![]() | #1 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Aug 2010
Member: 1361078 Status: Offline Thanks Meter: 49 | plz help me gsm masters [Solved] i flashe the phone but after flash dead totay dead i try with new downgrade tick but still same plz help me urgent |
![]() | #2 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2009 Location: England Age: 60
Member: 947561 Status: Offline Thanks Meter: 14,068 | if you did the back-ups before the flash just follow the instructions in this thread after full erasing it http://forum.gsmhosting.com/vbb/8454190-post3.html BR Alex |
The Following User Says Thank You to moulnisky For This Useful Post: |
![]() | #5 (permalink) |
Member: 1361078 Status: Offline Thanks Meter: 49 | here is flahing log Retrieving Variants for Product RM-133 - wait... 131 Variants Retrieved Booting CMT... APE_SYSTEM_ASIC_ID: 17100708 APE_ASIC_MODE_ID: 00 APE_PUBLIC_ID: BDD8F5263F12DBB82FD0726142F2670A78441FDB APE_ROOT_KEY_HASH: 49A97E826B93BA20B7ED0B082475C00500000000 APE_BOOT_ROM_CRC: 1DFD6613 APE_SECURE_ROM_CRC: 2C872FD4 CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 169001137AC40154140968EDA616B2E9E0214603 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! Searching for BootCode: DualLine 32Bit RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.42.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x00EC22E800006921, Samsung, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit FlashChip 0x00EC22E8 (Samsung), Size: 16MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 5E8D0D504A0902E261268C14FCD8A2C9093523BC APE Boot skipped on user request Flashbus Write baud set to 5.0Mbits Restarting MCU... Processing pre flash tasks... Backing up RPL... RPL Creation started... Processing CMT Part... Warning: Phone not detected, using Rap Public ID in FileName and reading Certificates Only Booting CMT... APE_SYSTEM_ASIC_ID: 17100708 APE_ASIC_MODE_ID: 00 APE_PUBLIC_ID: BDD8F5263F12DBB82FD0726142F2670A78441FDB APE_ROOT_KEY_HASH: 49A97E826B93BA20B7ED0B082475C00500000000 APE_BOOT_ROM_CRC: 1DFD6613 APE_SECURE_ROM_CRC: 2C872FD4 CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 169001137AC40154140968EDA616B2E9E0214603 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! Searching for BootCode: DualLine 32Bit RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.42.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x00EC22E800006921, Samsung, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit FlashChip 0x00EC22E8 (Samsung), Size: 16MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 5E8D0D504A0902E261268C14FCD8A2C9093523BC Searching for BootCode: DualLine 32Bit helen3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.35.0, Algo: BB5 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. Failed to send APE Secondary Loader -> Failed to get APE Configuration Data Prepare phone failed with message -> APE Secondary Boot Failed Failed to Create RPL from phone -> Failed to Boot / Prepare Phone RPL backup thread finished, continuing... Pre flash tasks finished, continuing... Processing N73_4.0839.42.0.1_western_C00_PRD_cc.fpsx (CMT)... Booting CMT... APE_SYSTEM_ASIC_ID: 17100708 APE_ASIC_MODE_ID: 00 APE_PUBLIC_ID: BDD8F5263F12DBB82FD0726142F2670A78441FDB APE_ROOT_KEY_HASH: 49A97E826B93BA20B7ED0B082475C00500000000 APE_BOOT_ROM_CRC: 1DFD6613 APE_SECURE_ROM_CRC: 2C872FD4 CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 169001137AC40154140968EDA616B2E9E0214603 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! N73_4.0839.42.0.1_western_C00_PRD_cc.fpsx, Type: Flash Image, Algo: