TEST Passed ST_ACCEL_IF_TEST Passed ST_BT_SLEEP_CLK_TEST Passed ST_APE_EM_ASIC_TEST Passed ST_TEMP_SENSOR_IF_TEST Passed ST_VIBRA_TEST Selftests done, Tests total: 43, Tests passed: 39, Tests not passed: 4 Step by step would be great! I dont know all the technical stuff.. yet. I did not try to unlock the phone. Never been locked. Thanks! |
09-23-2009, 16:38 | #2 (permalink) |
No Life Poster Join Date: Jan 2009 Location: England Age: 59
Member: 947561 Status: Offline Thanks Meter: 14,053 | download this PM http://rapidshare.com/files/256765887/N95_RM-159.pm go in the tab bb5/security and click on SX4 auth once you got the autorize go in the tab bb5/common, SX4bypass NOT THICKED click on write PM and select N95_RM-159.pm BR Alex |
The Following User Says Thank You to moulnisky For This Useful Post: |
09-23-2009, 17:25 | #3 (permalink) | |
Member: 1120123 Status: Offline Thanks Meter: 0 | Quote:
09-23-2009, 17:43 | #4 (permalink) |
Member: 1120123 Status: Offline Thanks Meter: 0 | Passed ST_UEM_CBUS_IF_TEST Passed ST_EAR_DATA_LOOP_TEST Passed ST_SIM_CLK_LOOP_TEST Passed ST_SIM_IO_CTRL_LOOP_TEST Passed ST_SIM_LOCK_TEST Passed ST_SECURITY_TEST Passed ST_PWR_KEY_TEST Passed ST_CURRENT_CONS_TEST Passed ST_BACKUP_BATT_TEST Failed ST_CMT_APE_WAKEUP_TEST Passed ST_SLEEPCLK_FREQ_TEST Passed ST_RADIO_TEST Passed ST_HOOKINT_TEST Passed ST_BTEMP_TEST Passed ST_MBUS_RX_TX_LOOP_TEST Passed ST_EXT_DEVICE_TEST Passed ST_CDSP_RF_BB_IF_TEST Passed ST_CDSP_RF_SUPPLY_TEST Passed ST_CDSP_TX_IQ_TEST Passed ST_CDSP_TXC_DATA_TEST Passed ST_CDSP_PWR_DETECTOR_BIAS_TEST Passed ST_CDSP_RX_PLL_PHASE_LOCK_TEST Failed ST_CDSP_TX_PLL_PHASE_LOCK_TEST Passed ST_CDSP_WCDMA_TX_POWER_TEST Passed ST_CDSP_RX_IQ_LOOP_BACK_TEST Passed ST_CDSP_GSM_TX_POWER_TEST Passed ST_IR_LOOP_TEST Passed ST_KEYBOARD_STUCK_TEST Failed ST_LPRF_IF_TEST Passed ST_CAMERA_IF_TEST Passed ST_CAMERA_ACCELERATOR_TEST Passed ST_SEC_CAMERA_IF_TEST Passed ST_CAMERA_AUTOFOCUS_TEST Passed ST_LPRF_AUDIO_LINES_TEST Passed ST_MAIN_LCD_IF_TEST Passed ST_BT_WAKEUP_TEST Passed ST_WLAN_TEST Passed ST_BT_WLAN_COEXISTENCE_TEST Passed ST_ACCEL_IF_TEST Passed ST_BT_SLEEP_CLK_TEST Passed ST_APE_EM_ASIC_TEST Passed ST_TEMP_SENSOR_IF_TEST Passed ST_VIBRA_TEST Selftests done, Tests total: 43, Tests passed: 40, Tests not passed: 3 Can i do something about this? I know that the antenna for .. bluetooth (i think) is damaged. |
09-23-2009, 17:53 | #5 (permalink) |
Member: 947561 Status: Offline Thanks Meter: 14,053 | You just wrote the calibration data again in the mobile and, using the sx4 authorization, you updated the checksum in the mobile and the security error (the reason of the CS) has gone... about the other problems you can try to reheat the ape. BR Alex |
The Following 2 Users Say Thank You to moulnisky For This Useful Post: |
Support - It fails in the Downgrade Nokia N95 RM-159 | 007spyphone | Universalbox | 4 | 01-13-2010 11:55 |
Nokia n95 rm-159 + n958gb rm-320 full | fun_tool | Nokia Base Band 5 ( BB-5 ) | 0 | 05-10-2009 05:31 |
n95 rm-159 phone dead. | pok_oho | Nokia Base Band 5 ( BB-5 ) | 0 | 06-25-2008 14:45 |
