Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cyclonebox
Old 05-10-2013, 18:20   #1 (permalink)
Member: 1487523
Please help can't flash nokia c3 USB
Processing pre flash tasks...
Pre flash tasks finished, continuing...
Processing rm614__08.70.mcusw (CMT)...
Booting CMT...
[Nokia USB Flashing Generic]: Port opened OK!
New ROM Detected
CMT_SYSTEM_ASIC_ID: 000000000000000022000509200C0000
CMT_EM_ASIC_ID: 00005361
CMT_PUBLIC_ID: 0000000000D5E45FA5A98138BA40A8DE8F637019
CMT_ASIC_MODE_ID: 00
CMT_ROOT_KEY_HASH: 1B0D74C532CA1C6133940C740E8C786E
CMT_BOOT_ROM_CRC: DE56D582
CMT_SECURE_ROM_CRC: BDDE7A3A
CMT Ready!
rm614__08.70.mcusw, Type: Flash Image, Algo: BB5, XSR 1.6
Searching for BootCode: DualLine 32Bit
BCM21351_usb2nd.fg, Type: 2nd Boot Loader, Rev: 513.12.8.0, Algo: BB5
Using NEW BB5 FLASHING PROTOCOL
Transmission Mode Requested: Control USB, Accepted: Control USB
FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM
FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC
FlashChip[0,CMT]: 0x0000000000000000, Unknown, NOR
FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR
FlashChip[0,CMT]: 0x00EC003000000431, Samsung, ONENAND
Requested Algorithm: XSR 1.6 (CMT)
FlashChip 0x00EC0030 (Samsung), Size: 128MBytes, VPP: Not Supported
BCM21351_XSR16_usbalg.fg, Type: Algorithm, Rev: 513.12.8.0, Algo: XSR 1.6
Initializing TurboCache...
TurboCache Loaded!
Writing CMT PASUBTOC Certificate...
Writing CMT ALG Certificate...
CMT Algorithm Ready!
Transmission Mode Requested: Bulk USB, Accepted: Bulk USB
Box TX2 Data Pin set to: Service Pin 3
Waiting for FUR Client become avaiable...
Sfter thta nothing happen the process get stuck
and the computer tell me that
thta the usb device can not be recognize
and then
BB5 USB Boot Rom not Detected -> Timeout, no any compatible USB device detected.
Processing Flash Image Failed -> FUR Not Avaiable
Failed to Process all Image files -> Failed to process rm614__08.70.mcusw
i don't know if i need the fbus cable i don't know if is the only solution please some help thanks.
Old 05-10-2013, 18:50   #2 (permalink)
Member: 1487523
I was reading maybe could be a windows problem is it true?
Or may only option is use a fbfbus cable
Old 05-10-2013, 22:21   #3 (permalink)
Member: 1487523
i try with diferent computer but now i'm geting this
Booting CMT...
New ROM Detected
CMT Ready!
FlashChip[0,CMT]: 0xFFFFFFFF00000000, Unknown, NOR
TurboCache Loaded!
FUR Avaiable!
Adding FUR Client (CMT, State: Ready)...
CMT FUR Ready!
Overriding VPP Setting, USB can't use VPP
Box VPP disabled
Internal CMT Phone VPP Enabled
Warning: PAPUBKEYS Hash Missing!
Sending Certificates...
Certificates OK
Partitioning...
Partitioning OK
Started group flash erase
EraseArea[0,CMT]: 0x00000000-0x0001FFFF, ONENAND
EraseArea[0,CMT]: 0x00020000-0x000203FF, ONENAND
EraseArea[0,CMT]: 0x00060000-0x012FFFFF, ONENAND
EraseArea[0,CMT]: 0x01300000-0x01DFFFFF, ONENAND
EraseArea[0,CMT]: 0x02600000-0x029FFFFF, ONENAND
Erase Partition (CMT)
Waiting 320s for erasure finish...
Erase taken 0.483s
Writing all blocks...
TurboCache Loaded!
Block Write Failed -> Failed to write CMT FUR data header and payload at 0x605
Processing Flash Image Failed -> Failed to write all blocks
Old 05-10-2013, 22:54   #4 (permalink)
ptt
ptt's Avatar
Member: 348680
Thanks Meter: 1,273
Check at Your Side.... Cable, Drivers, OS, USB Ports, Phone HW Problem...........
C3-00 RM-614, USB Flashing process is working OK, as you can see in these success Logs:
http://forum.gsmhosting.com/vbb/f528...ml#post8444952
http://forum.gsmhosting.com/vbb/f528...ml#post8363706
http://forum.gsmhosting.com/vbb/f528...ml#post7990950
Page generated in 0.13567 seconds with 8 queries