BB5, BB5 ALGORITHM, BB5, OMAP1710 UNISTORE-II-1.2.1 ALG Searching for BootCode: DualLine 32Bit RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.42.0, Algo: BB5 Flashbus Write baud set to 51Kbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x00EC22E800006921, Samsung, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit FlashChip 0x00EC22E8 (Samsung), Size: 16MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 5E8D0D504A0902E261268C14FCD8A2C9093523BC Flashbus Write baud set to 5.0Mbits Partitioning... Partitioning OK Started group flash erase EraseArea[0,CMT]: 0x00080000-0x0073194D, NOR EraseArea[0,CMT]: 0x00000000-0x0005FFFF, NOR EraseArea[0,CMT]: 0x001E0000-0x001FFFFF, NOR EraseArea[0,CMT]: 0x00880000-0x00FEFFFF, NOR Waiting 320s for erasure finish... Erase taken 43.484s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT NOLO Certificate... Block Write Failed -> Failed to write CMT cert data (3), Programming Status Error Processing Flash Image Failed -> Failed to write all blocks Failed to Process all Image files -> Failed to process N73_4.0839.42.0.1_western_C00_PRD_cc.fpsx Booting CMT... APE_SYSTEM_ASIC_ID: 17100708 APE_ASIC_MODE_ID: 00 APE_PUBLIC_ID: BDD8F5263F12DBB82FD0726142F2670A78441FDB APE_ROOT_KEY_HASH: 49A97E826B93BA20B7ED0B082475C00500000000 APE_BOOT_ROM_CRC: 1DFD6613 APE_SECURE_ROM_CRC: 2C872FD4 CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 169001137AC40154140968EDA616B2E9E0214603 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! Searching for BootCode: DualLine 32Bit RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.42.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x00EC22E800006921, Samsung, NOR FlashContent[0,CMT]: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit FlashChip 0x00EC22E8 (Samsung), Size: 16MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled Warning: PAPUBKEYS Hash Missing! APE Boot skipped on user request Flashbus Write baud set to 5.0Mbits Restarting MCU... Booting CMT... APE_SYSTEM_ASIC_ID: 17100708 APE_ASIC_MODE_ID: 00 APE_PUBLIC_ID: BDD8F5263F12DBB82FD0726142F2670A78441FDB APE_ROOT_KEY_HASH: 49A97E826B93BA20B7ED0B082475C00500000000 APE_BOOT_ROM_CRC: 1DFD6613 APE_SECURE_ROM_CRC: 2C872FD4 CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 169001137AC40154140968EDA616B2E9E0214603 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! Searching for BootCode: DualLine 32Bit RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.42.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x00EC22E800006921, Samsung, NOR FlashContent[0,CMT]: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit FlashChip 0x00EC22E8 (Samsung), Size: 16MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled Warning: PAPUBKEYS Hash Missing! APE Boot skipped on user request Flashbus Write baud set to 5.0Mbits Restarting MCU... Booting CMT... APE_SYSTEM_ASIC_ID: 17100708 APE_ASIC_MODE_ID: 00 APE_PUBLIC_ID: BDD8F5263F12DBB82FD0726142F2670A78441FDB APE_ROOT_KEY_HASH: 49A97E826B93BA20B7ED0B082475C00500000000 APE_BOOT_ROM_CRC: 1DFD6613 APE_SECURE_ROM_CRC: 2C872FD4 CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 169001137AC40154140968EDA616B2E9E0214603 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! Searching for BootCode: DualLine 32Bit RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.42.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x00EC22E800006921, Samsung, NOR FlashContent[0,CMT]: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit FlashChip 0x00EC22E8 (Samsung), Size: 16MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled Warning: PAPUBKEYS Hash Missing! Searching for BootCode: DualLine 32Bit helen3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.35.0, Algo: BB5 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,APE]: 0x00EC00A100800015, Samsung, NAND FlashContent[0,APE]: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF, NAND Searching for BootCode: DualLine 32Bit FlashChip 0x00EC00A1 (Samsung), Size: 128MBytes, VPP: 21V h3_sam_nand_xsr.fg, Type: Algorithm, Rev: 0.1.49.0, Algo: OMAP1710 UNISTORE-II-1.2.1 ALG Box VPP disabled Internal APE Phone VPP Enabled PAPUBKEYS Hash for APE: 5E8D0D504A0902E261268C14FCD8A2C9093523BC Flashbus Write baud set to 5.0Mbits Erasing flash chip... Started group flash erase EraseArea[0,CMT]: 0x00000000-0x00FFFFFF, NOR Waiting 640s for erasure finish... Erase taken 5.0s Restarting MCU... BB5 Full Erase Finished! Processing pre flash tasks... Backing up RPL... RPL Creation started... Processing CMT Part... Warning: Phone not detected, using Rap Public ID in FileName and reading Certificates Only Booting CMT... APE_SYSTEM_ASIC_ID: 17100708 APE_ASIC_MODE_ID: 00 APE_PUBLIC_ID: BDD8F5263F12DBB82FD0726142F2670A78441FDB APE_ROOT_KEY_HASH: 49A97E826B93BA20B7ED0B082475C00500000000 APE_BOOT_ROM_CRC: 1DFD6613 APE_SECURE_ROM_CRC: 2C872FD4 CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 169001137AC40154140968EDA616B2E9E0214603 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! Searching for BootCode: DualLine 32Bit RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.42.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x00EC22E800006921, Samsung, NOR FlashContent[0,CMT]: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit FlashChip 0x00EC22E8 (Samsung), Size: 16MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled Warning: PAPUBKEYS Hash Missing! Searching for BootCode: DualLine 32Bit helen3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.35.0, Algo: BB5 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,APE]: 0x00EC00A100800015, Samsung, NAND FlashContent[0,APE]: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF, NAND Searching for BootCode: DualLine 32Bit FlashChip 0x00EC00A1 (Samsung), Size: 128MBytes, VPP: 21V h3_sam_nand_xsr.fg, Type: Algorithm, Rev: 0.1.49.0, Algo: OMAP1710 UNISTORE-II-1.2.1 ALG Box VPP disabled Internal APE Phone VPP Enabled PAPUBKEYS Hash for APE: 5E8D0D504A0902E261268C14FCD8A2C9093523BC Flashbus Write baud set to 5.0Mbits CMT NPC Not Found CMT CCC Not Found CMT HWC Not Found CMT VARIANT Not Found CMT PARTNERC Not Found Processing APE Part... Storing Product Code... Storing PSN... Storing HWID... APE NPC Not Found APE CCC Not Found APE HWC Not Found APE VARIANT Not Found APE PARTNERC Not Found Restarting MCU... RPL Saved OK RPL backup thread finished, continuing... Pre flash tasks finished, continuing... Processing N73_4.0839.42.0.1_western_C00_PRD_cc.fpsx (CMT)... Booting CMT... APE_SYSTEM_ASIC_ID: 17100708 APE_ASIC_MODE_ID: 00 APE_PUBLIC_ID: BDD8F5263F12DBB82FD0726142F2670A78441FDB APE_ROOT_KEY_HASH: 49A97E826B93BA20B7ED0B082475C00500000000 APE_BOOT_ROM_CRC: 1DFD6613 APE_SECURE_ROM_CRC: 2C872FD4 CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 169001137AC40154140968EDA616B2E9E0214603 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! N73_4.0839.42.0.1_western_C00_PRD_cc.fpsx, Type: Flash Image, Algo: BB5, BB5 ALGORITHM, BB5, OMAP1710 UNISTORE-II-1.2.1 ALG Searching for BootCode: DualLine 32Bit RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.42.0, Algo: BB5 Flashbus Write baud set to 51Kbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x00EC22E800006921, Samsung, NOR FlashContent[0,CMT]: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit FlashChip 0x00EC22E8 (Samsung), Size: 16MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled Warning: PAPUBKEYS Hash Missing! Flashbus Write baud set to 5.0Mbits Partitioning... Partitioning OK Started group flash erase EraseArea[0,CMT]: 0x00080000-0x0073194D, NOR EraseArea[0,CMT]: 0x00000000-0x0005FFFF, NOR EraseArea[0,CMT]: 0x001E0000-0x001FFFFF, NOR EraseArea[0,CMT]: 0x00880000-0x00FEFFFF, NOR Waiting 320s for erasure finish... Erase taken 3.422s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT NOLO Certificate... Writing CMT KEYS Certificate... Writing CMT PRIMAPP Certificate... Writing CMT PASUBTOC Certificate... WARNING: CMT PAPUBKEYS Hash is Empty, writing first found PAPUBKEYS Writing CMT PAPUBKEYS Certificate... Writing CMT UPDAPP Certificate... Writing CMT ADL Certificate... Writing CMT DSP0 Certificate... Writing CMT MCUSW Certificate... Programming Status OK! All blocks written OK! Time taken 33.46s Flashing Speed: 11912.32 kBit/S Restarting MCU... Processing N73_4.0839.42.0.1_western_C00_PRD_cc.fpsx (APE)... Booting CMT... APE_SYSTEM_ASIC_ID: 17100708 APE_ASIC_MODE_ID: 00 APE_PUBLIC_ID: BDD8F5263F12DBB82FD0726142F2670A78441FDB APE_ROOT_KEY_HASH: 49A97E826B93BA20B7ED0B082475C00500000000 APE_BOOT_ROM_CRC: 1DFD6613 APE_SECURE_ROM_CRC: 2C872FD4 CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 169001137AC40154140968EDA616B2E9E0214603 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! N73_4.0839.42.0.1_western_C00_PRD_cc.fpsx, Type: Flash Image, Algo: BB5, BB5 ALGORITHM, BB5, OMAP1710 UNISTORE-II-1.2.1 ALG Searching for BootCode: DualLine 32Bit RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.42.0, Algo: BB5 Flashbus Write baud set to 51Kbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x00EC22E800006921, Samsung, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit FlashChip 0x00EC22E8 (Samsung), Size: 16MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 5E8D0D504A0902E261268C14FCD8A2C9093523BC Searching for BootCode: DualLine 32Bit helen3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.35.0, Algo: BB5 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,APE]: 0x00EC00A100800015, Samsung, NAND FlashContent[0,APE]: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF, NAND Searching for BootCode: DualLine 32Bit FlashChip 0x00EC00A1 (Samsung), Size: 128MBytes, VPP: 21V h3_sam_nand_xsr.fg, Type: Algorithm, Rev: 0.1.49.0, Algo: OMAP1710 UNISTORE-II-1.2.1 ALG Box VPP disabled Internal APE Phone VPP Enabled PAPUBKEYS Hash for APE: 5E8D0D504A0902E261268C14FCD8A2C9093523BC Flashbus Write baud set to 5.0Mbits Partitioning... Partitioning OK Started group flash erase EraseArea[0,APE]: 0x00000000-0x0007FFFF, NAND EraseArea[0,APE]: 0x00080000-0x000FFFFF, NAND EraseArea[0,APE]: 0x00100000-0x0025FFFF, NAND EraseArea[0,APE]: 0x003C0000-0x04E1FFFF, NAND Waiting 320s for erasure finish... Erase taken 1.78s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing APE KEYS Certificate... Writing APE X-LOADER Certificate... Writing APE PRIMAPP Certificate... Writing APE SOS+LOADER Certificate... Writing APE SOS*UPDAPP Certificate... Writing APE SOS+UZIP Certificate... Writing APE PAPUBKEYS Certificate... Writing APE PASUBTOC Certificate... Writing APE ADL Certificate... Writing APE SOS+XZIP Certificate... Writing APE SOS*CORE Certificate... Writing APE SOS+ROFS Certificate... Writing APE SOS+ROFX Certificate... Programming Status OK! All blocks written OK! Time taken 56.62s Flashing Speed: 7021.77 kBit/S Restarting MCU... Processing N73_rofx_4.0839.42.0.1_PRD.V08 (CMT)... Processing N73_rofx_4.0839.42.0.1_PRD.V08 (APE)... Booting CMT... APE_SYSTEM_ASIC_ID: 17100708 APE_ASIC_MODE_ID: 00 APE_PUBLIC_ID: BDD8F5263F12DBB82FD0726142F2670A78441FDB APE_ROOT_KEY_HASH: 49A97E826B93BA20B7ED0B082475C00500000000 APE_BOOT_ROM_CRC: 1DFD6613 APE_SECURE_ROM_CRC: 2C872FD4 CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 169001137AC40154140968EDA616B2E9E0214603 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! N73_rofx_4.0839.42.0.1_PRD.V08, Type: Flash Image, Algo: BB5, OMAP1710 UNISTORE-II-1.2.1 ALG, BB5, BB5 ALGORITHM Searching for BootCode: DualLine 32Bit RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.42.0, Algo: BB5 Flashbus Write baud set to 650Kbits Flashbus Read baud set to 100Kbits Using OLD BB5 FLASHING PROTOCOL If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x00EC22E800006921, Samsung, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit FlashChip 0x00EC22E8 (Samsung), Size: 16MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 5E8D0D504A0902E261268C14FCD8A2C9093523BC Searching for BootCode: DualLine 32Bit helen3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.35.0, Algo: BB5 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,APE]: 0x00EC00A100800015, Samsung, NAND FlashContent[0,APE]: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF, NAND Searching for BootCode: DualLine 32Bit FlashChip 0x00EC00A1 (Samsung), Size: 128MBytes, VPP: 21V h3_sam_nand_xsr.fg, Type: Algorithm, Rev: 0.1.49.0, Algo: OMAP1710 UNISTORE-II-1.2.1 ALG Box VPP disabled Internal APE Phone VPP Enabled PAPUBKEYS Hash for APE: 5E8D0D504A0902E261268C14FCD8A2C9093523BC Flashbus Write baud set to 5.0Mbits Partitioning... Partitioning OK Started group flash erase EraseArea[0,APE]: 0x03920000-0x04E1FFFF, NAND Waiting 320s for erasure finish... Erase taken 0.296s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing APE SOS+ROFX Certificate... Programming Status OK! All blocks written OK! Time taken 28.688s Flashing Speed: 4297.71 kBit/S Restarting MCU... Processing N73_userarea_4.0839.42.0.1.U01 (CMT)... Processing N73_userarea_4.0839.42.0.1.U01 (APE)... Booting CMT... APE_SYSTEM_ASIC_ID: 17100708 APE_ASIC_MODE_ID: 00 APE_PUBLIC_ID: BDD8F5263F12DBB82FD0726142F2670A78441FDB APE_ROOT_KEY_HASH: 49A97E826B93BA20B7ED0B082475C00500000000 APE_BOOT_ROM_CRC: 1DFD6613 APE_SECURE_ROM_CRC: 2C872FD4 CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 169001137AC40154140968EDA616B2E9E0214603 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! N73_userarea_4.0839.42.0.1.U01, Type: Flash Image, Algo: BB5, OMAP1710 UNISTORE-II-1.2.1 ALG, BB5, BB5 ALGORITHM Searching for BootCode: DualLine 32Bit RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.42.0, Algo: BB5 Flashbus Write baud set to 650Kbits Flashbus Read baud set to 100Kbits Using OLD BB5 FLASHING PROTOCOL If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x00EC22E800006921, Samsung, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit FlashChip 0x00EC22E8 (Samsung), Size: 16MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 5E8D0D504A0902E261268C14FCD8A2C9093523BC Searching for BootCode: DualLine 32Bit helen3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.35.0, Algo: BB5 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,APE]: 0x00EC00A100800015, Samsung, NAND FlashContent[0,APE]: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF, NAND Searching for BootCode: DualLine 32Bit FlashChip 0x00EC00A1 (Samsung), Size: 128MBytes, VPP: 21V h3_sam_nand_xsr.fg, Type: Algorithm, Rev: 0.1.49.0, Algo: OMAP1710 UNISTORE-II-1.2.1 ALG Box VPP disabled Internal APE Phone VPP Enabled PAPUBKEYS Hash for APE: 5E8D0D504A0902E261268C14FCD8A2C9093523BC Flashbus Write baud set to 5.0Mbits Started group flash erase EraseArea[0,APE]: 0x04E20000-0x07C9FFFF, NAND Waiting 320s for erasure finish... Erase taken 0.656s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Programming Status OK! All blocks written OK! Time taken 7.516s Flashing Speed: 5714.11 kBit/S Restarting MCU... All images processed OK! Processing post flash tasks... Setting Factory Defaults... |
![]() | #6 (permalink) |
Member: 1361078 Status: Offline Thanks Meter: 49 | my problem solve now without connected tx2 adapter flashing thanks mr moulinsky and all here is info and selftest log Booting CMT... APE_SYSTEM_ASIC_ID: 17100708 APE_ASIC_MODE_ID: 00 APE_PUBLIC_ID: BDD8F5263F12DBB82FD0726142F2670A78441FDB APE_ROOT_KEY_HASH: 49A97E826B93BA20B7ED0B082475C00500000000 APE_BOOT_ROM_CRC: 1DFD6613 APE_SECURE_ROM_CRC: 2C872FD4 CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 169001137AC40154140968EDA616B2E9E0214603 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! Searching for BootCode: DualLine 32Bit RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.42.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x00EC22E800006921, Samsung, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit FlashChip 0x00EC22E8 (Samsung), Size: 16MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 5E8D0D504A0902E261268C14FCD8A2C9093523BC APE Boot skipped on user request Flashbus Write baud set to 5.0Mbits Restarting MCU... MCU Version V 05wk47v61 MCU Date 09-07-08 Product RM-133 (Nokia N73) Manufacturer (c) Nokia. IMEI 12345610654321? IMEI Spare 1A32541660452301 IMEI SV 1332541660452371F7000000 PSD 0000002200000000 RETU 15 TAHVO 22 AHNE 30 RFIC 17211721 DSP scarfe_mc.05wk46v50p2 Simlock Server SIMLOCK SERVER VERSION 63 Simlock Key FFFFFFFFFFFFFFFF Simlock Profile FFFFFFFFFFFFFFFF Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 00101F Auto Selecting Flash Files on User Request... Product Code: Scanning avaiable products... Processing C:\Program Files\Nokia\Phoenix\Products\... Found 5 products, Filtering DCT4 Products - wait... 0 Products left after filtering. Ready. This is Valid BB5 Product Variant found for readen Product Data! Selftests to proceed: 38 Passed ST_TAHVOINT_TEST Passed ST_UEM_CBUS_IF_TEST Passed ST_EAR_DATA_LOOP_TEST Passed ST_SIM_CLK_LOOP_TEST Passed ST_SIM_IO_CTRL_LOOP_TEST Passed ST_SIM_LOCK_TEST Passed ST_SECURITY_TEST Passed ST_PWR_KEY_TEST Passed ST_CURRENT_CONS_TEST Passed ST_BACKUP_BATT_TEST Passed ST_CMT_APE_WAKEUP_TEST Passed ST_SLEEPCLK_FREQ_TEST Passed ST_RADIO_TEST Passed ST_HOOKINT_TEST Passed ST_BTEMP_TEST Passed ST_VIBRA_TEST Passed ST_MBUS_RX_TX_LOOP_TEST Passed ST_EXT_DEVICE_TEST Passed ST_CDSP_RF_BB_IF_TEST Passed ST_CDSP_RF_SUPPLY_TEST Passed ST_CDSP_TX_IQ_TEST Passed ST_CDSP_TXC_DATA_TEST Passed ST_CDSP_PWR_DETECTOR_BIAS_TEST Passed ST_CDSP_RX_PLL_PHASE_LOCK_TEST Passed ST_CDSP_TX_PLL_PHASE_LOCK_TEST |
![]() | #8 (permalink) |
Member: 1361078 Status: Offline Thanks Meter: 49 | when i press auto recovery imie software always give this error APE_SYSTEM_ASIC_ID: 17100708 APE_ASIC_MODE_ID: 00 APE_PUBLIC_ID: BDD8F5263F12DBB82FD0726142F2670A78441FDB APE_ROOT_KEY_HASH: 49A97E826B93BA20B7ED0B082475C00500000000 APE_BOOT_ROM_CRC: 1DFD6613 APE_SECURE_ROM_CRC: 2C872FD4 CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 169001137AC40154140968EDA616B2E9E0214603 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! Searching for BootCode: DualLine 32Bit RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.42.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x00EC22E800006921, Samsung, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit FlashChip 0x00EC22E8 (Samsung), Size: 16MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 5E8D0D504A0902E261268C14FCD8A2C9093523BC APE Boot skipped on user request Flashbus Write baud set to 5.0Mbits Restarting MCU... Started IMEI Recovery... Booting CMT... APE_SYSTEM_ASIC_ID: 17100708 APE_ASIC_MODE_ID: 00 APE_PUBLIC_ID: BDD8F5263F12DBB82FD0726142F2670A78441FDB APE_ROOT_KEY_HASH: 49A97E826B93BA20B7ED0B082475C00500000000 APE_BOOT_ROM_CRC: 1DFD6613 APE_SECURE_ROM_CRC: 2C872FD4 CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 169001137AC40154140968EDA616B2E9E0214603 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! Searching for BootCode: DualLine 32Bit RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.42.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x00EC22E800006921, Samsung, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit FlashChip 0x00EC22E8 (Samsung), Size: 16MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 5E8D0D504A0902E261268C14FCD8A2C9093523BC Searching for BootCode: DualLine 32Bit helen3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.35.0, Algo: BB5 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,APE]: 0x00EC00A100800015, Samsung, NAND FlashContent[0,APE]: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF, NAND Searching for BootCode: DualLine 32Bit FlashChip 0x00EC00A1 (Samsung), Size: 128MBytes, VPP: 21V h3_sam_nand_xsr.fg, Type: Algorithm, Rev: 0.1.49.0, Algo: OMAP1710 UNISTORE-II-1.2.1 ALG Box VPP disabled Internal APE Phone VPP Enabled PAPUBKEYS Hash for APE: 5E8D0D504A0902E261268C14FCD8A2C9093523BC Flashbus Write baud set to 5.0Mbits Looking NPC for 169001137AC40154140968EDA616B2E9E0214603... Failed to Recovery IMEI -> Range check error what can i do now mr moulinsky plz help me i m waiting your answer |
![]() | #11 (permalink) |
Member: 1361078 Status: Offline Thanks Meter: 49 | my problem solve now Booting CMT... APE_SYSTEM_ASIC_ID: 17100708 APE_ASIC_MODE_ID: 00 APE_PUBLIC_ID: BDD8F5263F12DBB82FD0726142F2670A78441FDB APE_ROOT_KEY_HASH: 49A97E826B93BA20B7ED0B082475C00500000000 APE_BOOT_ROM_CRC: 1DFD6613 APE_SECURE_ROM_CRC: 2C872FD4 CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 169001137AC40154140968EDA616B2E9E0214603 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! Searching for BootCode: DualLine 32Bit RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.42.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x00EC22E800006921, Samsung, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit FlashChip 0x00EC22E8 (Samsung), Size: 16MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 5E8D0D504A0902E261268C14FCD8A2C9093523BC APE Boot skipped on user request Flashbus Write baud set to 5.0Mbits Restarting MCU... here is info logMCU Version V 05wk47v61 MCU Date 09-07-08 Product RM-133 (Nokia N73) Manufacturer (c) Nokia. IMEI 358634015408549 Mastercode 4062732330 IMEI Spare 3A85360451045804 IMEI SV 3385360451045874F7000000 PPM V 4.0839.42.0.1, 25-09-2008, RM-133, j,&V 4.0839.42.0.1-08, 25-09-2008, RM-133, qLGHCI Version 3 (rev. 1740). LMP Version 3 (rev. 1740). Manufacturer 10.n1o256p1 PSN 0EFDFF0AA Product Code 0595228 PSD 0000002200000000 Camera 1 APE SW V 4.0839.42.0.1, 25-09-2008, RM-133, APE Variant V 4.0839.42.0.1-08, 25-09-2008, RM-133, APE HW 1 APE ADSP 256 APE BT HCI Version 3 (rev. 1740). LMP Version 3 (rev. 1740). Manufacturer 10. RETU 15 TAHVO 22 AHNE 30 HW 3002i(#V 4.0839.42.0.1, 25-09-2008, RM-133, j,&V 4.0839.42.0.1-08, 25-09-2008, RM-133, qLGHCI Version 3 (rev. 1740). LMP Version 3 (rev. 1740). Manufacturer 10.n1o256p1 PCI i(#V 4.0839.42.0.1, 25-09-2008, RM-133, j,&V 4.0839.42.0.1-08, 25-09-2008, RM-133, qLGHCI Version 3 (rev. 1740). LMP Version 3 (rev. 1740). Manufacturer 10.n1o256p1 UEM V 4.0839.42.0.1, 25-09-2008, RM-133, j,&V 4.0839.42.0.1-08, 25-09-2008, RM-133, qLGHCI Version 3 (rev. 1740). LMP Version 3 (rev. 1740). Manufacturer 10.n1o256p1 UPP V 4.0839.42.0.1, 25-09-2008, RM-133, j,&V 4.0839.42.0.1-08, 25-09-2008, RM-133, qLGHCI Version 3 (rev. 1740). LMP Version 3 (rev. 1740). Manufacturer 10.n1o256p1 RFIC 17211721 DSP scarfe_mc.05wk46v50p2i(#V 4.0839.42.0.1, 25-09-2008, RM-133, j,&V 4.0839.42.0.1-08, 25-09-2008, RM-133, qLGHCI Version 3 (rev. 1740). LMP Version 3 (rev. 1740). Manufacturer 10.n1o256p1 LCD V 4.0839.42.0.1, 25-09-2008, RM-133, j,&V 4.0839.42.0.1-08, 25-09-2008, RM-133, qLGHCI Version 3 (rev. 1740). LMP Version 3 (rev. 1740). Manufacturer 10.n1o256p1 BT V 4.0839.42.0.1, 25-09-2008, RM-133, j,&V 4.0839.42.0.1-08, 25-09-2008, RM-133, qLGHCI Version 3 (rev. 1740). LMP Version 3 (rev. 1740). Manufacturer 10.n1o256p1 ADSP Sw V 4.0839.42.0.1, 25-09-2008, RM-133, j,&V 4.0839.42.0.1-08, 25-09-2008, RM-133, qLGHCI Version 3 (rev. 1740). LMP Version 3 (rev. 1740). Manufacturer 10.n1o256p1 ADSP DevID V 4.0839.42.0.1, 25-09-2008, RM-133, j,&V 4.0839.42.0.1-08, 25-09-2008, RM-133, qLGHCI Version 3 (rev. 1740). LMP Version 3 (rev. 1740). Manufacturer 10.n1o256p1 ADSP RevID V 4.0839.42.0.1, 25-09-2008, RM-133, j,&V 4.0839.42.0.1-08, 25-09-2008, RM-133, qLGHCI Version 3 (rev. 1740). LMP Version 3 (rev. 1740). Manufacturer 10.n1o256p1 AEM V 4.0839.42.0.1, 25-09-2008, RM-133, j,&V 4.0839.42.0.1-08, 25-09-2008, RM-133, qLGHCI Version 3 (rev. 1740). LMP Version 3 (rev. 1740). Manufacturer 10.n1o256p1 Flip MCUSW V 4.0839.42.0.1, 25-09-2008, RM-133, j,&V 4.0839.42.0.1-08, 25-09-2008, RM-133, qLGHCI Version 3 (rev. 1740). LMP Version 3 (rev. 1740). Manufacturer 10.n1o256p1 Simlock Server SIMLOCK SERVER VERSION 63 Simlock Key 2440700000000000 Simlock Profile 8000000000000006 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [1,2] State: OPENED Type: GID Data: FFFF Simlock [1,3] State: OPENED Type: GID Data: FFFF Simlock [1,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [1,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [2,2] State: OPENED Type: GID Data: FFFF Simlock [2,3] State: OPENED Type: GID Data: FFFF Simlock [2,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [3,2] State: OPENED Type: GID Data: FFFF Simlock [3,3] State: OPENED Type: GID Data: FFFF Simlock [3,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [4,2] State: OPENED Type: GID Data: FFFF Simlock [4,3] State: OPENED Type: GID Data: FFFF Simlock [4,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [5,2] State: OPENED Type: GID Data: FFFF Simlock [5,3] State: OPENED Type: GID Data: FFFF Simlock [5,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [6,2] State: OPENED Type: GID Data: FFFF Simlock [6,3] State: OPENED Type: GID Data: FFFF Simlock [6,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [7,2] State: OPENED Type: GID Data: FFFF Simlock [7,3] State: OPENED Type: GID Data: FFFF Simlock [7,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Auto Selecting Flash Files on User Request... Product Code: 0595228 This is Valid BB5 Product No variant found with given Product Code, selecting first one thanks all |
